Gemma 4 31B on DGX Spark: Runtime FP8 Benchmarks — Single & Dual Node (TP=2)
Gemma 4 31B dense benchmarks on DGX Spark with runtime FP8 quantization. Includes single-node (TP=1), dual-node (TP=2), multi-user concurrency, tool calling validation, and multimodal vision. Getting Gemma 4 running on vLLM required working around several issues — documenting everything here for anyone else attempting this.
Setup
  • Hardware: NVIDIA DGX Spark (1x GB10, 128GB unified memory)
  • Model: google/gemma-4-31B-it (BF16 base, runtime dynamic FP8)
  • vLLM: 0.19.1rc1.dev31+ga88ce94bb (April 4 build, includes PR #38826)
  • Container: vllm-node-tf5 (transformers 5 baked in)
  • Quantization: --quantization fp8 --kv-cache-dtype fp8
  • Context: 65,536 tokens | GPU mem utilization: 0.85 | TP: 1 and 2
  • Attention: Triton (forced — Gemma 4 has heterogeneous head dims: 256 local / 512 global)
  • Compilation: torch.compile enabled, VLLM_DISABLE_COMPILE_CACHE=1 (see workarounds below)
  • Mods: fix-gemma4-reasoning (#38855), fix-gemma4-tool-parser (PR #38909)
  • Benchmark: llama-benchy 0.3.5, 3 runs per config
Workarounds required
  1. transformers >= 5.0 — The gemma4 architecture isn’t in transformers 4.x. Using vllm-node-tf5 container which has transformers 5 baked in (avoids pip dependency conflicts from runtime upgrade).
  2. Runtime FP8 instead of pre-quantized checkpoints — Pre-quantized FP8 models (e.g. protoLabsAI/gemma-4-31B-it-FP8) fail with KeyError: 'layers.0.mlp.down_proj.weight_scale' in gemma4.py load_weights. Same class of bug as vllm #38912. Using the BF16 base model with --quantization fp8 works fine — the GB10’s 128GB unified memory handles the ~59GB BF16 load before online quantization kicks in.
  3. VLLM_DISABLE_COMPILE_CACHE=1 — torch.compile crashes with _pickle.PicklingError: Can't pickle <function launcher> during AOTAutogradCache save in the multiprocess EngineCore. Disabling the compile cache bypasses this while keeping torch.compile + CUDA graphs active. Cold start goes from ~1 min to ~3 min.
  4. Reasoning parser patch — vllm #38855: reasoning_content is always null because skip_special_tokens=True strips the <|channel> delimiters before the parser sees them. Patched via a mod that re-decodes with skip_special_tokens=False when reasoning boundary tokens are present.
Benchmarks — Single User (c=1)
llama-benchy --base-url http://localhost:8000/v1 --model google/gemma-4-31B-it \
  --pp 128 512 2048 --tg 32 128 --depth 0 --runs 3 --concurrency 1
model test t/s peak t/s ttfr (ms) est_ppt (ms) e2e_ttft (ms)
google/gemma-4-31B-it pp128 593.84 ± 95.22 228.45 ± 40.44 223.71 ± 40.44 228.53 ± 40.46
google/gemma-4-31B-it tg32 6.93 ± 0.01 7.00 ± 0.00
google/gemma-4-31B-it pp128 616.91 ± 98.45 219.81 ± 37.38 215.07 ± 37.38 219.88 ± 37.37
google/gemma-4-31B-it tg128 6.91 ± 0.01 7.00 ± 0.00
