I have a Fortran program running well if it is compiled with PGI’s PVF 15.3 with default setting, or with Auto-parallelization, or with Optimization. But it does not work with OpenMP directives enabled, even there is no OpenMP directive in the source code.
If it is compiled with OpenMP directives and Runtime | check stack bounds enabled, it runs fine (writing results out to files) before crashes, without any warning, at one subroutine. It writes outputs to file just before calling the subroutine, but does not write outputs to file at very earliest part of the subroutine.
If Runtime | check stack is not enabled, it shows a popup window with message
“Fexe.exe has stopped working. A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available. Debug or close program”
(Fexe.exe is my executable program)
When Debug is clicked, with Microsoft Visual Studio debugger, it shows
“Unhandled exception at 0x0F4812A7 (pgc.dll) in Fexe.exe: 0xC0000005: Access violation writing location 0xFFBD6B94.”
Is there something implied in OpenMP compilataion? There is no OpenMP directive in the code.
