Understand the mma instruction in PTX
Hello, I’m studying the mma instruction in PTX. And I found the code below which runs correctly. However I can not understand why.
asm volatile(
    "mma.sync.aligned.m16n8k8.row.col.f32.tf32.tf32.f32 "
    "{%0,%1,%2,%3}, {%4,%5,%6,%7}, {%8,%9}, {%10,%11,%12,%13};\n"
    : "=f"(C[cd[0]]),                                     // D[0]   32bit
      "=f"(C[cd[1]]),                                     // D[1]
      "=f"(C[cd[2]]),                                     // D[2]
      "=f"(C[cd[3]])                                      // D[3]
    : "r"(*reinterpret_cast<uint32_t const *>(&A[a[0]])), // A[0]   32bit
      "r"(*reinterpret_cast<uint32_t const *>(&A[a[1]])), // A[1]
      "r"(*reinterpret_cast<uint32_t const *>(&A[a[2]])), // A[2]
      "r"(*reinterpret_cast<uint32_t const *>(&A[a[3]])), // A[3]
      "r"(*reinterpret_cast<uint32_t const *>(&B[b[0]])), // B[0]
      "r"(*reinterpret_cast<uint32_t const *>(&B[b[1]])), // B[1]
      "f"(C[cd[0]]),                                      // C[0]
      "f"(C[cd[1]]),                                      // C[1]
      "f"(C[cd[2]]),                                      // C[2]
      "f"(C[cd[3]])                                       // C[3]
// a b cd store the current index of Matrix A B and CD
  1. It ueses mma.sync.aligned.m16n8k8.row.col.f32.tf32.tf32.f32 instruction. I understand that it should use "f" in PTX code due to f32. However why A and B is "r" in PTX code? Shouldn’t it be of type .b32 due to tf32? PTX document says that " A register variable containing tf32 data must be declared with .b32 type.".
  2. how to understand *reinterpret_cast<uint32_t const *>(&A[a[0]])? I do not understand why it use & and reinterpret_cast?
  3. In PTX document, I don’t find the syntax "f" "r". Where can I get the syntax reference?
*reinterpret_cast<uint32_t const *>(&A[a[0]]) is standard c++. “treat the element A[a[0]] as uint32_t, and load it”
“h” = .u16 reg
“r” = .u32 reg
“l” = .u64 reg
“f” = .f32 reg
“d” = .f64 reg
wow~ thank you for your excellent answer!
wwa or mma?
sorry for the typo… I already correct it. Thanks~
