Cluster siliarity calculated with usage of array reduction optimization
My previous question and details: Cluster of points similarity calculation
I’ve managed to do new implementation which is far more powerful, however, not enough. I would like any advice for making my kernel run faster.
Kernel call
float solveGPU(clusterA, clusterB, int n) {
    float *hostOutput;
    float *deviceOutput;
    int blockSize;
    int minGridSize;
    int gridSize;
    //use cuda occupancy calculator to determine grid and block sizes
    gpuSafeExec(cudaOccupancyMaxPotentialBlockSize( &minGridSize, &blockSize,
                                       cluster_similarity_reduction, 0, 0));
    //determine correct number of output elements after reduction
    int numOutputElements = n / (blockSize / 2);
    if (n % (blockSize / 2)) {
        numOutputElements++;
    hostOutput = (float *)malloc(numOutputElements * sizeof(float));
    // Round up according to array size
    gridSize = (n + blockSize - 1) / blockSize;
    //allocate GPU memory
    gpuSafeExec(cudaMalloc((void **)&deviceOutput, numOutputElements * sizeof(float)));
    cluster_similarity_reduction <<<gridSize, blockSize, blockSize*sizeof(float) >>>(A, B, n, deviceOutput, blockSize);
    //move GPU results to CPU via PCIe
    gpuSafeExec(cudaMemcpy(hostOutput, deviceOutput, numOutputElements * sizeof(float), cudaMemcpyDeviceToHost));
    //accumulate the sum in the first element
    for (int i = 1; i < numOutputElements; i++) {
        hostOutput[0] += hostOutput[i];
    //use overall square root out of GPU, to avoid race condition
    float retval = sqrt(1/((float)n*((float)n-1)) * hostOutput[0]);
    //cleanup
    gpuSafeExec(cudaFree(deviceOutput));
    free(hostOutput);
    return retval;
Kernel:
__global__ void cluster_similarity_reduction(const sGalaxy A, const sGalaxy B, const int n , float* output, int shmemSize) {
    extern __shared__ float sdata[];
    unsigned int tid = threadIdx.x;
    unsigned int i = blockIdx.x * blockDim.x + threadIdx.x;
    //clear SHMEM
    if (tid == 0)
        flushShmem(sdata, shmemSize);
    //wait for shem flush
    __syncthreads();
    //do the math
    for(int j = i+1; j < n; j++){
        float da = sqrt((A.x[i]-A.x[j])*(A.x[i]-A.x[j])
                    + (A.y[i]-A.y[j])*(A.y[i]-A.y[j])
                    + (A.z[i]-A.z[j])*(A.z[i]-A.z[j]));
        float db = sqrt((B.x[i]-B.x[j])*(B.x[i]-B.x[j])
                    + (B.y[i]-B.y[j])*(B.y[i]-B.y[j])
                    + (B.z[i]-B.z[j])*(B.z[i]-B.z[j]));
       //float da = norm3df(A.x[i]-A.x[j], A.y[i]-A.y[j], A.z[i]-A.z[j]);
      // float db = norm3df(B.x[i]-B.x[j], B.y[i]-B.y[j], B.z[i]-B.z[j]);
        sdata[tid] += (da-db) * (da-db);
    __syncthreads();
    for (unsigned int s = 1; s < blockDim.x; s *= 2) {
        if (tid % (2 * s) == 0) {
            sdata[tid] += sdata[tid + s];
        __syncthreads();
    //write result of this block to global memory
    if (tid == 0) output[blockIdx.x] = sdata[0];
I’m thinking of the inner for loop that goes within each thread. Size n is approximately 50 - 100k, which means that kernels with low index i have to traverse much larger loop as opposite to those that have index i closer to the n value. This results in threads that are doing much smaller loop traverse will have to wait afterwards because of __syncthreads().
Note: This is just my thought, but I think this could be done much more efficient way, I’m just not sure how this could be achieved.
From a higher level, this looks as if you have a triangular N x N matrix, and you want to perform a sum reduction over all its elements. Is this correct?
