Capture vGPU performance, Host vCPU, VM vCPU and memory performance using rrd2csv
Intent:
Capture the virtual machines memory, vCPU performance data along with the vGPU’s GPU utilization in the hypervisor.
Get a list of the virtual machines using:
[root@nvgrid ~]# xe vm-list | awk ‘{if ( $0 ~ /uuid/) {uuid=$5} if ($0 ~ /name-label/) {$1=$2=$3="";vmname=$0; printf "%20s - %s\n", vmname, uuid}}’
hp2-vgpu1 - 8c8781a1-c8eb-3471-2f19-37c68407015e
hp2-vgpu2 - 02ba1ffc-c8b1-8fca-a54b-edae4902a5d1
hp2-vgpu3 - 3061703c-374a-4fc5-8b65-23a84cd01106
hp2-vgpu4 - 9034ca98-fee3-643f-fc95-f189e42cb4c4
Set environment variables for each of the virtual machines to make the rrd2csv a ‘little’ more readable:
[root@nvgrid ~]# export UUID1=8c8781a1-c8eb-3471-2f19-37c68407015e
[root@nvgrid ~]# export UUID2=02ba1ffc-c8b1-8fca-a54b-edae4902a5d1
[root@nvgrid ~]# export UUID3=3061703c-374a-4fc5-8b65-23a84cd01106
[root@nvgrid ~]# export UUID4=9034ca98-fee3-643f-fc95-f189e42cb4c4
[root@nvgrid ~]# rrd2csv -n -s 5 AVERAGE:vm:$UUID1:memory AVERAGE:vm:$UUID1:cpu AVERAGE:vm:$UUID2:memory AVERAGE:vm:$UUID2:cpu AVERAGE:vm:$UUID3:memory AVERAGE:vm:$UUID3:cpu AVERAGE:vm:$UUID4:memory AVERAGE:vm:$UUID4:cpu AVERAGE:host::cpu_avg AVERAGE:host::gpu > ./vGPU-VMs-perf.csv
Now connect to your virtual machines and run some benchmarks and/or applications. This rrd2csv query utilizes wildcards by not being specific about all counter source names. If you wish to capture specific counters use the direct name following the AVERAGE:host::cpu_avg example.
<CTRL + c> to stop the capture process, then transfer the resulting .csv file to view the results.
Some counters will not have data, please look closely at the rrd2csv help via
rrd2csv -help
as well as :
Performance Monitoring Enhancements Pack for XenServer 6.1
http://support.citrix.com/article/CTX135033
Thanks Jeremy, my white paper on metrics has been wrapped into main doc, Sally our user experience lead did a great job adding a new chapter 9 with loads of other useful metrics, vGPU should join this in the next main release http://blogs.citrix.com/2014/01/22/xenserverxendesktop-vgpu-new-metrics-available-to-monitor-nvidia-grid-gpus/
A lot of metrics of by default but some super storage and IO
Nvidia now also have the NVWMI toolkit link on this page Citrix and NVIDIA extend vGPU support to include Windows 8.1 and Windows Server 2012 R2 | Citrix Blogs
