Pytorch runtime issue on Jetson Orin Nano
I installed pytorch as the guide says Installing PyTorch for Jetson Platform
But it’s quite weird, see below:
  • First time install
$ python3 -m pip install --no-cache --user $TORCH_INSTALL
Collecting torch==2.3.0a0+6ddf5cf85e.nv24.04.14026654
  Downloading https://developer.download.nvidia.cn/compute/redist/jp/v60dp/pytorch/torch-2.3.0a0+6ddf5cf85e.nv24.04.14026654-cp310-cp310-linux_aarch64.whl (1035.7 MB)
     ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 1.0/1.0 GB 8.9 MB/s eta 0:00:00
Requirement already satisfied: filelock in /usr/local/lib/python3.10/dist-packages (from torch==2.3.0a0+6ddf5cf85e.nv24.04.14026654) (3.13.1)
Requirement already satisfied: typing-extensions>=4.8.0 in /usr/local/lib/python3.10/dist-packages (from torch==2.3.0a0+6ddf5cf85e.nv24.04.14026654) (4.9.0)
Requirement already satisfied: sympy in /usr/lib/python3/dist-packages (from torch==2.3.0a0+6ddf5cf85e.nv24.04.14026654) (1.9)
Requirement already satisfied: networkx in /usr/local/lib/python3.10/dist-packages (from torch==2.3.0a0+6ddf5cf85e.nv24.04.14026654) (3.2.1)
Requirement already satisfied: jinja2 in /usr/local/lib/python3.10/dist-packages (from torch==2.3.0a0+6ddf5cf85e.nv24.04.14026654) (3.1.3)
Requirement already satisfied: fsspec in /usr/local/lib/python3.10/dist-packages (from torch==2.3.0a0+6ddf5cf85e.nv24.04.14026654) (2024.2.0)
Requirement already satisfied: MarkupSafe>=2.0 in ./.local/lib/python3.10/site-packages (from jinja2->torch==2.3.0a0+6ddf5cf85e.nv24.04.14026654) (2.1.5)
Installing collected packages: torch
  Attempting uninstall: torch
    Found existing installation: torch 2.2.2
    Uninstalling torch-2.2.2:
      Successfully uninstalled torch-2.2.2
ERROR: pip's dependency resolver does not currently take into account all the packages that are installed. This behaviour is the source of the following dependency conflicts.
torchaudio 2.2.2 requires torch==2.2.2, but you have torch 2.3.0a0+6ddf5cf85e.nv24.4 which is incompatible.
torchvision 0.17.2 requires torch==2.2.2, but you have torch 2.3.0a0+6ddf5cf85e.nv24.4 which is incompatible.
Successfully installed torch-2.3.0a0+6ddf5cf85e.nv24.4
  • Second time install
$ python3 -m pip install --no-cache --user $TORCH_INSTALLpython3 -m pip install --upgrade pip; python3 -m pip install numpy==’1.26.1’; python3 -m pip install --no-cache $TORCH_INSTALL^C
daniel@daniel-nvidia:~$ python3 -m pip install --upgrade pip; python3 -m pip install numpy==’1.26.1’; python3 -m pip install --no-cache $TORCH_INSTALL
Requirement already satisfied: pip in /usr/local/lib/python3.10/dist-packages (24.0)
ERROR: Could not find a version that satisfies the requirement numpy==’1.26.1’ (from versions: 1.3.0, 1.4.1, 1.5.0, 1.5.1, 1.6.0, 1.6.1, 1.6.2, 1.7.0, 1.7.1, 1.7.2, 1.8.0, 1.8.1, 1.8.2, 1.9.0, 1.9.1, 1.9.2, 1.9.3, 1.10.0.post2, 1.10.1, 1.10.2, 1.10.4, 1.11.0, 1.11.1, 1.11.2, 1.11.3, 1.12.0, 1.12.1, 1.13.0, 1.13.1, 1.13.3, 1.14.0, 1.14.1, 1.14.2, 1.14.3, 1.14.4, 1.14.5, 1.14.6, 1.15.0, 1.15.1, 1.15.2, 1.15.3, 1.15.4, 1.16.0, 1.16.1, 1.16.2, 1.16.3, 1.16.4, 1.16.5, 1.16.6, 1.17.0, 1.17.1, 1.17.2, 1.17.3, 1.17.4, 1.17.5, 1.18.0, 1.18.1, 1.18.2, 1.18.3, 1.18.4, 1.18.5, 1.19.0, 1.19.1, 1.19.2, 1.19.3, 1.19.4, 1.19.5, 1.20.0, 1.20.1, 1.20.2, 1.20.3, 1.21.0, 1.21.1, 1.21.2, 1.21.3, 1.21.4, 1.21.5, 1.21.6, 1.22.0, 1.22.1, 1.22.2, 1.22.3, 1.22.4, 1.23.0rc1, 1.23.0rc2, 1.23.0rc3, 1.23.0, 1.23.1, 1.23.2, 1.23.3, 1.23.4, 1.23.5, 1.24.0rc1, 1.24.0rc2, 1.24.0, 1.24.1, 1.24.2, 1.24.3, 1.24.4, 1.25.0rc1, 1.25.0, 1.25.1, 1.25.2, 1.26.0b1, 1.26.0rc1, 1.26.0, 1.26.1, 1.26.2, 1.26.3, 1.26.4, 2.0.0b1, 2.0.0rc1, 2.0.0rc2)
