Linking problems with cmake
I have a simple project written in CUDA to do simple calculations on a GPU. My project is structured like so:
…root/
…build/
…src/
…CMakeLists.txt
…main.cu
…cu/
…CMakeLists.txt
….cu
.cpp
…cuh/
….cuh
.h
When I compiled on the command line, I needed to include -dc flag to nvcc or else I get the following error:
ptxas fatal : Unresolved extern function ‘_ZN9potDriver15createPotDriverEi’
Now I’m trying to use cmake to do the same but I keep getting the same error above. Here is my root/src/CMakeLists.txt
CMAKE_MINIMUM_REQUIRED(VERSION 3.12 FATAL_ERROR)
#about this project
project(mcpc LANGUAGES CXX CUDA)
set(VERSION_MAJOR "0")
set(VERSION_MINOR "05")
set(VERSION "${VERSION_MAJOR}.${VERSION_MINOR}")
#setting the output directory
set(CMAKE_RUNTIME_OUTPUT_DIRECTORY ${CMAKE_BINARY_DIR}/bin)
#enabling C++11 flag
set(
 CUDA_NVCC_FLAGS
 ${CUDA_NVCC_FLAGS};
 -std=c++11
#I think I'm enabling seperable compilation
set(CUDA_ATTACH_VS_BUILD_RULE_TO_CUDA_FILE ON)
set(BUILD_SHARED_LIBS OFF)
set(CUDA_SEPARABLE_COMPILATION ON)
#set env
include_directories(${PROJECT_SOURCE_DIR}/cuh)
#add subfolders
add_subdirectory(cu)
add_executable(main.o ${PROJECT_SOURCE_DIR}/main.cu)
target_link_libraries(main.o cu cuCore)
and root/src/cu/CMakeLists.txt
add_library(cuCore STATIC
 test1.cpp
 test2.cu
 test3.cu
To compile I cd into my build directory and run
cmake …/src/
-bash-4.2$ cmake ../src
-- The CXX compiler identification is GNU 7.3.0
-- The CUDA compiler identification is NVIDIA 9.2.88
-- Check for working CXX compiler: /apps/gcc/7.3.0/bin/c++
-- Check for working CXX compiler: /apps/gcc/7.3.0/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Check for working CUDA compiler: /apps/cuda/9.2.88/bin/nvcc
-- Check for working CUDA compiler: /apps/cuda/9.2.88/bin/nvcc -- works
-- Detecting CUDA compiler ABI info
-- Detecting CUDA compiler ABI info - done
-- Configuring done
-- Generating done
-- Build files have been written to: /fslhome/pkawak/mcpc/build
make
ptxas fatal   : Unresolved extern function '_ZN9test315test3doEi'
make[2]: *** [cu/CMakeFiles/cuCore.dir/test2.cu.o] Error 255
make[1]: *** [cu/CMakeFiles/cuCore.dir/all] Error 2
make: *** [all] Error 2
Can anyone help? What am I doing wrong? Much appreciated!
Use one CMakeLists.txt file for the project, not two.
Do it in a way as in the following Working example:
https://stackoverflow.com/questions/13073717/building-cuda-object-files-using-cmake
Works via the macros provided in ‘FindCuda’ cmake file - especially the ‘cuda_compile’ macro.
Newer CMAKE versions have also ‘native’ CUDA support, see https://devblogs.nvidia.com/building-cuda-applications-cmake/
Thank you for your prompt answer HannesF99. I will attempt this.
Worked like a charm! I actually looked at that before but missed a few essential points due to novicity.
