Iam controlling 2 i2c oled displays from jetson nano using 2 seperate i2c busses (i2c-0 and i2c-1).
The clock speed was slow so i increased it by doing cd /sys/bus/i2c/devices/i2c-0 and i2c-1 and a
sudo nano bus_clk_rate and change it to 1000000.
And it works fine, but the problem is every time i reboot the system the value in bus_clk_rate returns to its orginial value.
How can i make it permanent?
Thank you
