RuntimeError: operator torchvision::nms does not exist
Hello, I am currently trying to set up PyTorch and Torchvision on my Jetson Orin Nano.
  1. Using JP 6.1
    I followed the instructions from ๐Ÿš… Initial Setup Guide - Jetson Orin Nano - NVIDIA Jetson AI Lab and were able to install pytorch 2.5 with cuda support (from here: developer.download.nvidia.com/compute/redist/jp/v61/pytorch/). Unfortunately, i am not able to install the matching torchvision version.
  2. Tried using JetPack 6.0
    Then i tried the same using jetpack 6 image from here: JetPack SDK 6.0 | NVIDIA Developer
    Installed torchvision as well as built it from source but ran into the same error as with jetpack 6.1.
Error message when importing torchvision:
I would appreciate any help with this, thank you.
I wouldnโ€™t mind if you enable me to use JP 6.0 or 6.1. Important would be to not use a container or venv.
You can find PyTorch and TorchVision for JetPack 6.1 below:
http://jetson.webredirect.org/jp6/cu126
Hi thereโ€™s still version incompatibility between the torch and torch vision downloaded from the above link for jetpack 6.1 rev 1. If I try to import torchvision after installing both wheels, I get a operator torchvision :: nms does not exist
Thanks, it looks like there are some issues with PyTorch 2.6.0rc1 and TorchVision 0.20.0.
Please use the PyTorch 2.5.0 and TorchVision 0.19.1 instead (compatible to JetPack 6.1):
$ wget https://pypi.jetson-ai-lab.dev/jp6/cu126/+f/5cf/9ed17e35cb752/torch-2.5.0-cp310-cp310-linux_aarch64.whl#sha256=5cf9ed17e35cb7523812aeda9e7d6353c437048c5a6df1dc6617650333049092 -O torch-2.5.0-cp310-cp310-linux_aarch64.whl
$ pip3 install torch-2.5.0-cp310-cp310-linux_aarch64.whl
$ wget https://pypi.jetson-ai-lab.dev/jp6/cu126/+f/9d2/6fac77a4e832a/torchvision-0.19.1a0+6194369-cp310-cp310-linux_aarch64.whl#sha256=9d26fac77a4e832a3a2a547543aabc6256b6f94b6531f6a94a762989db4535f8 -O torchvision-0.19.1a0+6194369-cp310-cp310-linux_aarch64.whl
$ pip3 install torchvision-0.19.1a0+6194369-cp310-cp310-linux_aarch64.whl
We can import both PyTorch and TorchVision without issues:
$ python3
Python 3.10.12 (main, Sep 11 2024, 15:47:36) [GCC 11.4.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import torch
>>> import torchvision
>>> torch.__version__
'2.5.0'
>>> torchvision.__version__
'0.19.1a0+6194369'
We got it setup with torch 2.6.0rc1 and Torchvision 0.20.0 by following these steps:
  1. Flash JP6.1 rev1 Image from here:
    ๐Ÿš€ Initial Setup Guide - NVIDIA Jetson AI Lab
  2. Install Cuda Keyring and libcusparselt
wget https://developer.download.nvidia.com/compute/cuda/repos/ubuntu2204/arm64/cuda-keyring_1.1-1_all.deb
sudo dpkg -i cuda-keyring_1.1-1_all.deb
sudo apt-get update
sudo apt-get -y install libcusparselt0 libcusparselt-dev
  1. Install python3.10-venv and python3-pip
sudo apt install python3.10-venv
sudo apt install python3-pip
  1. Install pytorch, torchvision and torchaudio for jp61
pip install torch torchvision torchaudio --index-url http://108.39.248.12:81/jp6/cu126/+simple/ --trusted-host 108.39.248.12
  1. Verify PyTorch and TorchVision installation:
python3 / python
import torch
torch.__version__
	>>> '2.5.0'
torch.cuda.is_available()
	>>> True
torch.cuda.device_count()
	>>> 1
torch.cuda.current_device()
	>>> 0
torch.cuda.device(0)
	>>> <torch.cuda.device at 0x7efce0b03be0>
torch.cuda.get_device_name(0)
	>>> 'Orin'
import torchvision
	>>> '0.20.0'
Good to know it works now.
Could you also share how you prepare the torch, torchvision, and torchaudio packages on @108.39.248.12?
Do you download them from the jp6/cu126 index?
