I’m testing code from a collaborator that implements Kronecker products as OpenACC and OpenMP target offload kernels:
I’m specifically testing the OpenACC version. When compiling it with NVHPC 21.2 using the provided build_pgi.sh
script, nvfortran
emits that error message referenced in the title at the stage when it compiles the double complex version of the code.
NVFORTRAN-S-0155-Compiler failed to translate accelerator region (see -Minfo messages): Unexpected address of constant (kron_mod.f90: 103)
Furthermore, when trying to inline the code for the OpenACC GEMM implementation, the compiler emits the following error message:
NVFORTRAN-S-0155-Compiler failed to translate accelerator region (see -Minfo messages): Could not find allocated-variable index for symbol - ..inline (kron_mod.f90: 103)
Notice that it’s the exact same line in kron_mod
!$acc kernels present(A1,X,Y)
The full output of the compile script can be found here.
Any help would be appreciated.
