I am experiencing the same issue as reported in http://forums.nvidia.com/index.php?showtopic=73981
briefly, I first declared a 2D texture:
texture<float2, 2, cudaReadModeNormalizedFloat> tS;
float2 *gS;
cudaMalloc((void **) &gS, sizeof(float2)*(DIMX)*(DIMY));
cudaChannelFormatDesc f2tex = cudaCreateChannelDesc<float2>();
cudaBindTexture2D(0,tS, gS,f2tex,DIMX,DIMY,DIMX);
then inside the kernel, I used
float2 ss=tex2D(tS,idx*rpix.x,idy*rpix.y);
to read the texture (idxrpix.x and idyrpix.y is the normalized coordinates), then I compile the code, nvcc complained
error: no instance of overloaded function "tex2D" matches the argument list
argument types are: (texture<float2, 2, cudaReadModeNormalizedFloat>, float, float)
if I change cudaReadModeNormalizedFloat to cudaReadModeElementType, nvcc works; if I change float2 to uchar or float, nvcc compiles ok too.
is this a bug?
