Hi everyone,
I wanted to flag a compatibility issue I ran into today when using Claude Code CLI (latest version) with vLLM serving as an Anthropic-compatible backend on my DGX Spark.
The problem
After Claude Code auto-updated to v2.1.154 (and later), every prompt fails with a 400 Bad Request from vLLM:
API Error: 400 54 validation errors:
{‘type’: ‘literal_error’, ‘loc’: (‘body’, ‘messages’, 1, ‘role’),
‘msg’: “Input should be ‘user’ or ‘assistant’”, ‘input’: ‘system’}
Root cause
Recent Claude Code versions (>= 2.1.154) started sending additional message roles (system, ctx, msg) inside the messages array of the Anthropic Messages API. vLLM’s Anthropic protocol strictly validates roles as only user or assistant, so these requests get rejected before any inference happens.
My setup
- DGX Spark (GB10)
- vLLM with Anthropic-compatible /v1/messages endpoint
- Claude Code CLI via ANTHROPIC_BASE_URL pointing to local vLLM
Workaround that worked for me
Downgrade Claude Code to v2.1.153 (last version before the breaking change). The official install script always pulls latest, so here’s a manual install script:
#!/bin/bash
set -e
VERSION=“2.1.153”
PLATFORM=“linux-arm64” # adjust: linux-x64, darwin-arm64, etc.
CHECKSUM=“6277fbbea72228a069e4719fc3e5fa36f16749247a2321c520dae93e83e92d9c”
URL=“https://downloads.claude.ai/claude-code-releases”
curl -fsSL -o /tmp/claude “$URL/$VERSION/$PLATFORM/claude”
echo “$CHECKSUM /tmp/claude” | sha256sum -c -
chmod +x /tmp/claude
/tmp/claude install
rm -f /tmp/claude
Note: Claude Code auto-updates by default. To stay on 2.1.153, set “autoUpdate”: false in ~/.config/claude/settings.json.
Long-term fix
The proper fix is on the vLLM side — either expanding the allowed role enum or normalizing these non-standard roles before validation. There’s an open issue tracking this: [Bug]: Claude Code CLI >= 2.1.154 sends ctx/msg/system roles and breaks vLLM Anthropic Messages API validation · Issue #44000 · vllm-project/vllm · GitHub
Hope this saves someone a few hours of debugging! Let me know if anyone has a cleaner solution or a vLLM patch that handles this properly.
