Ib_send_bw --ipv6 Errors out
I have 2 servers(Ubuntu 22.04) connected over a network with Mellanox Connect 5X card installed and an ipv6 address assigned to each of them. Basic connectivity over the network works as I am able to ping the servers from each other.
Trying to send RDMA traffic over this network (ROCE v2), i try the following commands -
Server - ib_send_bw --ib-dev=mlx5_1 --ipv6
Client - ib_send_bw <server_addr> --ib-dev=mlx5_1 --ipv6
The client always throws the error message -
Address family for hostname not supported for 1001:1:1:1::2:18515
Problem in resolving basic address and port
Unable to open file descriptor for socket connection Unable to init the socket connection
Am I missing something ?
(NSlookup also returns the correct ipv6 address for this host, hence the above error message is confusing)
ib_send_bw on another setup with ipv4 address seems to be working fine. So unable to figure out why the command with ipv6 address is not working.
Some more details of the card configuration -
Note - Both server and Client have similar configuration on the cards.
root@ubuntu-rdma-2:~# mstconfig -d 19:00.0 q
Device #1:
Device type: ConnectX5
Description: Mellanox ConnectX-5 MCX515A-CCAT single port 100GbE QSFP28 NIC
Device: 19:00.0
Configurations: Next Boot
MEMIC_BAR_SIZE 0
MEMIC_SIZE_LIMIT _256KB(1)
HOST_CHAINING_MODE DISABLED(0)
HOST_CHAINING_CACHE_DISABLE False(0)
HOST_CHAINING_DESCRIPTORS Array[0..7]
HOST_CHAINING_TOTAL_BUFFER_SIZE Array[0..7]
FLEX_PARSER_PROFILE_ENABLE 0
FLEX_IPV4_OVER_VXLAN_PORT 0
ROCE_NEXT_PROTOCOL 254
ESWITCH_HAIRPIN_DESCRIPTORS Array[0..7]
ESWITCH_HAIRPIN_TOT_BUFFER_SIZE Array[0..7]
PF_BAR2_SIZE 0
PF_NUM_OF_VF_VALID False(0)
NON_PREFETCHABLE_PF_BAR False(0)
VF_VPD_ENABLE False(0)
PF_NUM_PF_MSIX_VALID False(0)
PER_PF_NUM_SF False(0)
STRICT_VF_MSIX_NUM False(0)
VF_NODNIC_ENABLE False(0)
NUM_PF_MSIX_VALID True(1)
NUM_OF_VFS 8
NUM_OF_PF 2
PF_BAR2_ENABLE False(0)
SRIOV_EN True(1)
PF_LOG_BAR_SIZE 5
VF_LOG_BAR_SIZE 0
NUM_PF_MSIX 63
NUM_VF_MSIX 11
INT_LOG_MAX_PAYLOAD_SIZE AUTOMATIC(0)
PCIE_CREDIT_TOKEN_TIMEOUT 0
ACCURATE_TX_SCHEDULER False(0)
PARTIAL_RESET_EN False(0)
SW_RECOVERY_ON_ERRORS False(0)
RESET_WITH_HOST_ON_ERRORS False(0)
ADVANCED_POWER_SETTINGS False(0)
CQE_COMPRESSION BALANCED(0)
IP_OVER_VXLAN_EN False(0)
MKEY_BY_NAME False(0)
ESWITCH_IPV4_TTL_MODIFY_ENABLE False(0)
PRIO_TAG_REQUIRED_EN False(0)
UCTX_EN True(1)
PCI_ATOMIC_MODE PCI_ATOMIC_DISABLED_EXT_ATOMIC_ENABLED(0)
TUNNEL_ECN_COPY_DISABLE False(0)
LRO_LOG_TIMEOUT0 6
LRO_LOG_TIMEOUT1 7
LRO_LOG_TIMEOUT2 8
LRO_LOG_TIMEOUT3 13
LOG_TX_PSN_WINDOW 7
LOG_MAX_OUTSTANDING_WQE 7
ROCE_ADAPTIVE_ROUTING_EN False(0)
TUNNEL_IP_PROTO_ENTROPY_DISABLE False(0)
ICM_CACHE_MODE DEVICE_DEFAULT(0)
TX_SCHEDULER_BURST 0
ZERO_TOUCH_TUNING_ENABLE False(0)
LOG_MAX_QUEUE 17
LOG_DCR_HASH_TABLE_SIZE 11
DCR_LIFO_SIZE 16384
ROCE_CC_PRIO_MASK_P1 255
CLAMP_TGT_RATE_AFTER_TIME_INC_P1 True(1)
CLAMP_TGT_RATE_P1 False(0)
RPG_TIME_RESET_P1 300
RPG_BYTE_RESET_P1 32767
RPG_THRESHOLD_P1 1
RPG_MAX_RATE_P1 0
RPG_AI_RATE_P1 5
RPG_HAI_RATE_P1 50
RPG_GD_P1 11
RPG_MIN_DEC_FAC_P1 50
RPG_MIN_RATE_P1 1
RATE_TO_SET_ON_FIRST_CNP_P1 0
DCE_TCP_G_P1 1019
DCE_TCP_RTT_P1 1
RATE_REDUCE_MONITOR_PERIOD_P1 4
