• Hardware Platform (Jetson / GPU): 2 x GeForce RTX 2080 Ti
• DeepStream Version: 5.1
• TensorRT Version: TensorRT 7.2.1 for Linux and CUDA 11.1
• NVIDIA GPU Driver Version (valid for GPU only): 460.73.01
• Issue Type( questions, new requirements, bugs): question
I’ve run deepstream-test1 to verify that I installed DS 5.1 correctly.
I follow this guide to install the x86 TensorRT OSS Plugin but I got the following error:
$HOME/install/bin/cmake .. -DGPU_ARCHS=75 -DTRT_LIB_DIR=/usr/lib/x86_64-linux-gnu/ -DCMAKE_C_COMPILER=/usr/bin/gcc -DTRT_BIN_DIR=`pwd`/out
Building for TensorRT version: 7.0.0.1, library version: 7.0.0
-- Targeting TRT Platform: x86_64
-- GPU_ARCHS defined as 75. Generating CUDA code for SM 75
-- CUDA version set to 10.2
-- cuDNN version set to 7.6
-- Protobuf version set to 3.0.0
-- Using libprotobuf /home/minh/TensorRT/build/third_party.protobuf/lib/libprotobuf.a
-- ========================= Importing and creating target nvinfer ==========================
-- Looking for library nvinfer
-- Library that was found /usr/lib/x86_64-linux-gnu/libnvinfer.so
-- ========================= Importing and creating target nvuffparser ==========================
-- Looking for library nvparsers
-- Library that was found /usr/lib/x86_64-linux-gnu/libnvparsers.so
-- Protobuf proto/trtcaffe.proto -> proto/trtcaffe.pb.cc proto/trtcaffe.pb.h
-- /home/minh/TensorRT/build/parsers/caffe
Generated: /home/minh/TensorRT/build/parsers/onnx/third_party/onnx/onnx/onnx_onnx2trt_onnx-ml.proto
Generated: /home/minh/TensorRT/build/parsers/onnx/third_party/onnx/onnx/onnx-operators_onnx2trt_onnx-ml.proto
-- ******** Summary ********
-- CMake version : 3.19.4
-- CMake command : /home/minh/install/bin/cmake
-- System : Linux
-- C++ compiler : /usr/bin/g++
-- C++ compiler version : 7.5.0
-- CXX flags : -Wno-deprecated-declarations -DBUILD_SYSTEM=cmake_oss -Wall -Wno-deprecated-declarations -Wno-unused-function -Wnon-virtual-dtor
-- Build type : Release
-- Compile definitions : _PROTOBUF_INSTALL_DIR=/home/minh/TensorRT/build;ONNX_NAMESPACE=onnx2trt_onnx
-- CMAKE_PREFIX_PATH :
-- CMAKE_INSTALL_PREFIX : /usr/local
-- CMAKE_MODULE_PATH :
-- ONNX version : 1.6.0
-- ONNX NAMESPACE : onnx2trt_onnx
-- ONNX_BUILD_TESTS : OFF
-- ONNX_BUILD_BENCHMARKS : OFF
-- ONNX_USE_LITE_PROTO : OFF
-- ONNXIFI_DUMMY_BACKEND : OFF
-- ONNXIFI_ENABLE_EXT : OFF
-- Protobuf compiler :
-- Protobuf includes :
-- Protobuf libraries :
-- BUILD_ONNX_PYTHON : OFF
-- Found TensorRT headers at /home/minh/TensorRT/include
-- Find TensorRT libs at /usr/lib/x86_64-linux-gnu/libnvinfer.so;/usr/lib/x86_64-linux-gnu/libnvinfer_plugin.so;/usr/lib/x86_64-linux-gnu/libmyelin.so
-- Adding new sample: sample_char_rnn
-- - Parsers Used: none
-- - InferPlugin Used: OFF
-- - Licensing: opensource
-- Adding new sample: sample_dynamic_reshape
-- - Parsers Used: onnx
-- Adding new sample: sample_fasterRCNN
-- - Parsers Used: caffe
-- - InferPlugin Used: ON
-- Adding new sample: sample_googlenet
-- Adding new sample: sample_int8
-- Adding new sample: sample_int8_api
-- Adding new sample: sample_mlp
-- Adding new sample: sample_mnist
-- Adding new sample: sample_mnist_api
-- Adding new sample: sample_movielens
-- - Parsers Used: uff
-- Adding new sample: sample_movielens_mps
-- Adding new sample: sample_nmt
-- Adding new sample: sample_onnx_mnist
-- Adding new sample: sample_plugin
-- Adding new sample: sample_reformat_free_io
-- Adding new sample: sample_ssd
-- Adding new sample: sample_uff_fasterRCNN
-- Adding new sample: sample_uff_maskRCNN
-- Adding new sample: sample_uff_mnist
-- Adding new sample: sample_uff_plugin_v2_ext
-- Adding new sample: sample_uff_ssd
-- Adding new sample: trtexec
-- - Parsers Used: caffe;uff;onnx
-- Configuring done
CMake Warning (dev) in plugin/CMakeLists.txt:
Policy CMP0104 is not set: CMAKE_CUDA_ARCHITECTURES now detected for NVCC,
empty CUDA_ARCHITECTURES not allowed. Run "cmake --help-policy CMP0104"
for policy details. Use the cmake_policy command to set the policy and
suppress this warning.