The matrix is actually 3 x N if I’m correct.
struct Cluster{
	float* x;
	float* y;
	float* z;
This defines one cluster. Which is constructed by array of points, constructed by:
void populateClusters(Cluster A, Cluster B, int n) {
	for (int i = 0; i < n; i++) {
		A.x[i] = 1000.0f * (float)rand() / (float)RAND_MAX;
		A.y[i] = 1000.0f * (float)rand() / (float)RAND_MAX;
		A.z[i] = 1000.0f * (float)rand() / (float)RAND_MAX;
		if ((float)rand() / (float)RAND_MAX < 0.01f) {
			B.x[i] = A.x[i] + 10.0f * (float)rand() / (float)RAND_MAX;
			B.y[i] = A.y[i] + 10.0f * (float)rand() / (float)RAND_MAX;
			B.z[i] = A.z[i] + 10.0f * (float)rand() / (float)RAND_MAX;
		else {
            B.x[i] = A.x[i] + 1.0f * (float)rand() / (float)RAND_MAX;
            B.y[i] = A.y[i] + 1.0f * (float)rand() / (float)RAND_MAX;
            B.z[i] = A.z[i] + 1.0f * (float)rand() / (float)RAND_MAX;
So if I’m correct, height of the matrix is x + z + y coordinates = 3 and width of the matrix is N
EDIT: Actually as I’m looking towards the computation it might very well be triangular matrix, since inner loop j is starting from i + 1 towards N. I did not think about it this way.
Triangular matrix elements can be enumerated with a linear index. With the correct index transformation, your problem could be solved with thrust::transform_reduce like this
//nvcc --expt-relaxed-constexpr -O0 -g -std=c++17 triangular.cu -o triangular
#include <thrust/iterator/counting_iterator.h>
#include <thrust/iterator/transform_iterator.h>
#include <thrust/transform_reduce.h>
#include <thrust/functional.h>
#include <iostream>
#include <cmath>
struct MatrixIndex{
    int i = 0;
    int j = 0;
std::ostream& operator<<(std::ostream& os, const MatrixIndex& m){
    os << "(" << m.i << "," << m.j << ")";
    return os;
struct ConvertLinearIndexToTriangularMatrixIndex{
    int dim;
    __host__ __device__
    ConvertLinearIndexToTriangularMatrixIndex(int dimension) : dim(dimension){}
    __host__ __device__
    MatrixIndex operator()(int linear) const {
        MatrixIndex result;
       //check if those indices work for you
        //compute i and j from linear index https://stackoverflow.com/questions/27086195/linear-index-upper-triangular-matrix
        result.i = dim - 2 - floor(sqrt(-8*linear + 4*dim*(dim-1)-7)/2.0 - 0.5);
        result.j = linear + result.i + 1 - dim*(dim-1)/2 + (dim-result.i)*((dim-result.i)-1)/2;
        return result;
struct ComputeDelta{
    //A_type A
    //B_type B
    __host__ __device__
    ComputeDelta(/* init A and B*/){
        /* init A and B*/
    __host__ __device__
    float operator()(const MatrixIndex& index) const{
        float da = 0;
        float db = 0;
        //... compute da, db from index.i, index.j
        return (da-db) * (da-db);
int main(){
    const int dim = 5;
    const int elems = 10; //upper triangular matrix with dim 5 without diagonal has 10 elements
    auto matrixIndexIterator = thrust::make_transform_iterator(
        thrust::make_counting_iterator(0),
        ConvertLinearIndexToTriangularMatrixIndex{dim}
    for(int i = 0; i < elems; i++){
        std::cout << matrixIndexIterator[i] << " ";
    std::cout << "\n";
    float result = thrust::transform_reduce(
        thrust::host,
        matrixIndexIterator,
        matrixIndexIterator + elems,
        ComputeDelta{},
        float(0),
        thrust::plus<float>{}
    return 0;
Hello, thank you for your advice. I have implemented your suggestion with triangular matrix reduction and it indeed works! The only problem I have is, is performance measured by the test framework is measured 10 times worse than mine.
