Description
Building for TensorRT version: 8.0.1, library version: 8
– Targeting TRT Platform: x86_64
– CUDA version set to 11.3.1
– cuDNN version set to 8.2
– Protobuf version set to 3.0.0
– Using libprotobuf /tmp/TensorRT/build/third_party.protobuf/lib/libprotobuf.a
– ========================= Importing and creating target nvinfer ============= =============
– Looking for library nvinfer
– Library that was found /usr/lib/x86_64-linux-gnu/libnvinfer.so
– ========================= Importing and creating target nvuffparser ========= =================
– Looking for library nvparsers
– Library that was found /usr/lib/x86_64-linux-gnu/libnvparsers.so
– GPU_ARCHS is not defined. Generating CUDA code for default SMs: 35;53;61;70;7 5;80
– Protobuf proto/trtcaffe.proto → proto/trtcaffe.pb.cc proto/trtcaffe.pb.h
– /tmp/TensorRT/build/parsers/caffe
Generated: /tmp/TensorRT/build/parsers/onnx/third_party/onnx/onnx/onnx_onnx2trt_ onnx-ml.proto
Generated: /tmp/TensorRT/build/parsers/onnx/third_party/onnx/onnx/onnx-operators _onnx2trt_onnx-ml.proto
– ******** Summary ********
– CMake version : 3.17.0
– CMake command : /tmp/cmake-3.17.0/bin/cmake
– System : Linux
– C++ compiler : /usr/bin/g++
– C++ compiler version : 9.3.0
– CXX flags : -Wno-deprecated-declarations -DBUILD_SYSTEM=cmake_ oss -Wall -Wno-deprecated-declarations -Wno-unused-function -Wnon-virtual-dtor
– Build type : Release
– Compile definitions : _PROTOBUF_INSTALL_DIR=/tmp/TensorRT/build;ONNX_NAME SPACE=onnx2trt_onnx
– CMAKE_PREFIX_PATH :
– CMAKE_INSTALL_PREFIX : /usr/lib/aarch64-linux-gnu/..
– CMAKE_MODULE_PATH :
– ONNX version : 1.6.0
– ONNX NAMESPACE : onnx2trt_onnx
– ONNX_BUILD_TESTS : OFF
– ONNX_BUILD_BENCHMARKS : OFF
– ONNX_USE_LITE_PROTO : OFF
– ONNXIFI_DUMMY_BACKEND : OFF
– ONNXIFI_ENABLE_EXT : OFF
– Protobuf compiler :
– Protobuf includes :
– Protobuf libraries :
– BUILD_ONNX_PYTHON : OFF
– Found TensorRT headers at /usr/include/
– Find TensorRT libs at /usr/lib/x86_64-linux-gnu/libnvinfer.so;/usr/lib/x86_64 -linux-gnu/libnvinfer_plugin.so
– Adding new sample: sample_algorithm_selector
– - Parsers Used: caffe
– - InferPlugin Used: OFF
– - Licensing: opensource
– Adding new sample: sample_char_rnn
– - Parsers Used: uff;caffe;onnx
– Adding new sample: sample_dynamic_reshape
– - Parsers Used: onnx
– Adding new sample: sample_fasterRCNN
– - InferPlugin Used: ON
– Adding new sample: sample_googlenet
– Adding new sample: sample_int8
– Adding new sample: sample_int8_api
– Adding new sample: sample_mlp
– Adding new sample: sample_mnist
– Adding new sample: sample_mnist_api
– Adding new sample: sample_nmt
– - Parsers Used: none
– Adding new sample: sample_onnx_mnist
– Adding new sample: sample_reformat_free_io
– Adding new sample: sample_ssd
– Adding new sample: sample_uff_fasterRCNN
– Adding new sample: sample_uff_maskRCNN
– Adding new sample: sample_uff_mnist
– Adding new sample: sample_uff_plugin_v2_ext
– Adding new sample: sample_uff_ssd
– Adding new sample: sample_onnx_mnist_coord_conv_ac
– Adding new sample: trtexec
– - Parsers Used: caffe;uff;onnx
– Configuring done
– Generating done
– Build files have been written to: /tmp/TensorRT/build
The last lines of the make -j output are:
[ 54%] Linking CXX static library ../libnvinfer_plugin_static.a
[ 54%] Built target nvinfer_plugin_static
