janet
October 20, 2022, 2:13pm
1
We are using Pytorch Yolov5 with Strongsort on jetson nano with jetpack 4.5.1
We used PyTorch 1.10 with python3.6. We installed PyTorch using these links;
Below are pre-built PyTorch pip wheel installers for Jetson Nano, TX1/TX2, Xavier, and Orin with JetPack 4.2 and newer.
Download one of the PyTorch binaries from below for your version of JetPack, and see the installation instructions to run on your Jetson. These pip wheels are built for ARM aarch64 architecture, so run these commands on your Jetson (not on a host PC). You can also use the pre-built l4t-pytorch and l4t-ml container images and Dockerfiles .
PyTorch pip wheels
JetPack 5
PyTo…
opened 06:25AM - 28 Sep 22 UTC
documentation
enhancement
# Deploy on NVIDIA Jetson using TensorRT and DeepStream SDK
This guide explai… ns how to deploy a trained model into NVIDIA Jetson Platform and perform inference using TensorRT and DeepStream SDK. Here we use TensorRT to maximize the inference performance on the Jetson platform. UPDATED 18 November 2022.
## Hardware Verification
We have tested and verified this guide on the following Jetson devices
- [Seeed reComputer J1010 built with Jetson Nano module](https://www.seeedstudio.com/Jetson-10-1-A0-p-5336.html)
- [Seeed reComputer J2021 built with Jetson Xavier NX module](https://www.seeedstudio.com/reComputer-J2021-p-5438.html)
## Before You Start
Make sure you have properly installed **JetPack SDK** with all the **SDK Components** and **DeepStream SDK** on the Jetson device as this includes CUDA, TensorRT and DeepStream SDK which are needed for this guide.
JetPack SDK provides a full development environment for hardware-accelerated AI-at-the-edge development. All Jetson modules and developer kits are supported by JetPack SDK.
There are two major installation methods including,
1. SD Card Image Method
2. NVIDIA SDK Manager Method
You can find a very detailed installation guide from NVIDIA [official website](https://developer.nvidia.com/jetpack-sdk-461). Also you can find guides corresponding to the above-mentioned [reComputer J1010](https://wiki.seeedstudio.com/reComputer_J1010_J101_Flash_Jetpack) and [reComputer J2021](https://wiki.seeedstudio.com/reComputer_J2021_J202_Flash_Jetpack).
## Install Necessary Packages
- **Step 1.** Access the terminal of Jetson device, install pip and upgrade it
```sh
sudo apt update
sudo apt install -y python3-pip
pip3 install --upgrade pip
- **Step 2.** Clone the following repo
```sh
git clone https://github.com/ultralytics/yolov5
- **Step 3.** Open **requirements.txt**
```sh
cd yolov5
vi requirements.txt
- **Step 5.** Edit the following lines. Here you need to press **i** first to enter editing mode. Press **ESC**, then type **:wq** to save and quit
```sh
# torch>=1.7.0
# torchvision>=0.8.1
**Note:** torch and torchvision are excluded for now because they will be installed later.
- **Step 6.** install the below dependency
```sh
sudo apt install -y libfreetype6-dev
- **Step 7.** Install the necessary packages
```sh
pip3 install -r requirements.txt
## Install PyTorch and Torchvision
We cannot install PyTorch and Torchvision from pip because they are not compatible to run on Jetson platform which is based on **ARM aarch64 architecture**. Therefore we need to manually install pre-built PyTorch pip wheel and compile/ install Torchvision from source.
Visit [this page](https://forums.developer.nvidia.com/t/pytorch-for-jetson) to access all the PyTorch and Torchvision links.
Here are some of the versions supported by JetPack 4.6 and above.
