Hello there,
I am new to CUDA and CMake programming and set up my first project in Visual Studio.
project(cuNSearch LANGUAGES CXX CUDA)
# Visual studio solution directories.
set_property(GLOBAL PROPERTY USE_FOLDERS on)
set(CMAKE_CXX_STANDARD 11)
set(CMAKE_CXX_STANDARD_REQUIRED ON)
SET(CMAKE_DEBUG_POSTFIX "_d")
# CUDA
set (CUDA_HEADER_FILES
include/CuNSearch.cuh)
set (CUDA_SOURCE_FILES
src/CuNSearch.cu)
set (HEADER_FILES
include/Config.h
include/PointSet.h
include/ActivationTable.h
Utils/helper_cuda.h
Utils/helper_math.h
Utils/helper_string.h
Utils/Timing.h
Utils/IDFactory.h)
set (SOURCE_FILES
Utils/Timing.cpp
Utils/IDFactory.cpp)
file(GLOB CUDA_FILES "src/" *.cu)
include_directories(
"include"
"Utils"
${CUDA_INCLUDE_DIRS}
${CUDA_CUT_INCLUDE_DIR})
add_library(cuNSearch STATIC ${HEADER_FILES} ${SOURCE_FILES})
add_library(cudacuNSearch STATIC ${CUDA_HEADER_FILES} ${CUDA_SOURCE_FILES})
target_link_libraries(cudacuNSearch cudart ${CUDA_LIBRARIES})
set_target_properties( cudacuNSearch
PROPERTIES CUDA_SEPARABLE_COMPILATION ON)
PROPERTIES CUDA_RESOLVE_DEVICE_SYMBOLS ON)
target_link_libraries(cuNSearch cudacuNSearch)
install(FILES "include/cuNSearch" ${HEADER_FILES}
DESTINATION include/)
install(TARGETS cuNSearch
RUNTIME DESTINATION bin
LIBRARY DESTINATION lib
ARCHIVE DESTINATION lib)
option(BUILD_DEMO "Build example of how to use this library."
ON)
if(BUILD_DEMO)
add_subdirectory(demo)
endif(BUILD_DEMO)
string(APPEND CMAKE_CUDA_FLAGS " -gencode=arch=compute_50,code=sm_50 " )
include_directories("../include")
add_executable(Demo
main.cpp
target_link_libraries(Demo cuNSearch)
The code using seperable compilation compiles fine, but the linking with the executable throws the following error:
Error LNK2001 unresolved external symbol __fatbinwrap_66_tmpxft_000009c4_00000000_16_cuda_device_runtime_compute_70_cpp1_ii_8b1a5d37 Demo …\Desktop\Cunsearch\build\demo\cudacuNSearch.lib(cudacuNSearch.device-link.obj) 1
I hope that I provided all the necessary information.
CUDA 9.0
VS 15.4.4
Cmake 3.9.6
