Hi i am runnng yolov5 on jetson nano. Cant seem to get GPU to work.
Used both jetpack 4.4.1 & 4.5 version.
Still no success.
Driver installed.
root@f44cb67ac6b7:/yolov5/docker_yolov5/standard# nvcc -V
Copyright (c) 2005-2019 NVIDIA Corporation
Built on Wed_Oct_23_21:14:42_PDT_2019
Cuda compilation tools, release 10.2, V10.2.89
Here is yolov5 on docker container
root@f44cb67ac6b7:/yolov5/docker_yolov5/standard# python3 detect.py --source ./data/images/zidane.jpg --conf 0.5
Namespace(agnostic_nms=False, augment=False, classes=None, conf_thres=0.5, device=‘’, exist_ok=False, hide_conf=False, hide_labels=False, img_size=640, iou_thres=0.45, line_thickness=3, name=‘exp’, nosave=False, project=‘runs/detect’, save_conf=False, save_crop=False, save_txt=False, source=‘./data/images/zidane.jpg’, update=False, view_img=False, weights=‘yolov5s.pt’)
/usr/local/lib/python3.6/dist-packages/torch/cuda/init.py:52: UserWarning: CUDA initialization: Found no NVIDIA driver on your system. Please check that you have an NVIDIA GPU and installed a driver from Official Drivers | NVIDIA (Triggered internally at /media/nvidia/WD_NVME/PyTorch/JetPack_4.4.1/pytorch-v1.7.0/c10/cuda/CUDAFunctions.cpp:100.)
return torch._C._cuda_getDeviceCount() > 0
YOLOv5 \U0001f680 v5.0-75-g91547ed torch 1.7.0 CPU
Downloading https://github.com/ultralytics/yolov5/releases/download/v5.0/yolov5s.pt to yolov5s.pt…
100%|######################################| 14.1M/14.1M [00:02<00:00, 7.33MB/s]
Fusing layers…
Model Summary: 224 layers, 7266973 parameters, 0 gradients
image 1/1 /yolov5/docker_yolov5/standard/data/images/zidane.jpg: 384x640 2 persons, 1 tie, Done. (1.313s)
Results saved to runs/detect/exp
Done. (1.469s)
(env) test1@test1-desktop:~/thesis/yolov5$ python3 detect.py --weights burn_best.pt --source video6.mov
Namespace(agnostic_nms=False, augment=False, classes=None, conf_thres=0.25, device=‘’, exist_ok=False, half=False, hide_conf=False, hide_labels=False, imgsz=640, iou_thres=0.45, line_thickness=3, max_det=1000, name=‘exp’, nosave=False, project=‘runs/detect’, save_conf=False, save_crop=False, save_txt=False, source=‘video6.mov’, update=False, view_img=False, weights=[‘burn_best.pt’])
YOLOv5 🚀 v5.0-187-g6062319 torch 1.8.1 CPU
when manually select GPU
python3 detect.py --source ./data/images/zidane.jpg --conf 0.5 --device 0
AssertionError: CUDA unavailable, invalid device 0 requested
Kindly anyone help me find solution for this
Thanks everyone
