Can't install Jupyter
“/home/shadid/.local/lib/python3.6/site-packages/pkg_resources/init.py”, line 1068, in obtain
return installer(requirement)
File “/home/shadid/.local/lib/python3.6/site-packages/setuptools/dist.py”, line 883, in fetch_build_egg
return fetch_build_egg(self, req)
File “/home/shadid/.local/lib/python3.6/site-packages/setuptools/installer.py”, line 84, in fetch_build_egg
raise DistutilsError(str(e)) from e
distutils.errors.DistutilsError: Command ‘[’/usr/bin/python3’, ‘-m’, ‘pip’, ‘–disable-pip-version-check’, ‘wheel’, ‘–no-deps’, ‘-w’, ‘/tmp/tmp8ae_5wjh’, ‘–quiet’, ‘cffi>=1.0.1’]’ returned non-zero exit status 1.
Command “python setup.py egg_info” failed with error code 1 in /tmp/pip-build-7fbw1iio/argon2-cffi-bindings/
It looks like the log is truncated.
Could you share the complete output log with us?