int main(int argc, char **argv){
	Cluster A, B;
	A.x = A.y = A.z = B.x = B.y = B.z = NULL;
	Cluster dA, dB;
	dA.x = dA.y = dA.z = dB.x = dB.y = dB.z = NULL;
	float diff_CPU, diff_GPU;
	// parse command line
	int device = 0;
	if (argc == 2)
		device = atoi(argv[1]);
	if (cudaSetDevice(device) != cudaSuccess){
		fprintf(stderr, "Cannot set CUDA device!\n");
		exit(1);
	printf("Number of points per cluster: %d\n", N);
	cudaDeviceProp deviceProp;
    cudaGetDeviceProperties(&deviceProp, device);
    printf("Using device %d: \"%s\"\n", device, deviceProp.name);
	//printf("%d \n",*deviceProp.maxGridSize);
	// create events for timing
	cudaEvent_t start, stop;
    cudaEventCreate(&start);
    cudaEventCreate(&stop);
	// allocate and set host memory
	A.x = (float*)malloc(N*sizeof(A.x[0]));
	A.y = (float*)malloc(N*sizeof(A.y[0]));
	A.z = (float*)malloc(N*sizeof(A.z[0]));
	B.x = (float*)malloc(N*sizeof(B.x[0]));
    B.y = (float*)malloc(N*sizeof(B.y[0]));
    B.z = (float*)malloc(N*sizeof(B.z[0]));
	generateGalaxies(A, B, N);
	// allocate and set device memory
	if (cudaMalloc((void**)&dA.x, N*sizeof(dA.x[0])) != cudaSuccess
	|| cudaMalloc((void**)&dA.y, N*sizeof(dA.y[0])) != cudaSuccess
	|| cudaMalloc((void**)&dA.z, N*sizeof(dA.z[0])) != cudaSuccess
	|| cudaMalloc((void**)&dB.x, N*sizeof(dB.x[0])) != cudaSuccess
    || cudaMalloc((void**)&dB.y, N*sizeof(dB.y[0])) != cudaSuccess
    || cudaMalloc((void**)&dB.z, N*sizeof(dB.z[0])) != cudaSuccess) {
		fprintf(stderr, "Device memory allocation error!\n");
		cudaError_t err = cudaGetLastError();
		if (err != cudaSuccess){
			printf("CUDA ERROR while executing the kernel: %s\n",cudaGetErrorString(err));
			return 103;
		goto cleanup;
	cudaMemcpy(dA.x, A.x, N*sizeof(dA.x[0]), cudaMemcpyHostToDevice);
	cudaMemcpy(dA.y, A.y, N*sizeof(dA.y[0]), cudaMemcpyHostToDevice);
	cudaMemcpy(dA.z, A.z, N*sizeof(dA.z[0]), cudaMemcpyHostToDevice);
	cudaMemcpy(dB.x, B.x, N*sizeof(dB.x[0]), cudaMemcpyHostToDevice);
    cudaMemcpy(dB.y, B.y, N*sizeof(dB.y[0]), cudaMemcpyHostToDevice);
    cudaMemcpy(dB.z, B.z, N*sizeof(dB.z[0]), cudaMemcpyHostToDevice);
	// solve on CPU
    printf("Solving on CPU...\n");
	cudaEventRecord(start, 0);
	diff_CPU = solveCPU(A, B, N);
	cudaEventRecord(stop, 0);
    cudaEventSynchronize(stop);
    float time;
    cudaEventElapsedTime(&time, start, stop);
    printf("CPU performance: %f megapairs/s\n",
        float(N)*float(N-1)/2.0f/time/1e3f);
	// solve on GPU
	printf("Solving on GPU...\n");
	// run it 10x for more accurately timing results
    for (int i = 0; i < 10; i++){
		diff_GPU = solveGPU(dA, dB, N);
	printf("GPU performance: %f megapairs/s\n",
        float(N)*float(N-1)/2.0f/time/1e2f);
	printf("CPU diff: %f\nGPU diff: %f\n", diff_CPU, diff_GPU);
	// check GPU results
	if ( fabsf((diff_CPU-diff_GPU) / ((diff_CPU+diff_GPU)/2.0f)) < 0.01f)
		printf("Test OK :-).\n");
	else
		 fprintf(stderr, "Data mismatch: %f should be %f :-(\n", diff_GPU, diff_CPU);
