i am working with jetson orin now and happened to install jetpack 6.2,so now I want to use the gpu in my code,so i want to install pytorch ,but i am not able to find a compatible version for my purpose,so can someone please provide me the answer for this query
hey,thank you for the link,but is the torch and the torchvision compatible,because i get error that says,operator torchvision::nms does’nt exist(for sentence transformers).
Could you please clarify this
There are some different PyTorch versions on the link.
Please try the below command for the specific steps:
hey
i did install pytorch2.5.0,but i am not able to find a compatible torchaudio for this.
let me know if you know the answer
thanks
I am facing the same error with PyTorch 2.6.0rc1 and TorchVision 0.20.0 on Jetpack 6.2. Can someone tell me if I should downgrade to Jetpack 6.1 to use gpu in my code or someother Jetpack version?
hi,
try jetpack 6.1 as the higher version has few issues
Hi, all
Please try below for the packages for JetPack 6.2:
$ pip3 install 'numpy<2'
$ wget https://pypi.jetson-ai-lab.dev/jp6/cu126/+f/6cc/6ecfe8a5994fd/torch-2.6.0-cp310-cp310-linux_aarch64.whl#sha256=6cc6ecfe8a5994fd6d58fb6d6eb73ff2437428bb4953f3ebaa409f83a5f4db99
$ wget https://pypi.jetson-ai-lab.dev/jp6/cu126/+f/aa2/2da8dcf4c4c8d/torchvision-0.21.0-cp310-cp310-linux_aarch64.whl#sha256=aa22da8dcf4c4c8dc897e7922b1ef25cb0fe350e1a358168be87a854ad114531
$ wget https://pypi.jetson-ai-lab.dev/jp6/cu126/+f/dda/ce98dc7d89263/torchaudio-2.6.0-cp310-cp310-linux_aarch64.whl#sha256=ddace98dc7d892634d2e5b08593436f3e3b1247a1cb11c0d5f4e5ccf64a9be8c
$ pip3 install --force torch-2.6.0-cp310-cp310-linux_aarch64.whl
$ pip3 install --force torchvision-0.21.0-cp310-cp310-linux_aarch64.whl
$ pip3 install --force torchaudio-2.6.0-cp310-cp310-linux_aarch64.whl
$ python3
Python 3.10.12 (main, Nov 6 2024, 20:22:13) [GCC 11.4.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import torch
>>> import torchvision
>>> import torchaudio
>>> torch.__version__
'2.6.0'
>>> torchvision.__version__
'0.21.0'
>>> torchaudio.__version__
'2.6.0'
hi,
i get this error while checking
import torchvision
File “”, line 1, in
File “/home/san-jetson-orin/.local/lib/python3.10/site-packages/torchvision/init.py”, line 10, in
from torchvision import _meta_registrations, datasets, io, models, ops, transforms, utils # usort:skip
File “/home/san-jetson-orin/.local/lib/python3.10/site-packages/torchvision/_meta_registrations.py”, line 164, in
def meta_nms(dets, scores, iou_threshold):
File “/home/san-jetson-orin/.local/lib/python3.10/site-packages/torch/library.py”, line 828, in register
use_lib._register_fake(op_name, func, _stacklevel=stacklevel + 1)
File “/home/san-jetson-orin/.local/lib/python3.10/site-packages/torch/library.py”, line 198, in _register_fake
handle = entry.fake_impl.register(func_to_register, source)
File “/home/san-jetson-orin/.local/lib/python3.10/site-packages/torch/_library/fake_impl.py”, line 31, in register
if torch._C._dispatch_has_kernel_for_dispatch_key(self.qualname, “Meta”):
RuntimeError: operator torchvision::nms does not exist
Could you double-check the version?
The above commands work in our environment.
I am now using Jetpack 6.1 and I am now able to use GPU in my code but for some weird reason, I noticed that TensorRT was not present in my Jetpack 6.1
