I am debugging my own codec chip on orin nx, the system version is jetpack5.1.2. I hope it can play sound, the codec structure is as follows.
Hardware connection
I connected the codec to the 40-pin i2s and connected I2C to I2C1.
Software configuration
The device tree is configured as follows, mainly the modification of I2c and I2s.
// SPDX-License-Identifier: GPL-2.0-only
* Common Audio DT bindings
* Copyright (c) 2022, NVIDIA CORPORATION & AFFILIATES. All rights reserved.
#include <audio/tegra-platforms-audio-dai-links.dtsi>
#include <audio/tegra186-audio-dai-links.dtsi>
#include <audio/tegra186-audio-graph.dtsi>
aconnect@2a41000 {
agic-controller@2a41000 {
status = "okay";
adsp@2993000 {
status = "okay";
ahub {
status = "okay";
/* I2S1 in Short frame sync for BT SCO */
//i2s@2901000 {
// status = "okay";
//fsync-width = <0>;
//bclk-ratio = <4>;
i2s@2901100 {
status = "okay";
// i2s@2901300 {
// status = "okay";
hda@3510000 {
nvidia,model = "NVIDIA Jetson Orin NX HDA";
status = "okay";
hdr40_i2c1: i2c@c250000 {
status = "okay";
aw_smartpa_dai_name: aw882xx_smartpa@34 {
compatible = "awinic,aw882xx_smartpa";
#sound-dai-cells = <0>;
reg = <0x34>;
irq-gpio = <&tegra_main_gpio TEGRA234_MAIN_GPIO(H, 0) GPIO_ACTIVE_LOW>;
status = "okay";
tegra_sound: sound {
status = "okay";
compatible = "nvidia,tegra186-ape";
nvidia-audio-card,name = "NVIDIA Jetson Orin NX APE";
// nvidia-audio-card,widgets =
// "Headphone", "CVB-RT Headphone Jack",
// "Microphone", "CVB-RT Mic Jack",
// "Speaker", "CVB-RT Int Spk",
// "Microphone", "CVB-RT Int Mic";
// nvidia-audio-card,routing =
// "CVB-RT Headphone Jack", "CVB-RT HPOL",
// "CVB-RT Headphone Jack", "CVB-RT HPOR",
// "CVB-RT IN1P", "CVB-RT Mic Jack",
// "CVB-RT IN2P", "CVB-RT Mic Jack",
// "CVB-RT Int Spk", "CVB-RT SPOLP",
// "CVB-RT Int Spk", "CVB-RT SPORP",
// "CVB-RT DMIC1", "CVB-RT Int Mic",
// "CVB-RT DMIC2", "CVB-RT Int Mic";
nvidia-audio-card,mclk-fs = <256>;
clocks = <&bpmp_clks TEGRA234_CLK_PLLA>,
<&bpmp_clks TEGRA234_CLK_PLLA_OUT0>,
<&bpmp_clks TEGRA234_CLK_AUD_MCLK>;
clock-names = "pll_a", "pll_a_out0", "extern1";
assigned-clocks = <&bpmp_clks TEGRA234_CLK_PLLA_OUT0>,
assigned-clock-parents = <&bpmp_clks TEGRA234_CLK_PLLA>,
<&bpmp_clks TEGRA234_CLK_PLLA_OUT0>;
tegra_sound_graph: sound_graph {
compatible = "nvidia,tegra186-audio-graph-card";
* Tegra audio graph card is based on uptream generic audio
* graph sound card. In future there is plan to use this
* as default sound card.
