color stripes contained in decoded image
When i use the gstreamer to decode a video of 1080p. I found there are several color stripes in the bottom of the image(see the attachment). I used the pipeline as follows:
gst-launch-1.0 rtspsrc location=rtsp://admin:12345@172.16.10.195:554/h264/ch1/main/av_stream ! rtph264depay ! h264parse ! omxh264dec ! nvvidconv ! video/x-raw ! videoconvert ! nveglglessink -e
It seems that the image size was changed to 19201088(for 16-byte alignment) after processing by decoder. I thought nvvidconv should cropped the raw image to 19201080 according to the mata-info before processing, but in fact it just resized the image to 1920*1080 and this would cause the output image contains several color stripes .
I also made a test by using nvivafilter to instead of the nvvidconv, the output image is OK. but It seems that the nvivafilter takes high CPU performance, I don’t know why! The pipeline I used as follows:
gst-launch-1.0 rtspsrc location=rtsp://admin:12345@172.16.10.195:554/h264/ch1/main/av_stream ! rtph264depay ! h264parse ! omxh264dec ! nvivafilter ! video/x-raw(memory:NVMM),format=NV12  ! nvoverlaysink -e
You can configure top, bottom, left, right in nvvidconv.
Hi DaneLLL,
I know that I can assign the cropped-rect in nvvidconv when processing the 1080p videos, But In fact I don't even know the video resolution that i used. In addition, considering that the video resolution may be changed, i can't set the cropped rectangle to a fixed value.
We do not support runtime resolution change in nvvidconv plugin. Once the resolution is changed, you need to re-initialize nvvidconv.
Hi DaneLLL,
Maybe you don’t understand what i mean, i just want to remove the color stripes contained in decoded image.
I can’t use nvvidconv plugin to crop the image because i don’t know the video resolution. Any other ways to resolve this issue?
UPDATE
We don’t observe the issue in running 1080p video playback with nvv4l2decoder:
$ gst-launch-1.0 filesrc location=~/jellyfish-5-mbps-hd-h264.mkv ! matroskademux ! h264parse ! <b>nvv4l2decoder</b> ! nvvidconv ! nveglglessink
But it does happen with omxh264dec:
$ gst-launch-1.0 filesrc location=~/jellyfish-5-mbps-hd-h264.mkv ! matroskademux ! h264parse ! <b>omxh264dec</b> ! nvvidconv ! nveglglessink
Sample video file is at http://jell.yfish.us/
We are deprecating omx plugins, so please utilize nvviafilter while using omxh264dec:
$ gst-launch-1.0 filesrc location=~/jellyfish-5-mbps-hd-h264.mkv ! matroskademux ! h264parse ! omxh264dec ! nvivafilter ! 'video/x-raw(memory:NVMM),format=NV12' ! nvvidconv ! nveglglessink
Hi DaneLLL,
Thanks for your reply. As i said above, after i added nvviafilter while using omxh264dec,the CPU usage will become higher. In fact, I used the decodebin to auto-magically construct a decoding pipeline as i don’t know the video format(maybe a H265 format).
Please wait for nexr r32 release and utilize nvv4l2decoder.
There is an issue to run rtspsrc with nvv4l2decoder on r32.1. This shall be fixed in next release.
Hi DaneLLL,
I utilized the ‘appsrc’ and push back the H264/H265 video frames to the gst pipeline to instead the ‘rtspsrc’.
Then i utilized ‘parsebin | nvv4l2decoder’ to instead the ‘decodebin’, it works well, thank you!
This is a smart solution for r32.1. Thanks for the sharing.