ERROR: No matching distribution found for numpy==’1.26.1’
     ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 1.0/1.0 GB 11.1 MB/s eta 0:00:00
  • Run program got error below, it’s OK with torch 2.2.2 CPU version
RuntimeError                              Traceback (most recent call last)
Cell In[1], line 5
      3 import matplotlib.pyplot as plt
      4 import torch
----> 5 import torchvision.transforms as T
      6 import torchvision
      7 import torch
File ~/.local/lib/python3.10/site-packages/torchvision/__init__.py:6
      3 from modulefinder import Module
      5 import torch
----> 6 from torchvision import _meta_registrations, datasets, io, models, ops, transforms, utils
      8 from .extension import _HAS_OPS
     10 try:
File ~/.local/lib/python3.10/site-packages/torchvision/_meta_registrations.py:164
    153     torch._check(
    154         grad.dtype == rois.dtype,
    155         lambda: (
    158         ),
    159     )
    160     return grad.new_empty((batch_size, channels, height, width))
    163 @torch._custom_ops.impl_abstract("torchvision::nms")
--> 164 def meta_nms(dets, scores, iou_threshold):
    165     torch._check(dets.dim() == 2, lambda: f"boxes should be a 2d tensor, got {dets.dim()}D")
    166     torch._check(dets.size(1) == 4, lambda: f"boxes should have 4 elements in dimension 1, got {dets.size(1)}")
File ~/.local/lib/python3.10/site-packages/torch/library.py:467, in impl_abstract.<locals>.inner(func)
    464 else:
    465     func_to_register = func
--> 467 handle = entry.abstract_impl.register(func_to_register, source)
    468 if lib is not None:
    469     lib._registration_handles.append(handle)
File ~/.local/lib/python3.10/site-packages/torch/_library/abstract_impl.py:30, in AbstractImplHolder.register(self, func, source)
     24 if self.kernel is not None:
     25     raise RuntimeError(
     26         f"impl_abstract(...): the operator {self.qualname} "
     27         f"already has an abstract impl registered at "
     28         f"{self.kernel.source}."
     29     )
---> 30 if torch._C._dispatch_has_kernel_for_dispatch_key(self.qualname, "Meta"):
     31     raise RuntimeError(
     32         f"impl_abstract(...): the operator {self.qualname} "
     33         f"already has an DispatchKey::Meta implementation via a "
     36         f"impl_abstract."
     37     )
     39 if torch._C._dispatch_has_kernel_for_dispatch_key(
     40     self.qualname, "CompositeImplicitAutograd"
     41 ):
RuntimeError: operator torchvision::nms does not exist
Can anyone help to fix the issue?
It looks like the compatibility issue between PyTorch and TorchVision.
Could you share which TorchVision version do you use?
We recently have a prebuilt package of TorchVision and TorchAudio in the below link.
This should help your to get a working package directly:
Well (PyTorch for Jetson), it works, thanks.