status = "disabled";
dais = /* ADMAIF (FE) Ports */
<&admaif1_port>, <&admaif2_port>, <&admaif3_port>,
<&admaif4_port>, <&admaif5_port>, <&admaif6_port>,
<&admaif7_port>, <&admaif8_port>, <&admaif9_port>,
<&admaif10_port>, <&admaif11_port>, <&admaif12_port>,
<&admaif13_port>, <&admaif14_port>, <&admaif15_port>,
<&admaif16_port>, <&admaif17_port>, <&admaif18_port>,
<&admaif19_port>, <&admaif20_port>,
/* ADSP (FE) Ports */
<&adsp_pcm1_port>, <&adsp_pcm2_port>,
<&adsp_compr1_port>, <&adsp_compr2_port>,
/* XBAR I/O ports */
<&xbar_i2s1_port>, <&xbar_i2s2_port>, <&xbar_i2s3_port>,
<&xbar_i2s4_port>, <&xbar_i2s5_port>, <&xbar_i2s6_port>,
<&xbar_dmic1_port>, <&xbar_dmic2_port>,
<&xbar_dmic3_port>, <&xbar_dmic4_port>,
<&xbar_dspk1_port>, <&xbar_dspk2_port>,
/* XBAR HW accelerator ports */
<&xbar_sfc1_in_port>, <&xbar_sfc2_in_port>,
<&xbar_sfc3_in_port>, <&xbar_sfc4_in_port>,
<&xbar_mvc1_in_port>, <&xbar_mvc2_in_port>,
<&xbar_afc1_in_port>, <&xbar_afc2_in_port>,
<&xbar_afc3_in_port>, <&xbar_afc4_in_port>,
<&xbar_afc5_in_port>, <&xbar_afc6_in_port>,
<&xbar_asrc_in1_port>, <&xbar_asrc_in2_port>,
<&xbar_asrc_in3_port>, <&xbar_asrc_in4_port>,
<&xbar_asrc_in5_port>, <&xbar_asrc_in6_port>,
<&xbar_asrc_in7_port>, <&xbar_arad_port>,
<&xbar_mixer_in1_port>, <&xbar_mixer_in2_port>,
<&xbar_mixer_in3_port>, <&xbar_mixer_in4_port>,
<&xbar_mixer_in5_port>, <&xbar_mixer_in6_port>,
<&xbar_mixer_in7_port>, <&xbar_mixer_in8_port>,
<&xbar_mixer_in9_port>, <&xbar_mixer_in10_port>,
<&xbar_ope1_in_port>,
<&xbar_amx1_in1_port>, <&xbar_amx1_in2_port>,
<&xbar_amx1_in3_port>, <&xbar_amx1_in4_port>,
<&xbar_amx2_in1_port>, <&xbar_amx2_in2_port>,
<&xbar_amx2_in3_port>, <&xbar_amx2_in4_port>,
<&xbar_amx3_in1_port>, <&xbar_amx3_in2_port>,
<&xbar_amx3_in3_port>, <&xbar_amx3_in4_port>,
<&xbar_amx4_in1_port>, <&xbar_amx4_in2_port>,
<&xbar_amx4_in3_port>, <&xbar_amx4_in4_port>,
<&xbar_adx1_in_port>, <&xbar_adx2_in_port>,
<&xbar_adx3_in_port>, <&xbar_adx4_in_port>,
/* BE I/O Ports */
<&i2s1_port>, <&i2s2_port>, <&i2s3_port>,
<&i2s4_port>, <&i2s5_port>, <&i2s6_port>,
<&dmic1_port>, <&dmic2_port>, <&dmic3_port>,
<&dmic4_port>,
<&dspk1_port>, <&dspk2_port>,
/* BE HW accelerator ports */
<&sfc1_out_port>, <&sfc2_out_port>,
<&sfc3_out_port>, <&sfc4_out_port>,
<&mvc1_out_port>, <&mvc2_out_port>,
<&afc1_out_port>, <&afc2_out_port>,
<&afc3_out_port>, <&afc4_out_port>,
<&afc5_out_port>, <&afc6_out_port>,
<&asrc_out1_port>, <&asrc_out2_port>,
<&asrc_out3_port>, <&asrc_out4_port>,
<&asrc_out5_port>, <&asrc_out6_port>,
<&mixer_out1_port>, <&mixer_out2_port>,
<&mixer_out3_port>, <&mixer_out4_port>,
<&mixer_out5_port>,
<&ope1_out_port>,
<&amx1_out_port>, <&amx2_out_port>,
<&amx3_out_port>, <&amx4_out_port>,
<&adx1_out1_port>, <&adx1_out2_port>,
<&adx1_out3_port>, <&adx1_out4_port>,
<&adx2_out1_port>, <&adx2_out2_port>,
<&adx2_out3_port>, <&adx2_out4_port>,
