Capturing 10-bit image from IMX274
Hello. I’m trying to capture a 10-bit raw image from an IMX274 MIPI CSI-2 camera from Leopard Imaging using Jetson TX2 on a Spacely carrier board from Connect Tech. I’m using JetPack 4.6.3 (L4T 32.7.3).
I tried using the following command:
v4l2-ctl -v width=3840,height=2160,pixelformat=RG10 -c bypass_mode=0 --stream-mmap --stream-count=1 --stream-to=imag.raw -d /dev/video0 --verbose
It displays the following on screen and freezes (the imag.raw file is 0 bytes):
VIDIOC_QUERYCAP: ok
VIDIOC_S_EXT_CTRLS: ok
VIDIOC_G_FMT: ok
VIDIOC_S_FMT: ok
Format Video Capture:
        Width/Height      : 3840/2160
        Pixel Format      : 'RG10' (10-bit Bayer RGRG/GBGB)
        Field             : None
        Bytes per Line    : 7680
        Size Image        : 16588800
        Colorspace        : sRGB
        Transfer Function : Default (maps to sRGB)
        YCbCr/HSV Encoding: Default (maps to ITU-R 601)
        Quantization      : Default (maps to Full Range)
        Flags             :
                VIDIOC_REQBUFS returned 0 (Success)
                VIDIOC_QUERYBUF returned 0 (Success)
                VIDIOC_QBUF returned 0 (Success)
                VIDIOC_STREAMON returned 0 (Success)
I see the following error messages using dmesg:
[  735.586502] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[  735.594936] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[  735.643172] tegra-i2c c240000.i2c: no acknowledge from address 0x50
[  735.665955] arm-smmu 12000000.iommu: Unhandled context fault: iova=0x00000000, fsynr=0x11, cb=15, sid=4(0x4 - VI), pgd=0, pud=0, pmd=0, pte=0
What could be wrong here? Is there otherwise a way of capturing 10 or 12-bit images from IMX274? (preferably using GStreamer).
@SimonZhu
Could you help to check this issue.
@Oystein1 Can you see video output with Argus software (argus_camera -d 0)? If so, can you try below steps?
  1. Use Argus software to get the video (assume the default mode is 3840x2160).
  2. Close argus and try the v4l2 command again.
Yes. I can see video output using GStreamer and nvarguscamerasrc. For example, I can capture a video using this command line:
gst-launch-1.0 nvarguscamerasrc ! \
     "video/x-raw(memory:NVMM), width=(int)3840, height=(int)2160,format=(string)NV12,framerate=(fraction)30/1" ! nvv4l2h264enc \
 bitrate=8000000 ! h264parse ! qtmux ! filesink location=test.mp4 -e
I tried to run v4l2-ctl again (after successfully capturing video with nvarguscamerasrc), but the problem remains the same. (I also tried to shut down nvargus-daemon, but it didn’t help).
Have you installed the Argus software? Could you run the “argus_camera -d 0” and then try the v4l2-ctl again?
Can you let me know exactly what Argus software you are talking about? Do you have a link to where I can download it for JetPack 4.6.3?
The Argus software can be downloaded from link below or installed from Jetpack directly.
Open a terminal, do
$ sudo apt-get update
$ sudo apt-get install cmake build-essential pkg-config libx11-dev libgtk-3-dev libexpat1-dev libjpeg-dev libgstreamer1.0-dev
Uncompress the zip package, do
$ unzip jetson_multimedia_api_r32.7.3.zip
Under jetson_multimedia_api/argus/cmake, do
$ cmake …
$ make
$ sudo make install
Do "argus_camera -d 0” to get the video.
I have followed your instructions and compiled and installed the Argus software. I am able to successfully view the video using argus_camera -d 0.
However, when I run v4l2-ctl (as previously mentioned), it still freezes and the imag.raw file is 0 bytes.
Could you try below command after terminal argus_camera.
v4l2-ctl --stream-mmap -c bypass_mode=0
I tried it (after running argus_camera -d 0). What is supposed to happen? It just hangs:
$ v4l2-ctl --stream-mmap -c bypass_mode=0
With dmesg I can see the following:
[  151.940338] tegra-i2c c240000.i2c: no acknowledge from address 0x1a
[  151.946833] regmap_util_write_table_8:regmap_util_write_table:-121
[  151.952860] imx274 35-001a: Error writing mode
How many cameras on your system?
v4l2-ctl --list-devices
I only have one camera. But the CTI Spacely board has 3 MIPI CSI inputs. My LI-IMX274-MIPI-M12 camera is connected to CSI0.
$ v4l2-ctl --list-devices
vi-output, imx274 30-001a (platform:15700000.vi:0):
        /dev/video1
vi-output, imx274 32-001a (platform:15700000.vi:2):
        /dev/video2
vi-output, imx274 35-001a (platform:15700000.vi:4):
        /dev/video0
Maybe you can remove the video0 and video3 to try if your system didn’t connect to CSI2/CSI4
How do you mean remove video0 and video3? What exactly should I do? As I mentioned, argus_camera -d 0 works.
Do you make sure the argus_camera -d 0 map to video0?
I think it does. I tried to pass arguments -d /dev/video0, -d /dev/video1 and -d /dev/video2 to v4l2-ctl, but I get the same result.
Do you have any suggestions on how to proceed? By the way, is it possible to get 10 or 12 bit output with nvarguscamerasrc?
Suppose it could be the sensor REG configuration or device tree problem.
And nvarguscamerasrc only support YUV420 output.
