Yolov3 to TensorRT - Segmentation fault on inference
I am currently using the following repository to convert Yolo v3 to TensorRT.
https://github.com/xuwanqi/yolov3-tensorrt
The same repository is present in the NGC container of TensorRT 5.1.
I can successfully convert YOLO to .trt file but getting a segmentation error on inference.
TensorRT version : 5.1.2.2
CUDA version : 10.1
cuDNN version : 7.4.2
GPU : V100 (AWS)
Error Dump :-
Loading ONNX file from path yolov3.onnx...
Beginning ONNX file parsing
Completed parsing of ONNX file
Building an engine from file yolov3.onnx; this may take a while...
Completed creating Engine
Running inference on image dog.jpg...
Fatal Python error: Segmentation fault
Current thread 0x00007fbb1850b700 (most recent call first):
  File "/workspace/tensorrt/samples/python/yolov3_onnx/../common.py", line 145 in do_inference
  File "onnx_to_tensorrt.py", line 160 in main
  File "onnx_to_tensorrt.py", line 183 in <module>
Below is the function where it throws the error:-
def do_inference(context, bindings, inputs, outputs, stream, batch_size=1):
    start = time.time()
    # Transfer input data to the GPU.
    [cuda.memcpy_htod_async(inp.device, inp.host, stream) for inp in inputs]
    # Run inference.
    context.execute_async(batch_size=batch_size, bindings=bindings, stream_handle=stream.handle)
    # Transfer predictions back from the GPU.
    [cuda.memcpy_dtoh_async(out.host, out.device, stream) for out in outputs]
    # Synchronize the stream
    stream.synchronize()
    # Return only the host outputs.
    print("=> time: %.4f" %(time.time()-start))
    return [out.host for out in outputs]
Any help is appreciated.
Hello @meetdave06 ,
Are you able to resolve this issue?
I am also encountering the similar problem
Yes.
Do not build the python module if using TensorRT5 while installing onnx-tensorrt.
https://github.com/onnx/onnx-tensorrt#python-modules
I didn’t build the python modules while installing onnx-tensorrt.
I just followed these steps:
mkdir build
cd build
cmake … -DTENSORRT_ROOT=/opt/tensorrt
make -j8
sudo make install
Yes,I am using TensorRT version 5.1.2.2
I used to do this.
cmake -DCUDA_INCLUDE_DIRS=/usr/local/cuda-10.0/include -DTENSORRT_ROOT=/opt/tensorrt …
Also, I switched to TensorRT 5.0
I switched back to TensorRT 5.0.2.6 but with CUDA 9.0 and CUDNN 7.5, it still doesn’t work.
Maybe I should switch to cuda10.0 like yours !
I encounter the same problem, and my tensorrt version is
4.0.3.0-1+cuda10.0 arm64
Is there any methods to upgrade tensorrt from 4.0 to 5.0. I had tried to download version 5.0 from official website → [b]https://developer.nvidia.com/nvidia-tensorrt-5x-download[/b]
But it seems not have package for arm embedded system
Hello, I am also using the repository GitHub - xuwanqi/yolov3-tensorrt to convert yolov3.weights to yolov3.onnx and then yolov3.onnx to yolov3.trt.
I am successfully in converting yolov3.weights to yolov3.onnx. Please see the below screenshot from the below link to see success at this point.
Now when I run the below file to build the .trt file from .onnx
python2 onnx_to_tensorrt.py
I got the below error
Loading ONNX file from path ./yolov3.onnx...
Building an engine from file ./yolov3.onnx; this may take a while...
What I have in my system
ii  graphsurgeon-tf                                             5.1.5-1+cuda10.0                             amd64        GraphSurgeon for TensorRT package
ii  libnvinfer-dev                                              5.1.5-1+cuda10.0                             amd64        TensorRT development libraries and headers
ii  libnvinfer-samples                                          5.1.5-1+cuda10.0                             all          TensorRT samples and documentation
ii  libnvinfer5                                                 5.1.5-1+cuda10.0                             amd64        TensorRT runtime libraries
ii  python-libnvinfer                                           5.1.5-1+cuda10.0                             amd64        Python bindings for TensorRT
ii  python-libnvinfer-dev                                       5.1.5-1+cuda10.0                             amd64        Python development package for TensorRT
ii  python3-libnvinfer                                          5.1.5-1+cuda10.0                             amd64        Python 3 bindings for TensorRT
ii  python3-libnvinfer-dev                                      5.1.5-1+cuda10.0                             amd64        Python 3 development package for TensorRT
ii  tensorrt                                                    5.1.5.0-1+cuda10.0                           amd64        Meta package of TensorRT
ii  uff-converter-tf                                            5.1.5-1+cuda10.0                             amd64        UFF converter for TensorRT package
onnx                                                            1.1.1
I have successfully build ONNX-TensorRT using the repository GitHub - onnx/onnx-tensorrt: ONNX-TensorRT: TensorRT backend for ONNX, All the steps are successfully. I donot know why I am getting the error Segmentation fault (core dumped)
Note: Please notice that while building ONNX-TensorRT, I used the below command
cmake .. -DTENSORRT_ROOT=/usr/src/tensorrt
Can anyone explain what should I do know to overcome this error.
I have solved the above error by instead of building the yolo tensorrt model from this github repository, I tried with the sample placed at the following location
/usr/src/tensorrt/samples/python/yolov3_onnx
While building the code I was stuck in the way and got the error. Before showing the error as well as how I overcome it, let me write the steps I have implemented for building the code
python2 -m pip install -r requirements.txt
# code to convert yolo weights to yolo.onxx
python2 yolov3_to_onnx.py
# code to convert yolo.onxx to yolo.trt
Error I got after executing the command
  File "yolov3_to_onnx.py", line 812, in <module>
    main()
  File "yolov3_to_onnx.py", line 805, in main
    onnx.checker.check_model(yolov3_model_def)
  File "/home/gpu/.local/lib/python2.7/site-packages/onnx/checker.py", line 82, in check_model
    C.check_model(model.SerializeToString())
onnx.onnx_cpp2py_export.checker.ValidationError: Input size 2 not in range [min=1, max=1].
==> Context: Bad node spec: input: "085_convolutional_lrelu" input: "086_upsample_scale" output: "086_upsample" name: "086_upsample" op_type: "Upsample" attribute { name: "mode" s: "nearest" type: STRING }
How did I resolved this
I got the solution from https://devtalk.nvidia.com/default/topic/1052153/jetson-nano/tensorrt-backend-for-onnx-on-jetson-nano/1 by answer given by sojohans to upgrade onnx to onnx==1.4.1. Please execute the below command
pip2 uninstall onnx
pip2 install onnx==1.4.1 --user
hi sanpreetsingh
i use the onnx=1.4.1 but still meet this problem. any help is appreciated.
Is there some good reason to use python2 ?
br. Markus