google/gemma-4-31B-it pp512 1569.74 ± 84.61 332.28 ± 17.59 327.54 ± 17.59 332.35 ± 17.59
google/gemma-4-31B-it tg32 6.86 ± 0.01 7.00 ± 0.00
google/gemma-4-31B-it pp512 1558.11 ± 10.33 334.00 ± 2.19 329.26 ± 2.19 334.08 ± 2.18
google/gemma-4-31B-it tg128 6.84 ± 0.00 7.00 ± 0.00
google/gemma-4-31B-it pp2048 1466.99 ± 2.91 1401.48 ± 2.78 1396.74 ± 2.78 1401.57 ± 2.79
google/gemma-4-31B-it tg32 6.79 ± 0.00 7.00 ± 0.00
google/gemma-4-31B-it pp2048 1478.21 ± 8.49 1391.15 ± 8.31 1386.41 ± 8.31 1391.24 ± 8.31
google/gemma-4-31B-it tg128 6.79 ± 0.00 7.00 ± 0.00
Benchmarks — Multi User (c=2, c=4)
  --pp 128 512 2048 --tg 32 128 --depth 0 --runs 3 --concurrency 2 4
model test t/s (total) t/s (req) peak t/s peak t/s (req) ttfr (ms) est_ppt (ms) e2e_ttft (ms)
google/gemma-4-31B-it pp128 (c2) 1142.43 ± 15.71 575.81 ± 8.37 225.78 ± 3.14 224.07 ± 3.14 225.81 ± 3.14
google/gemma-4-31B-it tg32 (c2) 13.93 ± 0.33 7.04 ± 0.09 16.00 ± 0.00 8.00 ± 0.00
google/gemma-4-31B-it pp128 (c4) 1189.79 ± 2.08 427.42 ± 129.01 333.62 ± 99.76 331.92 ± 99.76 333.66 ± 99.76
google/gemma-4-31B-it tg32 (c4) 26.82 ± 0.01 6.96 ± 0.05 32.00 ± 0.00 8.00 ± 0.00
google/gemma-4-31B-it pp128 (c2) 1142.08 ± 5.12 575.70 ± 2.86 225.49 ± 1.23 223.79 ± 1.23 225.54 ± 1.22
google/gemma-4-31B-it tg128 (c2) 12.95 ± 1.57 7.01 ± 0.03 16.00 ± 0.00 8.00 ± 0.00
google/gemma-4-31B-it pp128 (c4) 1504.25 ± 227.97 420.35 ± 72.59 318.28 ± 58.91 316.58 ± 58.91 318.31 ± 58.92
google/gemma-4-31B-it tg128 (c4) 27.43 ± 0.31 6.94 ± 0.02 29.33 ± 1.89 7.33 ± 0.47
google/gemma-4-31B-it pp512 (c2) 1904.91 ± 13.54 955.71 ± 6.80 538.50 ± 3.84 536.80 ± 3.84 538.55 ± 3.84
google/gemma-4-31B-it tg32 (c2) 13.90 ± 0.01 6.95 ± 0.00 14.00 ± 0.00 7.00 ± 0.00
google/gemma-4-31B-it pp512 (c4) 1770.15 ± 86.47 535.22 ± 82.74 983.92 ± 154.95 982.22 ± 154.95 983.94 ± 154.95
google/gemma-4-31B-it tg32 (c4) 23.95 ± 1.81 6.63 ± 0.27 28.00 ± 0.00 7.00 ± 0.00
google/gemma-4-31B-it pp512 (c2) 1906.87 ± 7.96 956.67 ± 4.06 537.60 ± 2.16 535.90 ± 2.16 537.64 ± 2.17
google/gemma-4-31B-it tg128 (c2) 11.92 ± 2.78 6.88 ± 0.11 14.00 ± 0.00 7.00 ± 0.00
google/gemma-4-31B-it pp512 (c4) 1846.54 ± 45.65 708.08 ± 387.71 895.61 ± 319.23 893.91 ± 319.23 895.63 ± 319.22
google/gemma-4-31B-it tg128 (c4) 24.89 ± 1.06 6.75 ± 0.08 28.00 ± 0.00 7.00 ± 0.00
google/gemma-4-31B-it pp2048 (c2) 1573.33 ± 5.19 943.33 ± 309.04 2332.16 ± 485.54 2330.46 ± 485.54 2332.21 ± 485.54
google/gemma-4-31B-it tg32 (c2) 12.31 ± 1.26 6.60 ± 0.47 14.00 ± 0.00 7.00 ± 0.00
google/gemma-4-31B-it pp2048 (c4) 1613.51 ± 10.79 549.32 ± 169.50 4050.59 ± 1049.58 4048.89 ± 1049.58 4050.62 ± 1049.56
google/gemma-4-31B-it tg32 (c4) 15.75 ± 1.79 5.62 ± 0.92 26.33 ± 2.36 7.26 ± 0.85
google/gemma-4-31B-it pp2048 (c2) 1574.70 ± 3.60 811.10 ± 23.39 2529.78 ± 72.68 2528.08 ± 72.68 2529.86 ± 72.67
google/gemma-4-31B-it tg128 (c2) 12.67 ± 1.25 6.81 ± 0.03 14.00 ± 0.00 7.00 ± 0.00
