Nvfortran 25.11: internal compiler error with OpenACC code
Hi Mat,
Unfortunately I’m back with another issue in nvfortran, now with version 25.11.
The following code compiles with -O0 [nvfortran -O0 -acc -c farm.f90] but not does compile with -O1 , -O2 or -O3 . Note the team might find the error message emitted at -O1 most useful. The code used to compile at all optimisations levels with nvfortran 25.7 and 25.9.
module farm
  implicit none
  contains
  subroutine fox(scalar)
    real(kind=8), intent(inout) :: scalar
    real(kind=8), dimension(10) :: array
    !$acc kernels
    if (scalar < 1.0) then
      array(:) = 1
    end if
    !$acc end kernels
  end subroutine fox
  subroutine chicken()
    logical :: bool
    integer :: int
    real(kind=8) :: scalar
    real(kind=8), allocatable, dimension(:) :: array
    allocate(array(10))
    !$acc kernels
    scalar = array(5)
    if (bool .AND. int == 0) then
      array(:) = 1
    else
      array(:) = 2
    end if
    !$acc end kernels
    call fox(scalar)
  end subroutine chicken
end module farm
Cheers,
-Nuno
Thanks Nuno! I was able to track down the check-in where this started and sent the engineer a report. Filed as TPR #38055.
-Mat
Hi Mat, this seems to have been fixed in 26.1!
Could you please confirm when you get a chance?
Hi Nuno,
Yes, TPR#38055 was fixed in 26.1.
Thanks again for the report.
-Mat
Excellent, and thanks for the very quick turnaround once again.