cleanup:
	cudaEventDestroy(start);
    cudaEventDestroy(stop);
	if (dA.x) cudaFree(dA.x);
	if (dA.y) cudaFree(dA.y);
	if (dA.z) cudaFree(dA.z);
	if (dB.x) cudaFree(dB.x);
    if (dB.y) cudaFree(dB.y);
    if (dB.z) cudaFree(dB.z);
	if (A.x) free(A.x);
	if (A.y) free(A.y);
	if (A.z) free(A.z);
	if (B.x) free(B.x);
    if (B.y) free(B.y);
    if (B.z) free(B.z);
	return 0;
Results
your solution:
Number of points per cluster: 20000
Using device 0: "NVIDIA GeForce RTX 3060 Laptop GPU"
Solving on CPU...
CPU performance: 372.284668 megapairs/s
Solving on GPU...
GPU performance: 5470.582520 megapairs/s
CPU diff: 0.614017
GPU diff: 0.614017
Test OK :-).
My previous solution:
Solving on CPU...
Solving on GPU...
GPU performance: 55321.232770 megapairs/s
CPU diff: 0.614017
GPU diff: 0.614017
Test OK :-).
I don’t think my solution should be faster any ideas?
This is current code with triangular reduction
#include <iostream>
    Ensures safe cuda application executions
#define gpuSafeExec(ans) { gpuAssert((ans), __FILE__, __LINE__); }
inline void gpuAssert(cudaError_t code, const char *file, int line, bool abort=true)
   if (code != cudaSuccess)
      fprintf(stderr,"GPUassert: %s %s %d\n", cudaGetErrorString(code), file, line);
      if (abort) exit(code);
    Clears shared memory which is not full of previous
    numbers. Shmem is remembers values between consecutive
    kernel calls.
__device__ void flushShmem(float *shmem, int shmemSize){
    for (int i = 0; i < shmemSize; i ++)
        shmem[i] = 0.0f;
    return;
struct MatrixIndex{
    int i = 0;
    int j = 0;
    return os;
    int dim;
    __host__ __device__
    __host__ __device__
        MatrixIndex result;
        return result;
    Cluster A;
    Cluster B;
    __host__ __device__
    ComputeDelta(Cluster _A, Cluster _B){
        /* init A and B*/
        A = _A;
        B = _B;
    __host__ __device__
        float da = 0;
        float db = 0;
        da = sqrt((A.x[index.i]-A.x[index.j])*(A.x[index.i]-A.x[index.j])
                    + (A.y[index.i]-A.y[index.j])*(A.y[index.i]-A.y[index.j])
                    + (A.z[index.i]-A.z[index.j])*(A.z[index.i]-A.z[index.j]));
        db = sqrt((B.x[index.i]-B.x[index.j])*(B.x[index.i]-B.x[index.j])
                    + (B.y[index.i]-B.y[index.j])*(B.y[index.i]-B.y[index.j])
                    + (B.z[index.i]-B.z[index.j])*(B.z[index.i]-B.z[index.j]));
float solveGPU(Cluster A, Cluster B, int n) {
    const int dim = n;
    const int elems = round(n*(n-1)/2); //upper triangular(without diagonal) number of elements formula
    //for(int i = 0; i < elems; i++){
    //    std::cout << matrixIndexIterator[i] << " ";
        ComputeDelta{A,B},
        float(0),
    return sqrt(1/((float)n*((float)n-1)) * result);
Also the int elements is overflowing for higher number I should use long int instead I guess.
You could use a profiler to figure out why there is a time difference.