google/gemma-4-31B-it pp2048 (c4) 1617.20 ± 8.55 615.15 ± 336.70 3946.83 ± 1229.94 3945.13 ± 1229.94 3946.86 ± 1229.94
google/gemma-4-31B-it tg128 (c4) 22.90 ± 0.57 6.33 ± 0.32 28.00 ± 0.00 7.00 ± 0.00
torch.compile vs enforce-eager (c=1)
Out of the box, torch.compile crashes with a pickling error in AOTAutogradCache. Setting VLLM_DISABLE_COMPILE_CACHE=1 bypasses the cache serialization while keeping compilation + CUDA graphs active. The performance difference is meaningful:
Metric enforce-eager compiled Delta
tg32 decode (t/s) 6.88 6.93 +0.7%
tg128 decode (t/s) 6.24 6.91 +10.7%
pp128 prefill (t/s) 496 605 +22.0%
pp512 prefill (t/s) 1,321 1,564 +18.4%
pp2048 prefill (t/s) 1,416 1,473 +4.0%
TTFT pp128 (ms) 265 224 -15.5%
TTFT pp512 (ms) 391 333 -14.8%
Compilation gives +10-22% on prefill and longer decode. Short token generation (tg32) is fully memory-bandwidth bound and doesn’t benefit. The tradeoff is ~3 min cold start vs ~1 min (compilation happens fresh each launch since the cache is disabled).
Summary — Single Node (TP=1)
Single user 4 concurrent users
Decode (tg128) ~6.9 tok/s ~27 tok/s aggregate
Decode (tg32) ~6.9 tok/s ~27 tok/s aggregate
Prefill (pp512) ~1,560 tok/s ~1,850 tok/s
TTFT (pp512) ~333 ms ~940 ms
The model is solidly memory-bandwidth bound on the GB10 — per-request decode throughput stays flat (~6.8-7.0 t/s) regardless of concurrency. Aggregate scales near-linearly up to c=4. Prefill peaks at ~1,900 t/s at c=2, limited by the forced Triton attention backend (Gemma 4’s mixed head dimensions: 256 local / 512 global prevent FlashInfer).
Dual Spark — TP=2 Benchmarks (NEW)
Using vllm-node-tf5 container with --distributed-executor-backend ray and TP=2 across two DGX Sparks connected via InfiniBand.
  --pp 2048 --tg 32 128 --depth 0 4096 8192 16384 --runs 3 --concurrency 1
Token Generation (single user)
Context depth TP=1 (1 Spark) TP=2 (2 Sparks) Speedup
d=0, tg128 6.5 ± 0.0 t/s 11.2 ± 0.7 t/s 1.7×
d=4096, tg128 6.5 ± 0.0 t/s 10.3 ± 0.9 t/s 1.6×
d=8192, tg128 6.4 ± 0.0 t/s 10.1 ± 1.0 t/s 1.6×
d=16384, tg128 6.3 ± 0.0 t/s 11.0 ± 0.3 t/s 1.7×
Prompt Processing
Context depth TP=1 TP=2 Speedup
pp2048, d=0 1,890 ± 132 t/s 2,608 ± 69 t/s 1.4×
pp2048, d=8192 1,255 ± 1 t/s 2,010 ± 3 t/s 1.6×
pp2048, d=16384 886 ± 4 t/s 1,488 ± 2 t/s 1.7×
Time to First Response (lower = better)
d=0 1,300 ms 906 ms 1.4×
d=8192 8,926 ms 5,561 ms 1.6×
d=16384 22,669 ms 13,432 ms 1.7×
TP=2 VRAM usage
Node VRAM used
Head (Spark 1) 105,721 MB
Worker (Spark 2) 103,161 MB
Takeaway: TP=2 gives a consistent ~1.7× speedup across the board. Not a full 2× due to inter-node all-reduce overhead per layer via InfiniBand, but the improvement is meaningful — especially at longer contexts where TTFR drops from 22.7s to 13.4s at 16K depth. On GB10’s shared memory, nvidia-smi --query-compute-apps=used_gpu_memory is required for accurate VRAM readings (standard memory.used returns N/A).
