Hi
I encountered the following error after launching Chat with RTX, does anyone know how to fix it?
gradio.exceptions.Error: ‘Invalid session’
System Information
RTX4080
Driver Version: 551.23
Here is the full error log for your reference:
Environment path found: C:\Users\lzlal\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag
App running with config
"models": {
"supported": [
"name": "Mistral 7B int4",
"installed": true,
"metadata": {
"model_path": "model\\mistral\\mistral7b_int4_engine",
"engine": "llama_float16_tp1_rank0.engine",
"tokenizer_path": "model\\mistral\\mistral7b_hf",
"max_new_tokens": 1024,
"max_input_token": 7168,
"temperature": 0.1
"name": "Llama 2 13B int4",
"installed": false,
"metadata": {
"model_path": "model\\llama\\llama13_int4_engine",
"tokenizer_path": "model\\llama\\llama13_hf",
"max_input_token": 3900,
"temperature": 0.1
"selected": "Mistral 7B int4"
"sample_questions": [
"query": "How does NVIDIA ACE generate emotional responses?"
"query": "What is Portal prelude RTX?"
"query": "What is important about Half Life 2 RTX?"
"query": "When is the launch date for Ratchet & Clank: Rift Apart on PC?"
"dataset": {
"sources": [
"directory",
"youtube",
"nodataset"
"selected": "directory",
"path": "dataset",
"isRelative": true
"strings": {
"directory": "Folder Path",
"youtube": "YouTube URL",
"nodataset": "AI model default"
[02/15/2024-00:15:55] No sentence-transformers model found with name C:\Users\lzlal/.cache\torch\sentence_transformers\WhereIsAI_UAE-Large-V1. Creating a new one with MEAN pooling.
Using the persisted value form dataset_vector_embedding
The file at ./config/preferences.json does not exist.
Open http://127.0.0.1:5424?cookie=a2b7100d-4a19-4a41-b78b-8fe861f9504a&__theme=dark in browser to start Chat with RTX
Running on local URL: http://127.0.0.1:5424
To create a public link, set `share=True` in `launch()`.
File "C:\Users\lzlal\AppData\Local\NVIDIA\ChatWithRTX\RAG\trt-llm-rag-windows-main\ui\user_interface.py", line 596, in _validate_session_and_raise
self._validate_request(request)
File "C:\Users\lzlal\AppData\Local\NVIDIA\ChatWithRTX\RAG\trt-llm-rag-windows-main\ui\user_interface.py", line 298, in _validate_request
key, value = cookie.split('=')
ValueError: too many values to unpack (expected 2)
During handling of the above exception, another exception occurred:
File "C:\Users\lzlal\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\gradio\queueing.py", line 495, in call_prediction
output = await route_utils.call_process_api(
File "C:\Users\lzlal\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\gradio\route_utils.py", line 232, in call_process_api
output = await app.get_blocks().process_api(
File "C:\Users\lzlal\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\gradio\blocks.py", line 1561, in process_api
result = await self.call_function(
File "C:\Users\lzlal\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\gradio\blocks.py", line 1179, in call_function
prediction = await anyio.to_thread.run_sync(
File "C:\Users\lzlal\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\anyio\to_thread.py", line 33, in run_sync
return await get_asynclib().run_sync_in_worker_thread(
File "C:\Users\lzlal\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\anyio\_backends\_asyncio.py", line 877, in run_sync_in_worker_thread
return await future
File "C:\Users\lzlal\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\anyio\_backends\_asyncio.py", line 807, in run
result = context.run(func, *args)
File "C:\Users\lzlal\AppData\Local\NVIDIA\ChatWithRTX\env_nvd_rag\lib\site-packages\gradio\utils.py", line 678, in wrapper
response = f(*args, **kwargs)
File "C:\Users\lzlal\AppData\Local\NVIDIA\ChatWithRTX\RAG\trt-llm-rag-windows-main\ui\user_interface.py", line 598, in _validate_session_and_raise
raise gr.Error('Invalid session')
gradio.exceptions.Error: 'Invalid session'
return await future
