Commercially Available Rack/Cooling for 1+N Sparks?
Lot’s of great shares of custom 3D printed cooling/racking solutions, I have been searching and cant seem to find any commercially available. I am looking for something desktop to grow with 1-4 Sparks, the fans can be USB-C so they can be plugged in. I am not finding much, anyone else find anything?
There are commercial rack mount options, but none that includes cooling. I ended up designing my own desktop solution in the end. Will share the results once the fans are here end of July.
I recently spotted this on Amazon. I haven’t bought it and it has no reviews, so can’t say if it’s any good.
The guy that designed that cooler posted the 3d models to print on this forum a few months ago:
The cooler is working fine as long as you don’t mind hiding your Sparks.
This is what I use in my 5U under desk rack that I have my 4 nodes and my switch installed
Amazon.com: AC Infinity CLOUDPLATE T6, Rack Mount Fan 1U, Front Exhaust Airflow, for Cooling AV, Home Theater, Network 19” Racks : Electronics they have front and rear exhaust, since my rack is at the front of the my desk, so front exhaust so heat doesn’t get trapped under the desk.
Thats a design that one of the users on this forum created.
do the 5U fit 4x spark and switch as well as all the power adapter?
I have the 4 sparks the switch and the exhaust plate, not the power adapters those would just add more heat into the rack and eliminate holding the exhaust plate.
10 dollars notebook table with two big coolers. Eighth 1 dollar 5 сm height legs on double sided scotch. It’s my cooling recipe. 🤔🙂
Disclosure: I’m the maker, so take this with that in mind. Since you asked about commercial options, I just posted one in Projects called the Stackcooler TP2. It’s a desktop aluminum stand with a clear cover that holds two Sparks stacked and uses their built-in magnets to hold them in place.
To be upfront about where it falls short of your list: each one holds two Sparks, not 1–4, and the included 120mm Noctua fan runs off a 12V adapter, not USB-C. You can also order it without the fan or without the adapter. It’s US only for now and ships in about 4–6 weeks.
I use this in my 5U underdesk rack with my ASUS GX10’s and never have any issues.Make sure you plan the exhaust properly, if your rack sits at the front you want front exhaust so it doesn’t get trapped under the desk and vice versa if the rack is mounted towards the rear.
I’ve done 5-7 days full custom quant runs with my GX10s at 90%+ utilization and have 0 issues.
I do also have a set of silentwings pro at the back of the rack with negative pressure pulling heat out the side as well
