Clang12 is not able to compile a simple test program with CUDA11.4.3 on Ubuntu20.04.3 LTS on WSL
I’m trying to build my C++ CMake project using Clang-12 instead of GCC-10 but compilation breaks on the stage of trying to compile simple program with error
Building CUDA object CMakeFiles/cmTC_101e9.dir/main.cu.o
    /usr/local/cuda-11.4//bin/nvcc -forward-unknown-to-host-compiler -ccbin=/usr/bin/clang++-12   -std=c++17 -MD -MT CMakeFiles/cmTC_101e9.dir/main.cu.o -MF CMakeFiles/cmTC_101e9.dir/main.cu.o.d -x cu -c /path_to_my_proj/CMakeFiles/CMakeTmp/main.cu -o CMakeFiles/cmTC_101e9.dir/main.cu.o
    /usr/bin/../lib/gcc/x86_64-linux-gnu/10/../../../../include/c++/10/ext/numeric_traits.h(70): error: qualified name is not allowed
    /usr/bin/../lib/gcc/x86_64-linux-gnu/10/../../../../include/c++/10/ext/numeric_traits.h(72): error: expected a "("
    /usr/bin/../lib/gcc/x86_64-linux-gnu/10/../../../../include/c++/10/ext/numeric_traits.h(72): error: expected a type specifier
    /usr/bin/../lib/gcc/x86_64-linux-gnu/10/../../../../include/c++/10/ext/numeric_traits.h(72): error: expected a ")"
    /usr/bin/../lib/gcc/x86_64-linux-gnu/10/../../../../include/c++/10/ext/numeric_traits.h(76): error: expected a "("
    /usr/bin/../lib/gcc/x86_64-linux-gnu/10/../../../../include/c++/10/ext/numeric_traits.h(76): error: expected a type specifier
    /usr/bin/../lib/gcc/x86_64-linux-gnu/10/../../../../include/c++/10/ext/numeric_traits.h(77): error: expected a ";"
    /usr/bin/../lib/gcc/x86_64-linux-gnu/10/../../../../include/c++/10/ext/numeric_traits.h(78): error: expected a "("
    /usr/bin/../lib/gcc/x86_64-linux-gnu/10/../../../../include/c++/10/ext/numeric_traits.h(78): error: expected a ";"
    /usr/bin/../lib/gcc/x86_64-linux-gnu/10/../../../../include/c++/10/ext/numeric_traits.h(88): error: class template "__gnu_cxx::__numeric_traits_integer<_Value>" has no member "__is_signed"
    10 errors detected in the compilation of "/path_to_my_proj/CMakeFiles/CMakeTmp/main.cu".
I am using CUDA 11.4.3 on Ubuntu 20.04.3 LTS on WSL. I saw in documentation Installation Guide Linux :: CUDA Toolkit Documentation that Clang 12 is a supported compiler for this version of Ubuntu. Can you help me, please, to fix my build with Clang12?
Thank you for bringing this to our attention.
Please follow the instructions here to file a bug report against NVCC.
Please include all verbose output and intermediate files, generated by adding ‘-v -keep’ to the nvcc command line, in your bug report.
I also encountered the same problem, how to solve it?