make: *** [Makefile:169: all] Error 2
The cMaket error log shows as follows:
Determining if the pthread_create exist failed with the following output:
Change Dir: /tmp/TensorRT/build/CMakeFiles/CMakeTmp
Run Build Command:“/usr/bin/make” “cmTC_acdb9/fast”
/usr/bin/make -f CMakeFiles/cmTC_acdb9.dir/build.make CMakeFiles/cmTC_acdb9.dir/build
make[1]: Entering directory ‘/tmp/TensorRT/build/CMakeFiles/CMakeTmp’
Building CXX object CMakeFiles/cmTC_acdb9.dir/CheckSymbolExists.cxx.o
/usr/bin/g++ -Wno-deprecated-declarations -DBUILD_SYSTEM=cmake_oss -std=c++11 -o CMakeFiles/cmTC_acdb9.dir/CheckSymbolExists.cxx.o -c /tmp/TensorRT/build/CMakeFiles/CMakeTmp/CheckSymbolExists.cxx
Linking CXX executable cmTC_acdb9
/tmp/cmake-3.13.0/bin/cmake -E cmake_link_script CMakeFiles/cmTC_acdb9.dir/link.txt --verbose=1
/usr/bin/g++ -Wno-deprecated-declarations -DBUILD_SYSTEM=cmake_oss CMakeFiles/cmTC_acdb9.dir/CheckSymbolExists.cxx.o -o cmTC_acdb9
/usr/bin/ld: CMakeFiles/cmTC_acdb9.dir/CheckSymbolExists.cxx.o: in function main': CheckSymbolExists.cxx:(.text+0x1f): undefined reference to pthread_create’
collect2: error: ld returned 1 exit status
make[1]: *** [CMakeFiles/cmTC_acdb9.dir/build.make:87: cmTC_acdb9] Error 1
make[1]: Leaving directory ‘/tmp/TensorRT/build/CMakeFiles/CMakeTmp’
make: *** [Makefile:121: cmTC_acdb9/fast] Error 2
File /tmp/TensorRT/build/CMakeFiles/CMakeTmp/CheckSymbolExists.cxx:
include <pthread.h>
int main(int argc, char** argv)
(void)argv;
#ifndef pthread_create
return ((int*)(&pthread_create))[argc];
#else
(void)argc;
return 0;
endif
Determining if the function pthread_create exists in the pthreads failed with the following output:
Run Build Command:“/usr/bin/make” “cmTC_34380/fast”
/usr/bin/make -f CMakeFiles/cmTC_34380.dir/build.make CMakeFiles/cmTC_34380.dir/build
Building CXX object CMakeFiles/cmTC_34380.dir/CheckFunctionExists.cxx.o
/usr/bin/g++ -Wno-deprecated-declarations -DBUILD_SYSTEM=cmake_oss -DCHECK_FUNCTION_EXISTS=pthread_create -std=c++11 -o CMakeFiles/cmTC_34380.dir/CheckFunctionExists.cxx.o -c /tmp/TensorRT/build/CMakeFiles/CheckLibraryExists/CheckFunctionExists.cxx
Linking CXX executable cmTC_34380
/tmp/cmake-3.13.0/bin/cmake -E cmake_link_script CMakeFiles/cmTC_34380.dir/link.txt --verbose=1
/usr/bin/g++ -Wno-deprecated-declarations -DBUILD_SYSTEM=cmake_oss -DCHECK_FUNCTION_EXISTS=pthread_create CMakeFiles/cmTC_34380.dir/CheckFunctionExists.cxx.o -o cmTC_34380 -lpthreads
/usr/bin/ld: cannot find -lpthreads
make[1]: *** [CMakeFiles/cmTC_34380.dir/build.make:87: cmTC_34380] Error 1
make: *** [Makefile:121: cmTC_34380/fast] Error 2
Environment
TensorRT Version: 8.0.1.6
GPU Type: Nvidia RTX 2060
Nvidia Driver Version: 470.42.01
CUDA Version: 11.3
CUDNN Version: 8.2.1
Operating System + Version: Ubuntu 20.04 LTS
Python Version (if applicable): 3.8.10
TensorFlow Version (if applicable): 2.5
Cmake version: 3.17
Steps To Reproduce
git clone -b master GitHub - NVIDIA/TensorRT: NVIDIA® TensorRT™ is an SDK for high-performance deep learning inference on NVIDIA GPUs. This repository contains the open source components of TensorRT. TensorRT
cd TensorRT
git submodule update --init --recursive
mkdir -p build && cd build
cmake .. -DTRT_LIB_DIR=/usr/lib/aarch64-linux-gnu/ -DCMAKE_C_COMPILER=/usr/bin/gcc -DCMAKE_CUDA_COMPILER:PATH=/usr/local/cuda/bin/nvcc
make -j$(nproc)
