Can't get RDMA working on a KVM-VM on AMD Epyc cores.
I struggle to get the following setup running:
I have multiple AMD-epyc machines with Mellanox MCX556A-ECAT Cards (ConnectX-5).
I want to run a KVM virtual machine on these computers and have InfiniBand communication between different VMs (to get some MPI running).
Installation so far:
Host and Guest OS is Centos 7.7.
A Subnet Manager with virt_enabled 2 is running on one of the host systems.
I followed the steps in this guide.
I installed MLNX_OFED_LINUX-5.0-1.0.0.0-rhel7.7-x86_64 drivers on the hosts, enabled SR-IOV in the BIOS and set the kernel boot parameters amd_iommu=on and iommu=pt.
SR-IOV is enabled for the cards and I set /sys/class/infiniband/mlx5_1/device/mlx5_num_vfs to 2, /sys/class/infiniband/mlx5_1/device/sriov/XXX/policy is set to follow and each VF gets a node and port guid.
Then I unbind and bind the driver. This results in a set of vf-PCI devices as expected.
I then attach one of the vf-PCI devices to the KVM virtual machine via virsh and boot the VM. I can see the PCI device and installed MLNX_OFED_LINUX in the VM as well. Then I set up IPoIB and this works quite well.
Problem:
At this point, I can use IPoIB and I can also successfully use ibping. I can also use a tool like ib_write_bw from one of the Hosts to one of the VMs. But when I use these tools from one VM to another host or another VM, I get the errors below. Higher level tools like libverbs also don’t work.
Output VM (ib_write_bw client)
ib_write_bw host0 -x 0
RDMA_Write BW Test
Dual-port : OFF Device : mlx5_0
Number of qps : 1 Transport type : IB
Connection type : RC Using SRQ : OFF
PCIe relax order: ON
TX depth : 128
CQ Moderation : 1
Mtu : 4096[B]
Link type : IB
GID index : 1
Max inline data : 0[B]
rdma_cm QPs : OFF
Data ex. method : Ethernet
ethernet_read_keys: Couldn’t read remote address
Unable to read from socket/rdam_cm
Failed to exchange data between server and clients
Output other Host (ib_write_bw server)
ib_write_bw -d mlx5_1
  • Waiting for client to connect… *
RDMA_Write BW Test
Dual-port : OFF Device : mlx5_1
CQ Moderation : 1
Mtu : 4096[B]
Link type : IB
rdma_cm QPs : OFF
local address: LID 0x0b QPN 0x090e PSN 0x251319 RKey 0x00256e VAddr 0x007f4e0629a000
Unable to read to socket/rdam_cm
Output ibstat on VM
ibstat
CA ‘mlx5_0’
CA type: MT4120
Number of ports: 1
Firmware version: 16.27.1016
Hardware version: 0
Node GUID: 0x1122334400000100
System image GUID: 0x506b4b03000cef94
Port 1:
State: Active
Physical state: LinkUp
Rate: 56
Base lid: 4
LMC: 0
SM lid: 11
Capability mask: 0x2651ec48
Port GUID: 0x1122334400000101
Link layer: InfiniBand
Any help is appreciated 🙂!
Best Regards
Jonathan
Hi Jonathan,
How many baremetal servers (KVM) and how many VM’s per baremetal servers?
Is the Mellanox driver on the VM’s same as the baremetal servers, 5.0?
How many connectX-5 HCA cards per baremetal servers?
How many VF’s per VM’s?
Can you use ib_write_bw between baremetal servers?
Can you use ib_write_bw between VM’s belonging to the same baremetal server?
Can you use ib_write_bw between VM’s belonging to different baremetal servers?
same 3 questions above but this time with ping?
can you run any of the tests above adding option -R to the ib_write_bw (client/server)?
Do you use these tests using the ipoib ip addrs from the IB interfaces?
Are you getting the same results with ib_read_bw & ib_write_bw?
Can you confirm if the subnet prefix is the same for both the IP’s? (as applicable)
is firewall disabled?
is SELINUX disabled?
is the perftest package the same version/build?
are all ib interfaces part of the same subnet?
Those are pointers however, I would suggest opening a case
at Mellanox to further investigate/troubleshoot (supportadmin@mellanox.com)
Sophie.
one more thing, the utility uses default port 18515, is this port free? if not, you can use -p to use a different port. (ib_write_bw --help)
Sophie.
Thank you very much for your long Answer! I tried to answer all of your questions. I will follow your suggestion and write an email to the support.
Well, at the moment 2 servers with 1 VM per Server. If this works, maybe more later on…
Yes. The output of mst version is “mst, mft 4.14.0-105, built on Feb 27 2020, 13:41:03. Git SHA Hash: 52fcec8” on the VM as well as on the baremetal.
1 card per server
For the moment 4 VF’s.
Yes, this works
No, same problem.
No, that is exactly what I want to achive and it doesn’t work.
This works in all configurations. Same with IPoIB.
  • baremetal → baremetal: Works
  • vm → baremetal, vm → vm, baremetal → vm: No connection (Hangs up infinitely). A retry on client side often throws the following error:
*> ib_write_bw -R 10.0.0.11*
*Unexpected CM event bl blka 8*
*Unable to perform rdma_client function*
*Unable to init the socket connection*
Yes, I did all tests using both, ethernet ip and IPoIB ip
Yes, here is the results again for ib_read_bw:
  • vm → baremetal: hangs (same error as initially described - Unable to read to socket/rdam_cm).
  • baremetal → vm: Works
  • vm → vm: hangs (same error as initially described - Unable to read to socket/rdam_cm)
All tests with -R:
  • baremetal → baremetal with -R: Works
  • vm → baremetal, vm → vm, baremetal → vm: No connection (Hangs up infinitely). A retry often throws the same Error as on ib_write_bw.
Yes, Ethernet IPs share a subnet and the IPoIB IPs share another subnet.
firewalld is disabled and there is no other firewall on the network.
Yes, it is disabled
Yes, they are all on Version: 5.78.1
Yes, all are connected to the same IB-switch and there should be no other subnet present. However, there two SM running: One on the switch with lowest priority, and one on one of the barebone servers.
Yes, the port is free. Using another port does not make a difference.
Hi Jonathan,
I was referring to the Mellanox Driver ie: ofed_info -s, make sure the Mellanox Driver has been installed on the VM’s Guest and same version as the baremetal servers. You want to make sure the perftest utilities are running the same version due to interoperability issue.
Sophie.