CUDA_ARCHITECTURES is empty for target "nvinfer_plugin".
This warning is for project developers. Use -Wno-dev to suppress it.
CUDA_ARCHITECTURES is empty for target "nvinfer_plugin_static".
-- Generating done
-- Build files have been written to: /home/minh/TensorRT/build
$make nvinfer_plugin -j$(nproc)
[ 6%] Building CUDA object plugin/CMakeFiles/nvinfer_plugin.dir/fcPlugin/fcPlugin.cu.o
In file included from /usr/local/cuda/include/cub/util_arch.cuh:36:0,
from /usr/local/cuda/include/cub/config.cuh:35,
from /usr/local/cuda/include/cub/cub.cuh:37,
from /home/minh/TensorRT/plugin/common/bertCommon.h:27,
from /home/minh/TensorRT/plugin/fcPlugin/fcPlugin.h:20,
from /home/minh/TensorRT/plugin/fcPlugin/fcPlugin.cu:18:
/usr/local/cuda/include/cub/util_cpp_dialect.cuh:129:13: warning: CUB requires C++14. Please pass -std=c++14 to your compiler. Define CUB_IGNORE_DEPRECATED_CPP_DIALECT to suppress this message.
CUB_COMPILER_DEPRECATION(C++14, pass -std=c++14 to your compiler);
In file included from /usr/local/cuda/include/thrust/detail/config/config.h:27:0,
from /usr/local/cuda/include/thrust/detail/config.h:23,
from /usr/local/cuda/include/thrust/system/cuda/detail/core/triple_chevron_launch.h:29,
from /usr/local/cuda/include/cub/device/dispatch/dispatch_histogram.cuh:48,
from /usr/local/cuda/include/cub/device/device_histogram.cuh:41,
from /usr/local/cuda/include/cub/cub.cuh:52,
/usr/local/cuda/include/thrust/detail/config/cpp_dialect.h:104:13: warning: Thrust requires C++14. Please pass -std=c++14 to your compiler. Define THRUST_IGNORE_DEPRECATED_CPP_DIALECT to suppress this message.
THRUST_COMPILER_DEPRECATION(C++14, pass -std=c++14 to your compiler);
/home/minh/TensorRT/plugin/fcPlugin/fcPlugin.cu(165): error: argument of type "cudaDataType_t" is incompatible with parameter of type "cublasComputeType_t"
/home/minh/TensorRT/plugin/fcPlugin/fcPlugin.cu(165): error: too few arguments in function call
/home/minh/TensorRT/plugin/fcPlugin/fcPlugin.cu(177): error: argument of type "cudaDataType_t" is incompatible with parameter of type "cublasComputeType_t"
/home/minh/TensorRT/plugin/fcPlugin/fcPlugin.cu(193): error: argument of type "cudaDataType_t" is incompatible with parameter of type "cublasComputeType_t"
/home/minh/TensorRT/plugin/fcPlugin/fcPlugin.h(230): error: argument of type "cudaDataType_t" is incompatible with parameter of type "cublasComputeType_t"
/home/minh/TensorRT/plugin/fcPlugin/fcPlugin.h(230): error: too few arguments in function call
6 errors detected in the compilation of "/home/minh/TensorRT/plugin/fcPlugin/fcPlugin.cu".
plugin/CMakeFiles/nvinfer_plugin.dir/build.make:731: recipe for target 'plugin/CMakeFiles/nvinfer_plugin.dir/fcPlugin/fcPlugin.cu.o' failed
make[3]: *** [plugin/CMakeFiles/nvinfer_plugin.dir/fcPlugin/fcPlugin.cu.o] Error 1
CMakeFiles/Makefile2:1383: recipe for target 'plugin/CMakeFiles/nvinfer_plugin.dir/all' failed
make[2]: *** [plugin/CMakeFiles/nvinfer_plugin.dir/all] Error 2
CMakeFiles/Makefile2:1390: recipe for target 'plugin/CMakeFiles/nvinfer_plugin.dir/rule' failed
make[1]: *** [plugin/CMakeFiles/nvinfer_plugin.dir/rule] Error 2
Makefile:244: recipe for target 'nvinfer_plugin' failed
make: *** [nvinfer_plugin] Error 2
Please advise on how to solve this error.