Your kernel shared memory reduction does not work correctly. On Volta with blocksize 768, this causes illegal memory access. When I use cub::BlockReduce instead, I observe the following timings for 20000 points per cluster
Titan Xp
GPU performance with cub blockreduce: 18895.519531 megapairs/s
GPU performance with thrust: 13188.617188 megapairs/s
V100
GPU performance with cub blockreduce: 42709.398438 megapairs/s
GPU performance with thrust: 66447.367188 megapairs/s
A100
GPU performance with cub blockreduce: 52642.734375 megapairs/s
GPU performance with thrust: 127284.359375 megapairs/s
I cannot explain why thrust is slower in some cases.
Full source:
#include <iostream>
#include <cub/cub.cuh>
    kernel calls.
        shmem[i] = 0.0f;
    return;
struct Cluster{
	float* x;
	float* y;
	float* z;
		else {
struct MatrixIndex{
    int i = 0;
    int j = 0;
    return os;
    int dim;
    __host__ __device__
    __host__ __device__
        MatrixIndex result;
        return result;
    Cluster A;
    Cluster B;
    __host__ __device__
        /* init A and B*/
        A = _A;
        B = _B;
    __host__ __device__
        float da = 0;
        float db = 0;
float solveGPU_thrust(Cluster A, Cluster B, int n) {
    const int dim = n;
        ComputeDelta{A,B},
        float(0),
__global__ void cluster_similarity_reduction(const Cluster A, const Cluster B, const int n , float* output, int shmemSize) {
    //clear SHMEM
    if (tid == 0)
    __syncthreads();
    //do the math
    __syncthreads();
        __syncthreads();
float solveGPU(Cluster clusterA, Cluster clusterB, int n) {
    float *hostOutput;
    int blockSize;
    int minGridSize;
    int gridSize;
    //std::cerr << "cluster_similarity_reduction<<<" << gridSize << "," << blockSize << "," << blockSize*sizeof(float) << ">>>\n";
    cluster_similarity_reduction <<<gridSize, blockSize, blockSize*sizeof(float) >>>(clusterA, clusterB, n, deviceOutput, blockSize);
    //cleanup
    free(hostOutput);
    return retval;
template<int blocksize>
__global__ void cluster_similarity_reduction_cubreduce(const Cluster A, const Cluster B, const int n , float* output, int shmemSize) {
    //do the math
    float mysum = 0.0f;
        mysum += (da-db) * (da-db);
    using BlockReduce = cub::BlockReduce<float, blocksize>;
    __shared__ typename BlockReduce::TempStorage tmp;
    float sum = BlockReduce(tmp).Sum(mysum);
    if (threadIdx.x == 0){
        output[blockIdx.x] = sum;
float solveGPU_cubblockreduce(Cluster clusterA, Cluster clusterB, int n) {
    float *hostOutput;
    int gridSize;
    constexpr int blockSize = 256;
    auto kernel = cluster_similarity_reduction_cubreduce<blockSize>;
    int deviceId = 0;
    int numSMs = 0;
    int maxBlocksPerSM = 0;
    gpuSafeExec(cudaGetDevice(&deviceId));
    gpuSafeExec(cudaDeviceGetAttribute(&numSMs, cudaDevAttrMultiProcessorCount, deviceId));
    gpuSafeExec(cudaOccupancyMaxActiveBlocksPerMultiprocessor(
        &maxBlocksPerSM,
        kernel,
        blockSize,
        0
    //std::cerr << "cluster_similarity_reduction_cubreduce<<<" << gridSize << "," << blockSize << "," << 0 << ">>>\n";
    kernel<<<gridSize, blockSize, 0 >>>(clusterA, clusterB, n, deviceOutput, blockSize);
    //cleanup
    free(hostOutput);
    return retval;
float solveCPU(Cluster A, Cluster B, int n) {
	float difference = 0.0f;
	for (int i = 0; i < n-1; i++) {
		float tmp = 0.0f;
		for (int j = i+1; j < n; j++) {
			float diff_a = sqrt((A.x[i]-A.x[j])*(A.x[i]-A.x[j])
