I have a MIPI CSI camera connected to the CSI0 J20 connector. The camera has a trigger feature and its trigger_to_sensor port is connected to the CAM0_PWDN port on Jetson Orin Nano DevKit. From the document
< Jetson_Orin_Nano_DevKit_Carrier_Board_Specification_SP-11324-001_v1.1.pdf>, CAM0_PWND is pin 114 on J20 connector. I tried to test it over the GPIO library with a script but it says Channel 114 is not valid. Here is the script:
import Jetson.GPIO as GPIO
import time
CAM0_PWDN_PIN = '114'
# Pin Setup:
# Board pin-numbering scheme
GPIO.setmode(GPIO.BOARD)
# Set pin as an output pin with optional initial state of HIGH
GPIO.setup(CAM0_PWDN_PIN, GPIO.OUT, initial=GPIO.HIGH)
try:
print("Toggling CAM0_PWDN pin")
while True:
# Turn the camera power down off (enable the camera)
GPIO.output(CAM0_PWDN_PIN, GPIO.HIGH)
print("Camera enabled")
time.sleep(2)
# Turn the camera power down on (disable the camera)
GPIO.output(CAM0_PWDN_PIN, GPIO.LOW)
print("Camera disabled")
time.sleep(2)
finally:
GPIO.cleanup() # Clean up GPIOs for the next run
Yeah, I did find the GPIO PH.06 but not sure where 397 comes from. Is that a kind of calculation?
Also, I tried 397 with the following script but still returns invalid.
import time
CAM0_PWDN_PIN = '397'
# Pin Setup:
GPIO.setmode(GPIO.BCM)
try:
while True:
time.sleep(2)
time.sleep(2)
finally:
GPIO.cleanup() # Clean up GPIOs for next run
when I tried to test it via script or gpioset gpiochip0 397=1 command but it said invalid.
Then I run gpioinfo
gpiochip0 - 164 lines:
line 0: "PA.00" "fixed-regulators:regulator@8" output active-high [used]
line 1: "PA.01" unused input active-high
line 2: "PA.02" unused input active-high
line 3: "PA.03" unused input active-high
line 4: "PA.04" unused input active-high
line 5: "PA.05" unused input active-high
line 6: "PA.06" unused input active-high
line 7: "PA.07" unused input active-high
line 8: "PB.00" unused input active-high
line 9: "PC.00" unused input active-high
line 10: "PC.01" unused input active-high
line 11: "PC.02" unused input active-high
line 12: "PC.03" unused input active-high
line 13: "PC.04" unused input active-high
line 14: "PC.05" unused input active-high
line 15: "PC.06" unused input active-high
line 16: "PC.07" unused input active-high
line 17: "PD.00" unused input active-high
line 18: "PD.01" unused input active-high
line 19: "PD.02" unused input active-high
line 20: "PD.03" unused input active-high
line 21: "PE.00" unused input active-high
line 22: "PE.01" unused input active-high
line 23: "PE.02" unused input active-high
line 24: "PE.03" unused input active-high
line 25: "PE.04" unused input active-high
line 26: "PE.05" unused input active-high
line 27: "PE.06" unused input active-high
line 28: "PE.07" unused input active-high
line 29: "PF.00" unused input active-high
line 30: "PF.01" unused input active-high
line 31: "PF.02" unused input active-high
line 32: "PF.03" unused input active-high
line 33: "PF.04" unused input active-high
line 34: "PF.05" unused input active-high
line 35: "PG.00" "force-recovery" input active-low [used]
line 36: "PG.01" unused input active-high
line 37: "PG.02" unused input active-high
line 38: "PG.03" unused input active-high
line 39: "PG.04" unused input active-high
line 40: "PG.05" unused input active-high
line 41: "PG.06" unused input active-high
line 42: "PG.07" "cd" input active-high [used]
line 43: "PH.00" unused input active-high
line 44: "PH.01" unused input active-high
line 45: "PH.02" unused input active-high
line 46: "PH.03" unused input active-high
line 47: "PH.04" unused input active-high
line 48: "PH.05" unused input active-high
line 49: "PH.06" "camera-control-output-low" output active-high [used]
line 50: "PH.07" unused input active-high
line 51: "PI.00" unused input active-high
line 52: "PI.01" unused input active-high
line 53: "PI.02" unused input active-high
line 54: "PI.03" unused input active-high
line 55: "PI.04" unused input active-high
line 56: "PI.05" unused input active-high
line 57: "PI.06" unused input active-high
line 58: "PJ.00" unused input active-high
line 59: "PJ.01" unused input active-high
line 60: "PJ.02" unused input active-high
line 61: "PJ.03" unused input active-high
line 62: "PJ.04" unused input active-high
line 63: "PJ.05" unused input active-high
line 64: "PK.00" unused input active-high
line 65: "PK.01" unused input active-high
line 66: "PK.02" unused input active-high
line 67: "PK.03" unused input active-high
line 68: "PK.04" unused output active-high
line 69: "PK.05" unused output active-high
line 70: "PK.06" unused input active-high
line 71: "PK.07" unused input active-high
line 72: "PL.00" unused input active-high
line 73: "PL.01" unused input active-high
line 74: "PL.02" "nvidia,pex-wake" input active-low [used]
line 75: "PL.03" unused input active-high
line 76: "PM.00" unused input active-high
line 77: "PM.01" unused input active-high
line 78: "PM.02" unused input active-high
line 79: "PM.03" unused input active-high
line 80: "PM.04" unused input active-high
line 81: "PM.05" unused input active-high
line 82: "PM.06" unused input active-high
line 83: "PM.07" unused input active-high
line 84: "PN.00" unused input active-high
line 85: "PN.01" unused input active-high
line 86: "PN.02" unused input active-high
line 87: "PN.03" unused input active-high
