Clarification on the accumulator layout in an mma instruction
I’m looking at the documentation on MMA instructions from GTC 2020:
And I just want to confirm that in this example T0 (in the accumulator), is storing
  • 2 elements corresponding to (row 0 x column 1, row 0 x column 2)
  • 2 elements corresponding to (row 9 x column 1, row 9 x column 2)
Seems obvious, but worth double-checking this type of thing
I guess by accumulator you mean result. T0 means thread 0.
It looks to me like row 0 column 0 and 1, and row 8 column 0 and 1
I assume you are looking for 0-based indexing since you mention row 0.
You should be able to double-check it in the “actual” documentation, the PTX guide.