<&adx3_out1_port>, <&adx3_out2_port>,
<&adx3_out3_port>, <&adx3_out4_port>,
<&adx4_out1_port>, <&adx4_out2_port>,
<&adx4_out3_port>, <&adx4_out4_port>,
/* ADSP related ports */
<&adsp_admaif1_port>, <&adsp_admaif2_port>,
<&adsp_admaif3_port>, <&adsp_admaif4_port>,
<&adsp_admaif5_port>, <&adsp_admaif6_port>,
<&adsp_admaif7_port>, <&adsp_admaif8_port>,
<&adsp_admaif9_port>, <&adsp_admaif10_port>,
<&adsp_admaif11_port>, <&adsp_admaif12_port>,
<&adsp_admaif13_port>, <&adsp_admaif14_port>,
<&adsp_admaif15_port>, <&adsp_admaif16_port>,
<&adsp_admaif17_port>, <&adsp_admaif18_port>,
<&adsp_admaif19_port>, <&adsp_admaif20_port>,
<&admaif1_codec_port>, <&admaif2_codec_port>,
<&admaif3_codec_port>, <&admaif4_codec_port>,
<&admaif5_codec_port>, <&admaif6_codec_port>,
<&admaif7_codec_port>, <&admaif8_codec_port>,
<&admaif9_codec_port>, <&admaif10_codec_port>,
<&admaif11_codec_port>, <&admaif12_codec_port>,
<&admaif13_codec_port>, <&admaif14_codec_port>,
<&admaif15_codec_port>, <&admaif16_codec_port>,
<&admaif17_codec_port>, <&admaif18_codec_port>,
<&admaif19_codec_port>, <&admaif20_codec_port>;
label = "NVIDIA Jetson Concord APE";
clock-names = "pll_a", "plla_out0";
assigned-clocks = <&bpmp_clks TEGRA234_CLK_AUD_MCLK>;
assigned-clock-parents = <&bpmp_clks TEGRA234_CLK_PLLA_OUT0>;
hdr40_snd_link_i2s: &i2s2_to_codec {
link-name = "aw88261-audio-v1";
bitclock-master;
frame-master;
format = "i2s";
cpu {
sound-dai = <&tegra_i2s2 0>;
codec {
sound-dai = <&aw_smartpa_dai_name 0>;
prefix = "CVB-RT";
/* Audio graph related bindings */
hdr40_snd_i2s_dap_ep: &i2s2_dap_ep { };
After adding the codec driver, compile the flash, the i2c communication is normal, and the codec driver log also shows that the initialization is completed.
The current problem is that I can’t play sound. I checked the NVIDIA Jetson Orin NX APE through alsamixer. There are many items. I found my custom codec items (those starting with CVB-RT, as defined in the device tree) in many items, and I can also adjust my codec parameters through it.
Normally, my codec will print some logs when it is called (this comes from my codec code), but now there is no log output when playing, and i2s has no waveform. I guess my codec is not called.
Is this a problem with the audio routing?
I am not very familiar with this part, and I hope you can give me some ideas to solve the problem.
My playback command
aplay -D hw:APE,0 1.wav
cat /proc/asound/cards
0 [HDA ]: tegra-hda - NVIDIA Jetson Orin NX HDA
NVIDIA Jetson Orin NX HDA at 0x3518000 irq 111
1 [APE ]: tegra-ape - NVIDIA Jetson Orin NX APE
Unknown-NVIDIAOrinNXDeveloperKit-NotSpecified
some logs:
amixer.log (501.4 KB)
dmesg.log (83.6 KB)
pinmux.log (39.3 KB)
Supplementary content:
When I use the above aplay command to play, the event log is as follows, and it seems that there is no I2S2?
