SUBROUTINE SetRtSrc(Core, Fxr, src, phis, psi, axsrc, xstr1g, &
eigv, iz, ig, ng, GroupInfo, l3dim, lxslib, lscat1, lNegFix, PE)
USE PARAM
USE TYPEDEF, ONLY : coreinfo_type, Fxrinfo_type, Cell_Type, &
pin_Type, GroupInfo_Type, PE_TYPE, &
XsMac_Type
USE BenchXs, ONLY : GetChiBen, xssben
USE MacXsLib_mod, ONLY : MacXsScatMatrix
USE BasicOperation, ONLY : CP_CA
USE OMP_LIB
IMPLICIT NONE
TYPE(CoreInfo_Type) :: Core
TYPE(FxrInfo_Type) :: Fxr(:)
TYPE(GroupInfo_Type) :: GroupInfo
TYPE(PE_TYPE) :: PE
REAL(8) :: src(:), phis(:, :, :), psi(:, :), AxSrc(:), xstr1g(:)
REAL(8) :: eigv
INTEGER :: myzb, myze, ig, ng, iz, ifsr, ifxr
LOGICAL :: lxslib, lscat1, l3dim
LOGICAL :: lNegFix
TYPE(Pin_Type), POINTER :: Pin(:)
TYPE(Cell_Type), POINTER :: CellInfo(:)
TYPE(XsMac_Type), SAVE :: XsMac(nTHREADMAX)
INTEGER :: nxy, nCoreFsr, nCoreFxr, FsrIdxSt, FxrIdxSt, nlocalFxr, nFsrInFxr, nchi
INTEGER :: ipin, icel, ifsrlocal, itype, ig2, tid
INTEGER :: i, j, k
REAL(8) :: reigv
REAL(8) :: chi(ng)
REAL(8), POINTER :: xsmacs(:,:)
LOGICAL :: lscat1sum
LOGICAL :: lNegSrcFix
Pin => Core%Pin
CellInfo => Core%CellInfo
nCoreFsr = Core%nCoreFsr
nCoreFxr = Core%nCoreFxr
nxy = Core%nxy
reigv = one/eigv
lscat1sum = lscat1
lNegSrcFix = FALSE
IF(lNegFix) lNegSrcFix = TRUE
IF(.NOT. lxsLib) THEN
DO i = 1, PE%nThread
ALLOCATE(XsMac(i)%XsMacSm(ng, ng))
ENDDO
ENDIF
CALL CP_CA(src(:), zero, nCoreFxr)
!IF(.NOT. lxsLib) CALL CP_CA(xsmacs, zero, ng, ng)
IF(lxsLib) nchi = GroupInfo%nchi
tid = 1
!$ call omp_set_dynamic(.FALSE.)
!$ call omp_set_num_threads(PE%nThread)
!$OMP PARALLEL DEFAULT(SHARED) &
!$OMP PRIVATE(i, j, k, ifsr, ifxr, ipin, icel, ifsrlocal, itype, ig2, tid, FsrIdxSt, FxrIdxSt, nlocalFxr, nFsrInFxr, xsmacs, chi)
!$ tid = omp_get_thread_num()+1
!$OMP DO
The pgserv.exe and VS2013 literally die (no error message, just stop functioning) when the parallel region starts.
What is the problem?
