It’s not totally new, diffusion models have been around for quite some time, they are used for image generation. As well as there were attempts at text generation with diffusion.
It’s the same MoE Gemma with different generation strategy I think. Should be faster, at the cost of quality.
Not having played with text generation diffusion models before, I found it interesting that the T/S increased with the tg values up to about 4k, then drops off significantly…
It’s fast, but for very specific use cases, definitely not for main agentic use. Looks to be working with tooling, but only for generation with no input.
Hopefully someone would figure out some sort of smart AR/DG hybrid.
Wall-clock probe — input/output size sweep
Case
prompt tok
out tok
wall (s)
tok/s
finish
tiny-in / tiny-out
16
13
0.38
34.3
stop
short-in / med-out
22
121
1.39
87.2
stop
short-in / long-out
25
714
5.03
142.1
stop
med-in / med-out
782
72
0.94
76.6
stop
long-in / short-out
3060
35
1.18
29.6
stop
All stop, no truncation, coherent output.
Findings
Throughput rises with output length (opposite of AR, which is flat): 34 → 87 → 142 tok/s as output grows 13 → 121 → 714. A fixed per-request denoising cost (~0.38s floor) dominates short outputs and amortizes over long ones.
Input context is expensive: 3060-token prompt + 35-token output collapses to 29.6 tok/s — full-sequence attention per denoising step makes prefill dominate when output is short. TTFR climbs 3.2s → 20.4s from depth 0 → 32K.
No low-latency mode: ~0.38s floor on any request; ~3s+ TTFR. No sub-100ms first token.
Baseline: AR Gemma-4 26B-A4B ≈ 23.7 tok/s flat on the same box. DiffusionGemma wins ~6× for long outputs, converges to ~30 for short-output/long-input.
Routing implication: good for a bulk/long-form fast lane; not a fit for recall extraction (longish input, short structured output — keep on an AR model).
I’m only seeing about double, but I hope it is just a poorly optimized stack that gets better over time. I’ve seen many other models get significantly faster after release.
With the normal Gemma 4 26B QAT MTP under llama-server, I see 100 tokens per second output very consistently. If you’re only seeing a quarter of that, then something is not correct with your setup, or you’re using the 16-bit model, which I struggle to recommend when QAT is virtually indistinguishable. (If 26B A4B QAT isn’t good enough, then the 16 bit version won’t be good enough either… it’s time for a better model altogether.)
Moved a text-only workload over and saw similar behavior as the benchmark above: good throughput for medium sized one-shot responses, meh responsiveness and hangs with tool calling.
I started digging into testing google/diffusiongemma-26B-A4B-it in vLLM today and am seeing it perform as well in tool calling scenarios as the non-diffusion Gemma4 26B-A4B. Initial BFCL (older tool calling leaderboard) eval results show it doing quite decent - better than I expected for their first diffusion model release.
Now, in vLLM this model triggers a lot of bugs in our gemma4 tool call parser when using it in streaming mode. I have an entirely new streaming parser engine PR open upstream in vLLM that first fixes issues for Qwen3. Gemma4 will be submitted as a fast followup to that once the engine + Qwen3 merges, and this should clean up the streaming tool calls for this model (and existing Gemma4 models when used with speculative decoding, like MTP, enabled). Anyone feeling adventurous can build from my branch at GitHub - bbrowning/vllm at streaming-parser-engine-2 · GitHub to get the updated qwen3 and gemma4 reasoning and tool parsers if you want to test streaming tool calls with diffusiongemma or regular Qwen3.5/3.6 or Gemma4 with MTP enabled.
Do NOT try to use this model with structured outputs in vLLM yet (including tool_choice="required"), as that frequently causes crashes when I try. This is something we’ll have to work through on the vLLM side, and not too unusual for a branch new type of model like this.
Here are the results of tool-eval-bench, skipping the categories that test structured outputs but including hardmode. 82/100 overall. These were run on an H100 because my DGX Spark was busy running other tasks today. But, just to give a baseline of model expectations.
tool-eval-bench \
--seed 42 \
--hardmode \
--parallel 2 \
--categories A B C D E F G I J K L M N P
I had fixes for it in day0 community release, at least it was passing the tool-bench-eval without crashing. I believe vLLM have merged it at least partially yesterday.
This model is practically unusable. It can’t handle tool-use properly, and it’s been politically pre-trained — labeling everything as fake news over the smallest detail.
Two examples from my test:
It was supposed to translate a French X tweet. The post discussed the topic of Belfast in harsh terms. The model refused, saying it wouldn’t do it because it constitutes"hate speech." Fact is: yes, the post was written very harshly. But it’s not the model’s job to decide for me what’s good or right. It should just translate.
It was supposed to research “Fable 5.” Since it wasn’t capable enough for web search, it claimed that Fable 5 doesn’t exist. It accused me of trying to ask about fakenews. In an image analysis task (extracting text from an image), it concluded by saying that the text contained information that was “allegedly false.” That wasn’t the task.
In my case I was getting EngineDeadErrors from tool_choice=“required” tests with DiffusionGemma. Things are moving fast upstream, and I’m about a day behind at this point of my build and testing. So, it’s possible. I also see some open PRs cleaning some of this up. The general intersection of multi-token (whether via DiffusionGemma or spec decoding) and structured outputs is not in a good place generally upstream right now.
