Hello everyone,
I am running the DetectNet application https://github.com/dusty-nv/jetson-inference
with SSD-Mobilenet-v2 model. I would like to modify the code little bit. As you know, DetectNet uses “bounding box” for identifying the detection on the display.
The related function is
bool detectNet::Overlay(float* input, float* output, uint32_t width, uint32_t height, Detection* detections, uint32_t numDetections, uint32_t flags )
in detectNet.cpp. It is then linked it to cudaDetectionOverlay function, in detectNet.cu.
The result shows like:
I would like to have only border in my bounding box; instead of covering the detectnet object with color (based on the detected class). Something like that:
There are several options when you run the program with console commands, such as: – output_cvg and – output_bbox. However, I couldn’t find how to set an argument according to my need.
Do you have any idea how I can achieve that? only way it to modify “gpuDetectionOverlay” function ?
Thank you
