Timeline for OpenACC array reduction support in nvfortran?
Is there a timeline for nvfortran supporting array reductions in OpenACC loop constructs? I’m getting the error
NVFORTRAN-F-0155-Array reduction support is not complete and this case is not yet supported
For a simple reduction like
real(8) accum(3)
accum(3) = 0.d0
!$acc loop reduction(accum)
do ...
Just wondering if I should code this up as three scalar reductions…
Thanks,
Paul
Hi Paul,
OpenACC array reduction support was added in the 22.2 release. Which version of the compiler are you using?
-Mat
Ah, okay. I’m still on 22.1. I’ll upgrade.
Okay, I made the switch to 22.3, but now have a new problem… when I go to link my application with 22.3, I get:
nvlink error   : File uses too much global constant data (0x21e88 bytes, 0x10000 max)
It works find with 22.1 (exact same code base, clean builds with each compiler). Any suggestions on how to track this down, even to which file might be causing this? OpenACC only.
Thanks,
Paul
Nevermind… Max Katz is helping me figure it out.
Cheers,
Paul
Sounds good. Though I sent a note to engineering if they have any ideas.
Thanks. It appears that cuRAND is injecting a lot of static data into module files that don’t have any ACC in them.
