(testenv) jetson@orin:~/torchvision_0.16.1$ yolo
File “/home/jetson/.local/bin/yolo”, line 5, in
from ultralytics.cfg import entrypoint
File “/home/jetson/.local/lib/python3.8/site-packages/ultralytics/init.py”, line 5, in
from ultralytics.data.explorer.explorer import Explorer
File “/home/jetson/.local/lib/python3.8/site-packages/ultralytics/data/init.py”, line 3, in
from .base import BaseDataset
File “/home/jetson/.local/lib/python3.8/site-packages/ultralytics/data/base.py”, line 17, in
from ultralytics.utils import DEFAULT_CFG, LOCAL_RANK, LOGGER, NUM_THREADS, TQDM
File “/home/jetson/.local/lib/python3.8/site-packages/ultralytics/utils/init.py”, line 1025, in
SETTINGS = SettingsManager() # initialize settings
File “/home/jetson/.local/lib/python3.8/site-packages/ultralytics/utils/init.py”, line 923, in init
from ultralytics.utils.torch_utils import torch_distributed_zero_first
File “/home/jetson/.local/lib/python3.8/site-packages/ultralytics/utils/torch_utils.py”, line 17, in
import torchvision
File “/home/jetson/.local/lib/python3.8/site-packages/torchvision/init.py”, line 6, in
from torchvision import _meta_registrations, datasets, io, models, ops, transforms, utils
File “/home/jetson/.local/lib/python3.8/site-packages/torchvision/_meta_registrations.py”, line 4, in
import torch._custom_ops
ModuleNotFoundError: No module named ‘torch._custom_ops’
I have successfully installed torch + torchvision respectively.
I got an error when running yolo command.
