I’m guessing you haven’t informed it to only fetch byte (8bit) data, so it’s grabbing 32bits at a time instead. When you bind the texture, try something like:
[indent]cudaBindTexture(0, tex, charBuf, cudaCreateChannelDesc(8, 0, 0, 0, cudaChannelFormatKindUnsigned), BUFSIZE);[/indent]
where charBuf is a pointer to the char buffer, and BUFSIZE is the count of bytes in the buffer. Use “cudaChannelFormatKindSigned” if you really want signed “char” types rather than unsigned.