**PyTorch v1.10.0**
Supported by JetPack 4.4 (L4T R32.4.3) / JetPack 4.4.1 (L4T R32.4.4) / JetPack 4.5 (L4T R32.5.0) / JetPack 4.5.1 (L4T R32.5.1) / JetPack 4.6 (L4T R32.6.1) with Python 3.6
**file_name:** torch-1.10.0-cp36-cp36m-linux_aarch64.whl
**URL:** https://nvidia.box.com/shared/static/fjtbno0vpo676a25cgvuqc1wty0fkkg6.whl
**PyTorch v1.12.0**
Supported by JetPack 5.0 (L4T R34.1.0) / JetPack 5.0.1 (L4T R34.1.1) / JetPack 5.0.2 (L4T R35.1.0) with Python 3.8
**file_name:** torch-1.12.0a0+2c916ef.nv22.3-cp38-cp38-linux_aarch64.whl
**URL:** https://developer.download.nvidia.com/compute/redist/jp/v50/pytorch/torch-1.12.0a0+2c916ef.nv22.3-cp38-cp38-linux_aarch64.whl
- **Step 1.** Install torch according to your JetPack version in the following format
```sh
wget <URL> -O <file_name>
pip3 install <file_name>
For example, here we are running **JP4.6.1** and therefore we choose **PyTorch v1.10.0**
```sh
cd ~
sudo apt-get install -y libopenblas-base libopenmpi-dev
wget https://nvidia.box.com/shared/static/fjtbno0vpo676a25cgvuqc1wty0fkkg6.whl -O torch-1.10.0-cp36-cp36m-linux_aarch64.whl
pip3 install torch-1.10.0-cp36-cp36m-linux_aarch64.whl
- **Step 2.** Install torchvision depending on the version of PyTorch that you have installed. For example, we chose **PyTorch v1.10.0**, which means, we need to choose **Torchvision v0.11.1**
```sh
sudo apt install -y libjpeg-dev zlib1g-dev
git clone --branch v0.11.1 https://github.com/pytorch/vision torchvision
cd torchvision
sudo python3 setup.py install
Here a list of the corresponding torchvision version that you need to install according to the PyTorch version:
- PyTorch v1.10 - torchvision v0.11.1
- PyTorch v1.12 - torchvision v0.13.0
## DeepStream Configuration for YOLOv5
- **Step 1.** Clone the following repo
```sh
cd ~
git clone https://github.com/marcoslucianops/DeepStream-Yolo
- **Step 2.** Copy **gen_wts_yoloV5.py** from **DeepStream-Yolo/utils** into **yolov5** directory
```sh
cp DeepStream-Yolo/utils/gen_wts_yoloV5.py yolov5
- **Step 3.** Inside the yolov5 repo, download **pt file** from YOLOv5 releases (example for YOLOv5s 6.1)
```sh
cd yolov5
wget https://github.com/ultralytics/yolov5/releases/download/v6.1/yolov5s.pt
- **Step 4.** Generate the **cfg** and **wts** files
```sh
python3 gen_wts_yoloV5.py -w yolov5s.pt
**Note**: To change the inference size (defaut: 640)
```sh
-s SIZE
--size SIZE
-s HEIGHT WIDTH
--size HEIGHT WIDTH
Example for 1280:
-s 1280
or
-s 1280 1280
- **Step 5.** Copy the generated **cfg** and **wts** files into the **DeepStream-Yolo** folder
```sh
cp yolov5s.cfg ~/DeepStream-Yolo
cp yolov5s.wts ~/DeepStream-Yolo
- **Step 6.** Open the **DeepStream-Yolo** folder and compile the library
```sh
cd ~/DeepStream-Yolo
CUDA_VER=11.4 make -C nvdsinfer_custom_impl_Yolo # for DeepStream 6.1
CUDA_VER=10.2 make -C nvdsinfer_custom_impl_Yolo # for DeepStream 6.0.1 / 6.0
- **Step 7.** Edit the **config_infer_primary_yoloV5.txt** file according to your model
```sh
[property]
custom-network-config=yolov5s.cfg
model-file=yolov5s.wts
- **Step 8.** Edit the **deepstream_app_config** file
```sh
[primary-gie]
config-file=config_infer_primary_yoloV5.txt
- **Step 9.** Change the video source in **deepstream_app_config** file. Here a default video file is loaded as you can see below
```sh
[source0]
uri=file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_1080p_h264.mp4
## Run the Inference
```sh
deepstream-app -c deepstream_app_config.txt
<div align=center><img width=1000 src="https://files.seeedstudio.com/wiki/YOLOV5/FP32-yolov5s.gif"/></div>
The above result is running on **Jetson Xavier NX** with **FP32** and **YOLOv5s 640x640**. We can see that the **FPS** is around **30**.
