Hi guys, i am newbie at TAO. I am using Jetson Nano and Jetpack version is 4.6. Cuda version is 10.2. Deepstream version 6.0. I try this sample app Pre-trained models - License Plate Detection (LPDNet) and Recognition (LPRNet) . In this section Convert the Models to TRT Engine i tried download tao-converter. After following steps i tried download cmake and tensorRT OSS from here . But in step 3 i got an error on below.
I tought problem is my TensorRT version which is 8.0.1. My question, is Jetpack 4.6 isnt compatitable with TensorRT 7.2 ? and how i solve this problem…
Thank you so much.
nano@nano-desktop:~/cmake-3.13.5/TensorRT/build$ /usr/local/bin/cmake .. -DGPU_ARCHS=53 -DTRT_LIB_DIR=/usr/lib/aarch64-linux-gnu/ -DCMAKE_C_COMPILER=/usr/bin/gcc -DTRT_BIN_DIR=`pwd`/out
Building for TensorRT version: 7.2.2, library version: 7
-- Targeting TRT Platform: x86_64
-- CUDA version set to 11.1
-- cuDNN version set to 8.0
-- Protobuf version set to 3.0.0
-- Setting up another Protobuf build for cross compilation targeting aarch64-Linux
-- Using libprotobuf /home/nano/cmake-3.13.5/TensorRT/build/third_party.protobuf_aarch64/lib/libprotobuf.a
-- ========================= Importing and creating target nvinfer ==========================
-- Looking for library nvinfer
-- Library that was found /usr/lib/aarch64-linux-gnu/libnvinfer.so
-- ========================= Importing and creating target nvuffparser ==========================
-- Looking for library nvparsers
-- Library that was found /usr/lib/aarch64-linux-gnu/libnvparsers.so
-- GPU_ARCHS defined as 53. Generating CUDA code for SM 53
-- Protobuf proto/trtcaffe.proto -> proto/trtcaffe.pb.cc proto/trtcaffe.pb.h
-- /home/nano/cmake-3.13.5/TensorRT/build/parsers/caffe
Generated: /home/nano/cmake-3.13.5/TensorRT/build/parsers/onnx/third_party/onnx/onnx/onnx_onnx2trt_onnx-ml.proto
Generated: /home/nano/cmake-3.13.5/TensorRT/build/parsers/onnx/third_party/onnx/onnx/onnx-operators_onnx2trt_onnx-ml.proto
-- ******** Summary ********
-- CMake version : 3.13.5
-- CMake command : /usr/local/bin/cmake
-- System : Linux
-- C++ compiler : /usr/bin/g++
-- C++ compiler version : 7.5.0
-- CXX flags : -Wno-deprecated-declarations -DBUILD_SYSTEM=cmake_oss -Wall -Wno-deprecated-declarations -Wno-unused-function -Wnon-virtual-dtor
-- Build type : Release
-- Compile definitions : _PROTOBUF_INSTALL_DIR=/home/nano/cmake-3.13.5/TensorRT/build/third_party.protobuf;ONNX_NAMESPACE=onnx2trt_onnx
-- CMAKE_PREFIX_PATH :
-- CMAKE_INSTALL_PREFIX : /usr/lib/aarch64-linux-gnu/..
-- CMAKE_MODULE_PATH :
-- ONNX version : 1.6.0
-- ONNX NAMESPACE : onnx2trt_onnx
-- ONNX_BUILD_TESTS : OFF
-- ONNX_BUILD_BENCHMARKS : OFF
-- ONNX_USE_LITE_PROTO : OFF
-- ONNXIFI_DUMMY_BACKEND : OFF
-- ONNXIFI_ENABLE_EXT : OFF
-- Protobuf compiler :
-- Protobuf includes :
-- Protobuf libraries :
-- BUILD_ONNX_PYTHON : OFF
-- Found TensorRT headers at /home/nano/cmake-3.13.5/TensorRT/include
-- Find TensorRT libs at /usr/lib/aarch64-linux-gnu/libnvinfer.so;/usr/lib/aarch64-linux-gnu/libnvinfer_plugin.so;TENSORRT_LIBRARY_MYELIN-NOTFOUND
-- Could NOT find TENSORRT (missing: TENSORRT_LIBRARY)
ERRORCannot find TensorRT library.
-- Adding new sample: sample_algorithm_selector
-- - Parsers Used: caffe
-- - InferPlugin Used: OFF
-- - Licensing: opensource
-- Adding new sample: sample_char_rnn
-- - Parsers Used: uff;caffe;onnx
-- Adding new sample: sample_dynamic_reshape
-- - Parsers Used: onnx
-- Adding new sample: sample_fasterRCNN
-- - InferPlugin Used: ON
-- Adding new sample: sample_googlenet
-- Adding new sample: sample_int8
-- Adding new sample: sample_int8_api
-- Adding new sample: sample_mlp
-- Adding new sample: sample_mnist
-- Adding new sample: sample_mnist_api
-- Adding new sample: sample_movielens
-- Adding new sample: sample_movielens_mps
-- Adding new sample: sample_nmt
-- - Parsers Used: none
-- Adding new sample: sample_onnx_mnist
-- Adding new sample: sample_plugin
-- Adding new sample: sample_reformat_free_io
-- Adding new sample: sample_ssd
-- Adding new sample: sample_uff_fasterRCNN
-- Adding new sample: sample_uff_maskRCNN
-- Adding new sample: sample_uff_mnist
-- Adding new sample: sample_uff_plugin_v2_ext
-- Adding new sample: sample_uff_ssd
-- Adding new sample: sample_onnx_mnist_coord_conv_ac
-- Adding new sample: trtexec
-- - Parsers Used: caffe;uff;onnx
CMake Error: The following variables are used in this project, but they are set to NOTFOUND.
Please set them or make sure they are set and tested correctly in the CMake files:
linked by target "nvonnxparser_static" in directory /home/nano/cmake-3.13.5/TensorRT/parsers/onnx
linked by target "nvonnxparser" in directory /home/nano/cmake-3.13.5/TensorRT/parsers/onnx
-- Configuring incomplete, errors occurred!
See also "/home/nano/cmake-3.13.5/TensorRT/build/CMakeFiles/CMakeOutput.log".
See also "/home/nano/cmake-3.13.5/TensorRT/build/CMakeFiles/CMakeError.log".
