yolo predict model=yolov8n.pt source='https://ultralytics.com/images/bus.jpg'
File "/home/doruk/doruk/yolov8/yolov8/bin/yolo", line 5, in <module>
from ultralytics.cfg import entrypoint
File "/home/doruk/doruk/yolov8/ultralytics/__init__.py", line 5, in <module>
from ultralytics.data.explorer.explorer import Explorer
File "/home/doruk/doruk/yolov8/ultralytics/data/__init__.py", line 3, in <module>
from .base import BaseDataset
File "/home/doruk/doruk/yolov8/ultralytics/data/base.py", line 17, in <module>
from ultralytics.data.utils import FORMATS_HELP_MSG, HELP_URL, IMG_FORMATS
File "/home/doruk/doruk/yolov8/ultralytics/data/utils.py", line 19, in <module>
from ultralytics.nn.autobackend import check_class_names
File "/home/doruk/doruk/yolov8/ultralytics/nn/__init__.py", line 3, in <module>
from .tasks import (
File "/home/doruk/doruk/yolov8/ultralytics/nn/tasks.py", line 10, in <module>
from ultralytics.nn.modules import (
File "/home/doruk/doruk/yolov8/ultralytics/nn/modules/__init__.py", line 65, in <module>
from .head import OBB, Classify, Detect, Pose, RTDETRDecoder, Segment, WorldDetect
File "/home/doruk/doruk/yolov8/ultralytics/nn/modules/head.py", line 10, in <module>
from ultralytics.utils.tal import TORCH_1_10, dist2bbox, dist2rbox, make_anchors
File "/home/doruk/doruk/yolov8/ultralytics/utils/__init__.py", line 47, in <module>
TORCHVISION_VERSION = importlib.metadata.version("torchvision") # faster than importing torchvision
File "/usr/lib/python3.8/importlib/metadata.py", line 530, in version
return distribution(distribution_name).version
File "/usr/lib/python3.8/importlib/metadata.py", line 503, in distribution
return Distribution.from_name(distribution_name)
File "/usr/lib/python3.8/importlib/metadata.py", line 177, in from_name
raise PackageNotFoundError(name)
importlib.metadata.PackageNotFoundError: torchvision
TorchVision and PyTorch are different libraries.
Based on the error message, TorchVision is missing in your environment.
Please follow our document above to install it.
doruk@ubuntu:~/doruk/yolov8$ source yolov8/bin/activate
(yolov8) doruk@ubuntu:~/doruk/yolov8$ python
Python 3.8.10 (default, Nov 22 2023, 10:22:35)
[GCC 9.4.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import torchvision
>>> import torch
>>> print(torch.__version__)
2.1.0a0+41361538.nv23.06
>>> print('CUDA available: ' + str(torch.cuda.is_available()))
CUDA available: True
>>> exit()
(yolov8) doruk@ubuntu:~/doruk/yolov8$ yolo predict model=yolov8n.pt source='https://ultralytics.com/images/bus.jpg'
In the web Installing PyTorch for Jetson Platform - NVIDIA Docs " Installing PyTorch for Jetson Platform". There is a missing “;” in the command, after ‘1.16.1’. This causes to torch not being installed. If you could change this it will be good for all the newbies in Jetson.
Hi, did you solve the problem? I am having the same problem. I followed same steps in ultralytics docs.
(env3.8) jetson-orin@jetsonorin-desktop:~/Desktop/gpu$ python3
Type “help”, “copyright”, “credits” or “license” for more information.
import ultralytics
File “”, line 1, in
File “/home/jetson-orin/Desktop/gpu_cocacola/env3.8/lib/python3.8/site-packages/ultralytics/init.py”, line 10, in
File “/home/jetson-orin/Desktop/gpu_cocacola/env3.8/lib/python3.8/site-packages/ultralytics/data/init.py”, line 3, in
File “/home/jetson-orin/Desktop/gpu_cocacola/env3.8/lib/python3.8/site-packages/ultralytics/data/base.py”, line 17, in
File “/home/jetson-orin/Desktop/gpu_cocacola/env3.8/lib/python3.8/site-packages/ultralytics/data/utils.py”, line 19, in
File “/home/jetson-orin/Desktop/gpu_cocacola/env3.8/lib/python3.8/site-packages/ultralytics/nn/init.py”, line 3, in
File “/home/jetson-orin/Desktop/gpu_cocacola/env3.8/lib/python3.8/site-packages/ultralytics/nn/tasks.py”, line 10, in
File “/home/jetson-orin/Desktop/gpu_cocacola/env3.8/lib/python3.8/site-packages/ultralytics/nn/modules/init.py”, line 20, in
from .block import (
File “/home/jetson-orin/Desktop/gpu_cocacola/env3.8/lib/python3.8/site-packages/ultralytics/nn/modules/block.py”, line 8, in
from ultralytics.utils.torch_utils import fuse_conv_and_bn
File “/home/jetson-orin/Desktop/gpu_cocacola/env3.8/lib/python3.8/site-packages/ultralytics/utils/init.py”, line 47, in
TORCHVISION_VERSION = importlib.metadata.version(“torchvision”) # faster than importing torchvision
File “/usr/lib/python3.8/importlib/metadata.py”, line 530, in version
File “/usr/lib/python3.8/importlib/metadata.py”, line 503, in distribution
File “/usr/lib/python3.8/importlib/metadata.py”, line 177, in from_name