			float diff_b = sqrt((B.x[i]-B.x[j])*(B.x[i]-B.x[j])
			tmp += (diff_a-diff_b) * (diff_a-diff_b);
		difference += tmp;
	return sqrt(1/((float)n*((float)n-1)) * difference);
    constexpr int N = 20000;
	Cluster A, B;
	Cluster dA, dB;
	int device = 0;
	if (argc == 2)
		exit(1);
	populateClusters(A, B, N);
			return 103;
		goto cleanup;
	// solve on CPU
    float time;
	// solve on GPU
    #if 0
	printf("Solving on GPU with default kernel...\n");
	else
    #endif
    // solve on GPU with cub block reduce
	printf("Solving on GPU with cub block reduce kernel...\n");
		diff_GPU = solveGPU_cubblockreduce(dA, dB, N);
	printf("GPU performance with cub blockreduce: %f megapairs/s\n",
	else
    // solve on GPU
	printf("Solving on GPU with thrust...\n");
		diff_GPU = solveGPU_thrust(dA, dB, N);
	printf("GPU performance with thrust: %f megapairs/s\n",
	else
cleanup:
	if (A.x) free(A.x);
	if (A.y) free(A.y);
	if (A.z) free(A.z);
	if (B.x) free(B.x);
    if (B.y) free(B.y);
    if (B.z) free(B.z);
	return 0;
Thanks for your time to dive into this. Cube reduction is , indeed, slightly more optimized. I 've used your kernel thread / calculation for specific N, which is highest performance boost. Nvidia Nsight compute, still has problem with small grid and occupancy limiters. I’m not entirely sure why occupancy is only on 40% from theoretical 100%. Your solution helped me a bit for that I am thankful. For 50k points the results on referenced GPU shows around 45k megapairs. Optimization is required to run on at least 75k megapairs for 50k points. I am not entirely sure how could this be optimized further more. I will post nsight report if you have any further ideas I would be glad for them.
Thrust implementation, for some reason, does not calculate results for me.(but I do not understand this implementation, so for learning purpose I would rather use kernel calls that are much more readable
I guess your kernel has small occupancy because the 79*256 threads do not saturate the GPU.
There is no magic behind the thrust implementation. Take each number from 0 to elems - 1 (counting iterator), compute the coordinate pair (convert linear index), compute the squared difference for that coordinate pair (compute delta), and sum reduce all squared differences.
void cluster_similarity_reduction2(const Cluster A, const Cluster B, std::int64_t clusterDim , float* output){
    using Int_t = std::int64_t;
    const Int_t tid = Int_t(threadIdx.x) + Int_t(blockIdx.x) * Int_t(blockDim.x);
    const Int_t stride = Int_t(blockDim.x) * Int_t(gridDim.x);
    const Int_t numElementsToProcess = (clusterDim * (clusterDim-1)) / 2;
    float threadsum = 0.0f;
    for(Int_t x = tid; x < numElementsToProcess; x += stride){
        //compute cluster coordinates from x
        const Int_t i = clusterDim - 2 - floor(sqrt(-8*x + 4*clusterDim*(clusterDim-1)-7)/2.0 - 0.5);
        const Int_t j = x + i + 1 - clusterDim*(clusterDim-1)/2 + (clusterDim-i)*((clusterDim-i)-1)/2;
        //compute values
        const float da = sqrt((A.x[i]-A.x[j])*(A.x[i]-A.x[j])
        const float db = sqrt((B.x[i]-B.x[j])*(B.x[i]-B.x[j])
        const float diffSquared = (da-db) * (da-db);
        threadsum += diffSquared;
    float blocksum = BlockReduce(tmp).Sum(threadsum);
        output[blockIdx.x] = blocksum;
The reason that Thrust does not work with many points is indeed 32-bit integer overflow. You would need to use 64-bit numbers instead, like in above kernel.
I won’t spend more time on this problem.
