I followed “Jetson_X2_Developer_Kit_User_Guide.pdf” and flash binaries using jetpack.
After then, I tried to change dtb file using file copy(scp) not flash.sh.
I refered below link for this and modified extlinux.conf
Jetson/TX2 DTB - eLinux.org // Add FDT /boot/tegra186-quill-p3310-1000-c03-00-base.dtb
but after this, board has not boot up with below error message.
Do I need more fix for it?
Enter choice: 1: primary kernel
Retrieving file: /boot/Image
20484864 bytes read in 537 ms (36.4 MiB/s)
append: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 memtype=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x03100000 nvdumper_reserved=0x2772e0000 gpt tegra_fbmem2=0x800000@0x969ec000 lut_mem2=0x2008@0x969e9000 tegraid=18.1.2.0.0 tegra_keep_boot_clocks maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2.1 androidboot.serialno=0322017038084 bl_prof_dataptr=0x10000@0x277040000 sdhci_tegra.en_boot_part_access=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4
Retrieving file: /boot/tegra186-quill-p3310-1000-c03-00-base.dtb
279208 bytes read in 63 ms (4.2 MiB/s)
Flattened Device Tree blob at 82200000
Booting using the fdt blob at 0x82200000
reserving fdt memory region: addr=80000000 size=10000
Using Device Tree in place at 0000000082200000, end 00000000822472a7
WARNING: could not set reg FDT_ERR_NOSPACE.
ERROR: arch-specific fdt fixup failed
- must RESET the board to recover.