## INT8 Calibration
If you want to use INT8 precision for inference, you need to follow the steps below
- **Step 1.** Install OpenCV
```sh
sudo apt-get install libopencv-dev
- **Step 2.** Compile/recompile the **nvdsinfer_custom_impl_Yolo** library with OpenCV support
```sh
CUDA_VER=11.4 OPENCV=1 make -C nvdsinfer_custom_impl_Yolo # for DeepStream 6.1
CUDA_VER=10.2 OPENCV=1 make -C nvdsinfer_custom_impl_Yolo # for DeepStream 6.0.1 / 6.0
- **Step 3.** For COCO dataset, download the [val2017](https://drive.google.com/file/d/1gbvfn7mcsGDRZ_luJwtITL-ru2kK99aK/view?usp=sharing), extract, and move to **DeepStream-Yolo** folder
- **Step 4.** Make a new directory for calibration images
```sh
mkdir calibration
- **Step 5.** Run the following to select 1000 random images from COCO dataset to run calibration
```sh
for jpg in $(ls -1 val2017/*.jpg | sort -R | head -1000); do \
cp ${jpg} calibration/; \
done
**Note:** NVIDIA recommends at least 500 images to get a good accuracy. On this example, 1000 images are chosen to get better accuracy (more images = more accuracy). Higher INT8_CALIB_BATCH_SIZE values will result in more accuracy and faster calibration speed. Set it according to you GPU memory. You can set it from **head -1000**. For example, for 2000 images, **head -2000**. This process can take a long time.
- **Step 6.** Create the **calibration.txt** file with all selected images
```sh
realpath calibration/*jpg > calibration.txt
- **Step 7.** Set environment variables
```sh
export INT8_CALIB_IMG_PATH=calibration.txt
export INT8_CALIB_BATCH_SIZE=1
- **Step 8.** Update the **config_infer_primary_yoloV5.txt** file
From
```sh
model-engine-file=model_b1_gpu0_fp32.engine
#int8-calib-file=calib.table
network-mode=0
To
```sh
model-engine-file=model_b1_gpu0_int8.engine
network-mode=1
- **Step 9.** Run the inference
```sh
<div align=center><img width=1000 src="https://files.seeedstudio.com/wiki/YOLOV5/INT8-yolov5s.gif"/></div>
The above result is running on **Jetson Xavier NX** with **INT8** and **YOLOv5s 640x640**. We can see that the **FPS** is around **60**.
## Benchmark results
The following table summarizes how different models perform on **Jetson Xavier NX**.
|Model Name | Precision |Inference Size |Inference Time (ms) | FPS |
|YOLOv5s | FP32 | 320x320 | 16.66 | 60 |
| | FP32 | 640x640 | 33.33 | 30 |
| | INT8 | 640x640 | 16.66 | 60 |
| YOLOv5n | FP32 | 640x640 | 16.66 | 60 |
### Additional
This tutorial is written by our friends at seeed @lakshanthad and Elaine
We notice that wherever we start the app, only the CPU is being used and we were not able to activate GPU. Also, when we run torch.cuda.is_available(), we get False.
Could you help us figure out a solution?
Hi @janet , are you sure that a generic PyTorch package didn’t get installed when installing the YOLO dependencies? You might want to try doing pip3 uninstall torch, and then re-install the PyTorch 1.10 wheel for Jetson (that wheel was built with CUDA enabled)
Then try running this to confirm that PyTorch detects your GPU:
python3 -c 'import torch; print(torch.cuda.is_available())'
If that still returns false, then I recommend to try running the CUDA deviceQuery sample to make sure that the GPU driver is working:
cd /usr/local/cuda/samples/1_Utilities/deviceQuery
sudo make
./deviceQuery
