I have a situation where I will be getting input data which will always be in the unsigned int range value of 0-32, and is received as a uint8 type(from MATLAB).
I cast it as a uchar1 type in the .cpp for the cudaMemcpy to device memory.
The problem is that when I try to cast a value from that uchar1 array to a float(in a device kernel) for a calculation I get an error along the lines of 'no suitable conversion for those types…".
I am sure there is an easy way to get around this issue, but wanted to check here first.
