Is there an updated tutorial for ComfyUI and Flux on Jetson Orin.
On step 3 Verify and Configure CUDA it brakes.
Do you mean the step below?
https://www.jetson-ai-lab.com/tutorial_comfyui_flux.html#3-verify-and-configure-cuda
If so, JetPack 6.2.1 uses CUDA 12.6, so replacing the 12.4 with 12.6 should work.
Also the step
Install PyTorch, TorchVision, and TorchAudio
The wheels are broken
http://jetson.webredirect.org
Any feedback?
OK that worked, but the rest….
Sorry for the late update.
Do you get it work?
We have changed the server URL to link below:
I am sorry but I do not see the change, am I supposed to change the link from
https://pypi.jetson-ai-lab.dev/jp6/cu124
to
from Comfyui Manager
Found index url https://pypi.jetson-ai-lab.dev/jp6/cu126/
Starting new HTTPS connection (1): pypi.jetson-ai-lab.dev:443. and stays stuck there
Hi
Suppose you can install the ComfyUI dependencies with the above link via:
$ git clone https://github.com/comfyanonymous/ComfyUI.git
$ cd ComfyUI/
$ pip install -r requirements.txt --extra-index-url https://pypi.jetson-ai-lab.io/jp6/cu126
That did not work because: Torch not compiled with CUDA enabled
The instructions on the ComfyUI and Flux on Jetson Orin needs to be fixed.
Do you use the PyTorch shared from jp6/cu126 index?
The package supports CUDA and has been built with Orin’s GPU architecture.
Yes, I used the jp6/cu126 index
Thanks ~1105
Could you share the detailed log with us?
We want to check if any difference between us?
