Based on the provided context, it appears that you are trying to update the Capsule on a Jetson Orin NX device. The command you ran seems to be incomplete, but I’ll provide a comprehensive answer based on the context.
To update the Capsule, you need to follow the steps outlined in the context:
- Copy the Capsule payload to the
EFI/UpdateCapsule directory in the esp partition of the active boot media.
- Set the bit2 of the
OsIndications UEFI variable.
- Reboot the Jetson device. UEFI uses the Capsule payload to update the non-current slot Bootloader.
- To check the Capsule update status and current slot, run the
nvbootctrl command.
If you’ve completed these steps and the Capsule update status is success, it’s likely that the update was successful. However, if you’re unsure, you can verify the update by checking the UEFI Secure Boot status and the updated KEK, db, and dbx keys.
To check the UEFI Secure Boot status, you can follow the high-level process outlined in the context:
- Prepare the update keys.
- Generate the Capsule payload with UEFI Secure Boot enabled.
- Trigger a Capsule update.
- Check and verify update keys.
If the UEFI Secure Boot status is enabled, and the updated KEK, db, and dbx keys are verified, it’s likely that the Capsule update was successful.
In your case, since you didn’t provide the complete command, it’s difficult to determine if the update was successful. However, if you’ve completed the steps outlined above and the Capsule update status is success, it’s likely that the update was successful.
To confirm, you can try running the nvbootctrl command to check the Capsule update status and current slot. If the status is success, and the current slot is updated, it’s likely that the Capsule update was successful.
In comparison to other Jetson devices, the update process for the Jetson Orin NX is similar. However, the specific commands and steps may vary depending on the device and the version of the UEFI firmware.
In summary, to determine if the Capsule update was successful, you can:
- Check the Capsule update status and current slot using the
nvbootctrl command.
- Verify the UEFI Secure Boot status and the updated KEK, db, and dbx keys.
- Follow the high-level process outlined in the context to update the UEFI Secure Boot keys.
If you’re still unsure, please provide more information about the command you ran and the output you received, and I’ll be happy to help you further.