line 88: "PN.04" unused input active-high
line 89: "PN.05" unused input active-high
line 90: "PN.06" unused input active-high
line 91: "PN.07" unused input active-high
line 92: "PP.00" unused input active-high
line 93: "PP.01" unused input active-high
line 94: "PP.02" unused input active-high
line 95: "PP.03" unused input active-high
line 96: "PP.04" unused input active-high
line 97: "PP.05" unused input active-high
line 98: "PP.06" unused input active-high
line 99: "PP.07" unused input active-high
line 100: "PQ.00" unused input active-high
line 101: "PQ.01" unused input active-high
line 102: "PQ.02" unused input active-high
line 103: "PQ.03" unused output active-high
line 104: "PQ.04" unused input active-high
line 105: "PQ.05" unused input active-high
line 106: "PQ.06" unused input active-high
line 107: "PQ.07" unused input active-high
line 108: "PR.00" unused input active-high
line 109: "PR.01" unused input active-high
line 110: "PR.02" unused input active-high
line 111: "PR.03" unused input active-high
line 112: "PR.04" unused input active-high
line 113: "PR.05" unused input active-high
line 114: "PX.00" unused input active-high
line 115: "PX.01" unused input active-high
line 116: "PX.02" unused input active-high
line 117: "PX.03" unused input active-high
line 118: "PX.04" unused input active-high
line 119: "PX.05" unused input active-high
line 120: "PX.06" unused input active-high
line 121: "PX.07" unused input active-high
line 122: "PY.00" unused input active-high
line 123: "PY.01" unused input active-high
line 124: "PY.02" unused input active-high
line 125: "PY.03" unused input active-high
line 126: "PY.04" unused input active-high
line 127: "PY.05" unused input active-high
line 128: "PY.06" unused input active-high
line 129: "PY.07" unused input active-high
line 130: "PZ.00" unused input active-high
line 131: "PZ.01" "interrupt" input active-high [used]
line 132: "PZ.02" unused input active-high
line 133: "PZ.03" unused input active-high
line 134: "PZ.04" unused input active-high
line 135: "PZ.05" unused input active-high
line 136: "PZ.06" unused input active-high
line 137: "PZ.07" unused input active-high
line 138: "PAC.00" "camera-control-output-low" output active-high [used]
line 139: "PAC.01" unused input active-high
line 140: "PAC.02" unused input active-high
line 141: "PAC.03" unused input active-high
line 142: "PAC.04" unused input active-high
line 143: "PAC.05" unused input active-high
line 144: "PAC.06" unused input active-high
line 145: "PAC.07" unused input active-high
line 146: "PAD.00" unused input active-high
line 147: "PAD.01" unused input active-high
line 148: "PAD.02" unused input active-high
line 149: "PAD.03" unused input active-high
line 150: "PAE.00" unused input active-high
line 151: "PAE.01" unused input active-high
line 152: "PAF.00" unused input active-high
line 153: "PAF.01" unused input active-high
line 154: "PAF.02" unused input active-high
line 155: "PAF.03" unused input active-high
line 156: "PAG.00" unused input active-high
line 157: "PAG.01" unused input active-high
line 158: "PAG.02" unused input active-high
line 159: "PAG.03" unused input active-high
line 160: "PAG.04" unused input active-high
line 161: "PAG.05" unused input active-high
line 162: "PAG.06" unused input active-high
line 163: "PAG.07" unused input active-high
gpiochip1 - 32 lines:
line 0: "PAA.00" unused input active-high
line 1: "PAA.01" unused input active-high
line 2: "PAA.02" unused input active-high
line 3: "PAA.03" unused input active-high
line 4: "PAA.04" unused output active-high
line 5: "PAA.05" "fixed-regulators:regulator@12" output active-high [used]
line 6: "PAA.06" unused input active-high
line 7: "PAA.07" unused input active-high
line 8: "PBB.00" unused input active-high
line 9: "PBB.01" unused input active-high
line 10: "PBB.02" unused input active-high
line 11: "PBB.03" unused output active-high
line 12: "PCC.00" unused output active-high
line 13: "PCC.01" unused output active-high
line 14: "PCC.02" unused output active-high
line 15: "PCC.03" "mux" output active-high [used]
line 16: "PCC.04" unused input active-high
line 17: "PCC.05" unused input active-high
line 18: "PCC.06" unused input active-high
line 19: "PCC.07" unused input active-high
line 20: "PDD.00" unused input active-high
line 21: "PDD.01" unused input active-high
line 22: "PDD.02" unused input active-high
line 23: "PEE.00" unused input active-high
line 24: "PEE.01" unused input active-high
line 25: "PEE.02" unused input active-high
line 26: "PEE.03" unused input active-high
line 27: "PEE.04" "power-key" input active-low [used]
line 28: "PEE.05" unused input active-high
line 29: "PEE.06" unused input active-high
line 30: "PEE.07" unused input active-high
line 31: "PGG.00" unused input active-high
and from the gpiochip0, I can see that line 49: "PH.06" "camera-control-output-low" output active-high [used]
Then I tried setting up and down with the commands gpioset gpiochip0 49=<1 or 0> and it returned no error but I also didn’t see any effect on the camera feed. What do you think about this route?
But if I release the camera sensor, then I can not use the camera. The purpose here is to trigger the camera module via CAM0_PWDN so it captures frames at the triggered moment. I did not understand the context of using by gpiofs.