cat /sys/kernel/debug/tracing/trace_pipe | grep \*
aplay-2051 [001] .... 1845.023151: snd_soc_dapm_path: *ADMAIF1 XBAR-RX <- (direct) <- ADMAIF1 XBAR-Playback
aplay-2051 [001] .... 1845.023213: snd_soc_dapm_path: *I2S1 Mux <- ADMAIF1 <- ADMAIF1 XBAR-RX
aplay-2051 [001] .... 1845.023215: snd_soc_dapm_path: *I2S1 XBAR-TX <- (direct) <- I2S1 Mux
aplay-2051 [001] .... 1845.023217: snd_soc_dapm_path: *I2S1 XBAR-Capture <- (direct) <- I2S1 XBAR-TX
aplay-2051 [001] .... 1845.023218: snd_soc_dapm_path: *tegra-dlink-64-playback <- (direct) <- I2S1 XBAR-Capture
aplay-2051 [001] .... 1845.023219: snd_soc_dapm_path: *I2S1 CIF-Playback <- (direct) <- tegra-dlink-64-playback
aplay-2051 [001] .... 1845.023220: snd_soc_dapm_path: *I2S1 RX <- (direct) <- I2S1 CIF-Playback
aplay-2051 [001] .... 1845.023221: snd_soc_dapm_path: *I2S1 DAP-Capture <- (direct) <- I2S1 RX
aplay-2051 [001] .... 1845.023222: snd_soc_dapm_path: *tegra-dlink-76-playback <- (direct) <- I2S1 DAP-Capture
aplay-2051 [001] .... 1845.023223: snd_soc_dapm_path: *I2S1 Dummy-Playback <- (direct) <- tegra-dlink-76-playback
aplay-2051 [001] .... 1845.023224: snd_soc_dapm_path: *I2S1 SPK <- (direct) <- I2S1 Dummy-Playback
aplay-2051 [001] .... 1850.458000: snd_soc_dapm_path: *ADMAIF1 XBAR-Playback <- (direct) <- tegra-dlink-44-playback
aplay-2051 [001] .... 1850.458001: snd_soc_dapm_path: *ADMAIF1 XBAR-Playback <- (direct) <- ADMAIF1 Playback
aplay-2051 [001] .... 1850.458003: snd_soc_dapm_path: *ADMAIF1 XBAR-RX <- (direct) <- ADMAIF1 XBAR-Playback
aplay-2051 [001] .... 1850.458053: snd_soc_dapm_path: *I2S1 Mux <- ADMAIF1 <- ADMAIF1 XBAR-RX
aplay-2051 [001] .... 1850.458054: snd_soc_dapm_path: *I2S1 XBAR-TX <- (direct) <- I2S1 Mux
aplay-2051 [001] .... 1850.458055: snd_soc_dapm_path: *I2S1 XBAR-Capture <- (direct) <- I2S1 XBAR-TX
aplay-2051 [001] .... 1850.458056: snd_soc_dapm_path: *tegra-dlink-64-playback <- (direct) <- I2S1 XBAR-Capture
aplay-2051 [001] .... 1850.458057: snd_soc_dapm_path: *I2S1 CIF-Playback <- (direct) <- tegra-dlink-64-playback
aplay-2051 [001] .... 1850.458058: snd_soc_dapm_path: *I2S1 RX <- (direct) <- I2S1 CIF-Playback
aplay-2051 [001] .... 1850.458059: snd_soc_dapm_path: *I2S1 DAP-Capture <- (direct) <- I2S1 RX
aplay-2051 [001] .... 1850.458060: snd_soc_dapm_path: *tegra-dlink-76-playback <- (direct) <- I2S1 DAP-Capture
aplay-2051 [001] .... 1850.458061: snd_soc_dapm_path: *I2S1 Dummy-Playback <- (direct) <- tegra-dlink-76-playback
aplay-2051 [001] .... 1850.458063: snd_soc_dapm_path: *I2S1 SPK <- (direct) <- I2S1 Dummy-Playback
