I compile openpose in my jetson-nano. I got an error.
NOTE: This script assumes that just flashed JetPack 3.3 : Ubuntu 16, CUDA 9, cuDNN 7 and OpenCV are already installed on your machine. Otherwise, it might fail.
------------------------- Compiling OpenPose -------------------------
CXX/LD -o .build_release/examples/calibration/calibration.bin
CXX/LD -o .build_release/examples/openpose/openpose.bin
CXX/LD -o .build_release/examples/tutorial_add_module/1_custom_post_processing.bin
CXX/LD -o .build_release/examples/tutorial_api_cpp/04_keypoints_from_images.bin
/usr/bin/ld: cannot find -lopencv_contrib
/usr/bin/ld: cannot find -lopencv_gpu
collect2: error: ld returned 1 exit status
Makefile:492: recipe for target '.build_release/examples/calibration/calibration.bin' failed
make: *** [.build_release/examples/calibration/calibration.bin] Error 1
make: *** Waiting for unfinished jobs....
Makefile:492: recipe for target '.build_release/examples/openpose/openpose.bin' failed
make: *** [.build_release/examples/openpose/openpose.bin] Error 1
Makefile:492: recipe for target '.build_release/examples/tutorial_api_cpp/04_keypoints_from_images.bin' failed
make: *** [.build_release/examples/tutorial_api_cpp/04_keypoints_from_images.bin] Error 1
Makefile:492: recipe for target '.build_release/examples/tutorial_add_module/1_custom_post_processing.bin' failed
make: *** [.build_release/examples/tutorial_add_module/1_custom_post_processing.bin] Error 1
Errors detected. Exiting script. The software might have not been successfully installed.
When edit Makfile , using “OPENCV_VERSION := 3” ,I got an other error.
------------------------- Installing OpenPose -------------------------
/usr/bin/ld: .build_release/examples/calibration/calibration.o: undefined reference to symbol '_ZN2cv6String10deallocateEv'
/usr/lib/libopencv_core.so.3.3: error adding symbols: DSO missing from command line
/usr/bin/ld: .build_release/examples/openpose/openpose.o: undefined reference to symbol '_ZN2cv6String10deallocateEv'
/usr/bin/ld: warning: libopencv_core.so.3.3, needed by ./3rdparty/caffe/distribute/lib/libcaffe.so, may conflict with libopencv_core.so.4.0
/usr/bin/ld: .build_release/examples/tutorial_add_module/1_custom_post_processing.o: undefined reference to symbol '_ZN2cv6String10deallocateEv'
/usr/bin/ld: .build_release/examples/tutorial_api_cpp/04_keypoints_from_images.o: undefined reference to symbol '_ZN2cv6String10deallocateEv'
jetson-nano:~/nas/openpose$ jetson_release
- NVIDIA Jetson NANO/TX1
* Jetpack 4.2 [L4T 32.1.0]
* CUDA GPU architecture 5.3
- Libraries:
* CUDA 10.0.166
* cuDNN 7.3.1.28-1+cuda10.0
* TensorRT 5.0.6.3-1+cuda10.0
* Visionworks 1.6.0.500n
* OpenCV 4.0.0 compiled CUDA: YES
- Jetson Performance: inactive
- Jetson Easy v1.5.0
Do you have an idea how to fix this? :)