INITIAL_ALPHA_VALUE_P1 1023
MIN_TIME_BETWEEN_CNPS_P1 4
CNP_802P_PRIO_P1 6
CNP_DSCP_P1 48
LLDP_NB_DCBX_P1 False(0)
LLDP_NB_RX_MODE_P1 OFF(0)
LLDP_NB_TX_MODE_P1 OFF(0)
DCBX_IEEE_P1 True(1)
DCBX_CEE_P1 True(1)
DCBX_WILLING_P1 True(1)
KEEP_ETH_LINK_UP_P1 True(1)
KEEP_IB_LINK_UP_P1 False(0)
KEEP_LINK_UP_ON_BOOT_P1 False(0)
KEEP_LINK_UP_ON_STANDBY_P1 False(0)
DO_NOT_CLEAR_PORT_STATS_P1 False(0)
AUTO_POWER_SAVE_LINK_DOWN_P1 False(0)
NUM_OF_VL_P1 _4_VLs(3)
NUM_OF_TC_P1 _8_TCs(0)
NUM_OF_PFC_P1 8
VL15_BUFFER_SIZE_P1 0
DUP_MAC_ACTION_P1 LAST_CFG(0)
MPFS_MC_LOOPBACK_DISABLE_P1 False(0)
MPFS_UC_LOOPBACK_DISABLE_P1 False(0)
UNKNOWN_UPLINK_MAC_FLOOD_P1 False(0)
SRIOV_IB_ROUTING_MODE_P1 LID(1)
PHY_AUTO_NEG_P1 DEVICE_DEFAULT(0)
PHY_RATE_MASK_OVERRIDE_P1 False(0)
PHY_FEC_OVERRIDE_P1 DEVICE_DEFAULT(0)
PF_TOTAL_SF 0
PF_SF_BAR_SIZE 0
PF_NUM_PF_MSIX 63
ROCE_CONTROL ROCE_ENABLE(2)
PCI_WR_ORDERING per_mkey(0)
MULTI_PORT_VHCA_EN False(0)
PORT_OWNER True(1)
ALLOW_RD_COUNTERS True(1)
RENEG_ON_CHANGE True(1)
TRACER_ENABLE True(1)
IP_VER IPv6(1)
BOOT_UNDI_NETWORK_WAIT 0
UEFI_HII_EN True(1)
BOOT_DBG_LOG False(0)
UEFI_LOGS DISABLED(0)
BOOT_VLAN 1
LEGACY_BOOT_PROTOCOL PXE(1)
BOOT_RETRY_CNT NONE(0)
BOOT_INTERRUPT_DIS False(0)
BOOT_LACP_DIS True(1)
BOOT_VLAN_EN False(0)
BOOT_PKEY 0
P2P_ORDERING_MODE DEVICE_DEFAULT(0)
ATS_ENABLED False(0)
DYNAMIC_VF_MSIX_TABLE False(0)
EXP_ROM_UEFI_x86_ENABLE True(1)
EXP_ROM_PXE_ENABLE True(1)
ADVANCED_PCI_SETTINGS False(0)
SAFE_MODE_THRESHOLD 10
SAFE_MODE_ENABLE True(1)
root@ubuntu-rdma-1:/etc/netplan# ibv_devinfo
hca_id: mlx5_0
transport: InfiniBand (0)
fw_ver: 16.34.1002
node_guid: 043f:7203:00d0:aee6
sys_image_guid: 043f:7203:00d0:aee6
vendor_id: 0x02c9
vendor_part_id: 4119
hw_ver: 0x0
board_id: CIS0000000004
phys_port_cnt: 1
port: 1
state: PORT_DOWN (1)
max_mtu: 4096 (5)
active_mtu: 1024 (3)
sm_lid: 0
port_lid: 0
port_lmc: 0x00
link_layer: Ethernet
hca_id: mlx5_1
fw_ver: 16.34.1002
node_guid: 1070:fd03:0018:e774
sys_image_guid: 1070:fd03:0018:e774
vendor_id: 0x02c9
vendor_part_id: 4121
hw_ver: 0x0
board_id: CIS0000000003
phys_port_cnt: 1
port: 1
state: PORT_ACTIVE (4)
max_mtu: 4096 (5)
sm_lid: 0
port_lid: 0
port_lmc: 0x00
hca_id: mlx5_2
fw_ver: 16.34.1002
node_guid: 1070:fd03:0018:e775
vendor_id: 0x02c9
hw_ver: 0x0
phys_port_cnt: 1
port: 1
max_mtu: 4096 (5)
sm_lid: 0
port_lid: 0
port_lmc: 0x00
Hi @sundu19962 ,
At the moment, perftest suite doesn’t support IPv6 address family , but IPv4. For additional details of implementation, you may refer to source code of the tool -
–ipv6 parameter might be confusing, but is used internally to detect a gid index, that used to initialize RoCE related resources.
As you can see, the only protocol family supported is ‘AF_INET’. This is limitation of the utility and not the kernel or user-space libraries provided by Mellanox OFED. If you are interested in having IPv6 in perftest tool, you might raise the question on linux-rdma mailing list.
At the same time, to validate, IPv6 communication establishment, you might use ‘rping’ utility
On sever side:
#rping -s -a ::0
On the sender side:
#rping -c
You can also refer to rping source code if you are interesting in the writing application that support IPv6.
Regards,
Chen
