module jacksort
implicit none
integer, parameter :: ncon = 21
private
public :: SetErrorFunction
abstract interface
pure function error_template2 ( x )
import :: ncon
real, dimension(0:, 0:), intent(in) :: x
real, dimension(ncon) :: error_template2
end function error_template2
end interface
procedure(error_template2), pointer :: errorfunction2 => null()
contains
pure function jackerror2 ( x )
real, dimension(ncon) :: jackerror2 ! <== FN result
real, dimension(ncon) :: avg, err
avg = sum(x(1:ncon, 1:ncon), dim=2) / real(ncon - 1)
err = sum((x(1:ncon, 1:ncon) - spread(avg, dim=2, ncopies=ncon))**2, dim=2)
jackerror2 = sqrt(err * real(ncon - 2) / real(ncon - 1))
end function jackerror2
subroutine SetErrorFunction ( func )
character(len=*), intent(in) :: func
select case( func )
case( 'jack' )
errorfunction2 => jackerror2
case default
stop 'Unknown error type '
end select
end subroutine SetErrorFunction
end module jacksort
causes the compiler to say
PGF90-S-0155-Illegal POINTER assignment - rank mismatch (jck1.f90: 35)
0 inform, 0 warnings, 1 severes, 0 fatal for seterrorfunction
even though the pointer and pointee are both real, dimension(ncon).
