After attempting to stream my CSI interface RASPI V2 camera using the test-launch.c script in the gst-rtsp-server example (Followed examples in FAQ and recommendations under this forum post, I received the following output that looked more or less correct (minus the GStreamer-Critical error):
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 2
Output Stream W = 1920 H = 1080
seconds to Run = 0
Frame Rate = 29.999999
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
GST_ARGUS: Cleaning up
CONSUMER: Done Success
GST_ARGUS: Done Success
(test-launch:8836): GStreamer-CRITICAL **: 14:12:28.155: gst_element_make_from_uri: assertion 'gst_uri_is_valid (uri)' failed
Opening in BLOCKING MODE
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3264 x 2464 FR = 21.000000 fps Duration = 47619048 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 3264 x 1848 FR = 28.000001 fps Duration = 35714284 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 120.000005 fps Duration = 8333333 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
Camera index = 0
Camera mode = 2
seconds to Run = 0
It is exactly here where I lost communication with my linux kernel and got the following messages on repeat indicating a hw failure:
[0000.025] W> RATCHET: MB1 binary ratchet value 4 is too large than ratchet level 2 from HW fuses.
[0000.034] I> MB1 (prd-version: 1.5.1.3-t194-41334769-d2a21c57)
[0000.039] I> Boot-mode: Coldboot
[0000.042] I> Chip revision : A02P
[0000.045] I> Bootrom patch version : 15 (correctly patc▒▒
I am using a production module NX with the quark carrier board (so it is headless). I don’t understand how a sw command could cause such catastrophic hw damage. I have been working with the nx for many months now without an issue. Is there a way to reverse this or must I purchase a new board? Thanks
