I’m trying to run Yolov5 on my jetson nano GPU, but i’m facing many problems:
- I’m not able to see the a message like this:
 “Detected 1 CUDA Capable device(s)”
 when i run:
 /usr/local/cuda/samples/1_Utilities/deviceQuery
 sudo make
- I get"false" when i run:
 import torch
 torch.cuda.is_available()
I tried using Jetpack 4.5 and 4.6 and i had the same problem.
Does anybody know which versions and dependencies should i use?
Thanks in advance.
