OS: CentOS 8 Stream 64
Nvidia Card: Geforce GTX Titan Black 6GB (GK110B)
I downloaded and ran the following script.
$ sudo rpm -i cuda-repo-rhel8-11-2-local-11.2.1_460.32.03-1.x86_64.rpm
$ sudo dnf clean all
$ sudo dnf -y module install nvidia-driver:latest-dkms
$ sudo dnf -y install cuda
After installing the CUDA development pack, the display appears to not be fully functional. When running the following command before and after the install, it would appear that I have a valid device:
$ lspci | grep -i invida
01:00.0 VGA compatible controller: NVIDIA Corporation GK110B [Geforce GTX TITAN Black] (rev a1)
I run the following command, wait for completion, and restart machine
$ sudo yum install cuda
To bring system back as before I run the following and then restart system:
$ sudo dnf remove nvidia-driver
Among other things, before uninstalling the driver, when running ‘nvcc’, I get “Command not found”. Please advise. Is CentOS 8 not supported? EOL has been announced for CentOS 8, so using CentOS 8 Stream due to support.
Using the following guide for reference:
https://docs.nvidia.com/cuda/cuda-installation-guide-linux/index.html