Comparison across all Gemma 4 variants on Spark
Model Quant Nodes tg t/s (c=1)
Gemma 4 31B dense BF16 1 ~3.7
Gemma 4 31B dense FP8 runtime 1 ~6.5
Gemma 4 31B dense NVFP4 1 ~6.9
Gemma 4 31B dense FP8 runtime 2 (TP=2) ~11.2
Gemma 4 26B-A4B MoE FP8 1 ~38–40
Runtime FP8 single-node is within 6% of NVFP4. Dual-node TP=2 pushes past the single-node ceiling. The 26B-A4B MoE remains ~3.5× faster than dense 31B at TP=2 — expected since only 4B of 26B params are active per token.
Multimodal Vision Test
Gemma 4 is a multimodal model (text + image + video). Vision works out of the box via the standard OpenAI image_url content type — no extra flags needed.
Tested with a synthetic scene (house, tree, sun, sky):
"content": [
  {"type": "image_url", "image_url": {"url": "data:image/png;base64,..."}},
  {"type": "text", "text": "What is this a picture of? List everything you see."}
This is a simple, stylized illustration of a house in a landscape.
  • A house: It has a red body and a red triangular roof.
  • Windows: Two light-blue square windows on the house.
  • A door: A black rectangular door.
  • A tree: A brown trunk with a green circular top.
  • The ground: A solid green field.
  • The sky: A light blue background.
  • The sun: A yellow circle in the upper right corner.
Correctly identified all elements including shapes, colors, and spatial relationships. TTFT for vision requests is comparable to text-only (~300ms for small images).
Tool Calling & Agentic Workflows
With fix-gemma4-reasoning + fix-gemma4-tool-parser mods applied (vllm-node-tf5 container):
Test Streaming Result
Single tool call No ✅ Valid JSON arguments
Single tool call Yes ✅ Valid JSON streamed
Multi-tool call (parallel) No ✅ Both tools called correctly
Agentic multi-step (tool → result → synthesis) No ✅ Correct answer from tool data
Agentic multi-step Yes ✅ Streamed correctly
HTML in streaming tool args Yes ✅ No << duplication (PR #38909 fix)
Tool selection from 3 options No ✅ Correct tool chosen
Full agentic loop (2 tools → results → answer) Yes ✅ Complete workflow
Known limitation: Non-streaming maxSteps agent loops (e.g. Vercel AI SDK generateText with maxSteps) may exit after 1 step — vLLM returns stop instead of continuing tool calls (#39043). Streaming mode (streamText) is recommended for agentic workflows.
Open vLLM Issues Affecting Gemma 4
Issue Impact Status/Workaround
#38912 Pre-quantized FP8 checkpoints fail to load Use BF16 + --quantization fp8
#38946 Streaming tool calls produce invalid JSON Fixed via PR #38992 (merged)
#38855 reasoning_content always null Fixed via fix-gemma4-reasoning mod
#38909 Streaming HTML duplication in tool args Fixed via fix-gemma4-tool-parser mod
#39043 Tool call tags leak in non-streaming multi-turn Use streaming for agentic workflows
AOTAutogradCache pickle torch.compile cache crashes on aarch64 VLLM_DISABLE_COMPILE_CACHE=1
Reproduction
Recipe and mods available at spark-vllm-docker (PR #165 to upstream):
# Single node (TP=1)
HF_HOME=/mnt/tank/models ./run-recipe.sh gemma-4-31b-fp8 --setup --solo
# Dual node (TP=2)
HF_HOME=/mnt/tank/models ./run-recipe.sh gemma-4-31b-fp8 --setup -n spark1,spark2 --tp 2
# Benchmark
uvx llama-benchy --base-url http://localhost:8000/v1 \
  --pp 128 512 2048 --tg 32 128 --depth 0 4096 8192 16384 \
  --runs 3 --concurrency 1 2 4 --latency-mode generation
