Hi NVIDIA experts,
I verify capsule update feature with below steps:
download Driver Package (BSP)
deploy image into sd card that is attached on orin nano board
In recovery mode, run command “sudo ./nvsdkmanager_flash.sh”
after board boots up, install nvidia-jetpack
sudo apt update
sudo apt install nvidia-jetpack
Generate update capsule
In recovery mode, run below command to generate Single-Spec BUP
cd xxx/Jetson_Linux_R36.4.3_aarch64/Linux_for_Tegra
sudo ./build_l4t_bup.sh jetson-orin-nano-devkit mmcblk0p1
Generate the Capsule Payload from the BUP
./generate_capsule/l4t_generate_soc_capsule.sh
-i bootloader/payloads_t23x/bl_only_payload
-o ./TEGRA_BL.Cap t234
Trigger update
boots up board normally, run boot command
sudo mkdir /boot/efi/EFI/UpdateCapsule/
sudo cp xxxx/TEGRA_BL.Cap /boot/efi/EFI/UpdateCapsule/
cd /sys/firmware/efi/efivars/
printf “\x07\x00\x00\x00\x04\x00\x00\x00\x00\x00\x00\x00” > /tmp/var_tmp.bin
sudo dd if=/tmp/var_tmp.bin of=OsIndications-8be4df61-93ca-11d2-aa0d-00e098032b8c bs=12; sync
sudo reboot
But the board doesn’t not switch to slot 1, it still boots up from slot 0.
Could you please help to have a look this issue?
thanks.
Limeng
Based on the provided context, it appears that you are trying to update the Bootloader on a Jetson Orin Nano device using the Capsule update feature. However, the board is not switching to the updated slot after the update.
To troubleshoot this issue, let’s compare the steps you provided with the steps in the context:
- You generated the Capsule payload using the
l4t_generate_soc_capsule.sh script, which is correct.
- You triggered the update by setting the bit2 of the
OsIndications UEFI variable, which is also correct.
- You rebooted the board, which should have triggered the Capsule update.
However, there are a few potential issues that might be causing the board to not switch to the updated slot:
- Make sure that the
OsIndications UEFI variable is set correctly. You can verify this by checking the value of the variable using the dd command: sudo dd if=OsIndications-8be4df61-93ca-11d2-aa0d-00e098032b8c bs=12
- Ensure that the Capsule payload is correctly generated and placed in the
EFI/UpdateCapsule directory.
- Verify that the
nvbootctrl command is correctly configured to update the non-current slot Bootloader.
- Check the
Capsule update status using the nvbootctrl command: sudo nvbootctrl dump-slots-info. If the status is not 1 - Capsule update successfully, it may indicate an issue with the update process.
Additionally, you can try to check the UEFI firmware logs to see if there are any errors or issues during the update process. You can do this by running the sudo efibootmgr -v command.
It’s also worth noting that the l4t_generate_soc_bup.sh script is used to generate the SingleSpec BUP, but in your case, you are using the l4t_generate_soc_capsule.sh script to generate the Capsule payload. Make sure that the correct script is being used for your specific use case.
If none of these troubleshooting steps resolve the issue, it may be helpful to provide more information about your specific setup and configuration, such as the version of the JetPack and the BSP you are using.
Is tegra-kernel.cap able to be updated with capsule solution?
thanks,
Limeng
Could you please show a detailed steps to do capsule update?
thanks,
Limeng
Have you run below commands to check whether update complete?
$ sudo nvbootctrl dump-slots-info
now, I can update tegra-bl.cap normally. But I don’t find out example about how to update egra-kernel.cap.
So, I ask whether tegra-kernel.cap is able to be updated with capsule solution?
thanks,
Limeng
We don’t have kernel capsule solution.
Please refer to the image-based ota update Software Packages and the Update Mechanism — NVIDIA Jetson Linux Developer Guide to update the kernel.
