I am trying to utilize array reduction instead of atomics on this loop. The code compiles fine but has a segmentation fault when I try to run it. Is this a none allowed loop?
!$acc parallel loop collapse(2) default(present) reduction(+:fn,fs)
do k=2,npm-1
do i=1,nblk
fn(i) = fn(i) + flux_t(i, 2,k)*dp(k)
fs(i) = fs(i) + flux_t(i,ntm1,k)*dp(k)
enddo
enddo
Any help would be appreciated.
Hi Miko,
Is it a seg fault (host) or illegal address error (device)?
How big are the fn and fs arrays?
In order to do a reduction, each thread is going to get a complete private copy of each array. (allocated as one large block of memory). Depending on how the compiler is scheduling this, it may mean as many as (npm-2)*nblk threads times the size of the arrays.
You can try adding “-mcmodel=medium” so 64-bit offsets are used for large arrays, but you may be better off sticking with atomics as the overhead to do the reduction is high… Alternatively, you can interchanging the loops and only parallelize the i loop so neither atomics nor reductions are needed.
-Mat
-Mat
Hi Mat,
It is “./Run: line 1: 2404805 Segmentation fault (core dumped)”
It seems the problem only occurs on the CPU. The code runs find on the GPU with the reduction.
Ok, does adding “-mcmodel=medium” help?
Could it be a stack overflow? i.e. does setting “OMP_STACKSIZE=” help?
It could be a compiler issue as well, in which case, can you provide a minimal reproducing example?
Hello Mat,
Neither of those helped.
Here is an example code.
program Example
use iso_fortran_env
implicit none
integer, parameter :: r_typ = REAL64
integer :: j,k,i
integer :: nblk,nt,npm
real(r_typ), dimension(:), allocatable :: fn
real(r_typ), dimension(:,:,:), allocatable :: flux_t
nblk = 1
nt = 513
npm = 1025
allocate (flux_t(nblk,nt,npm))
!$acc enter data create(flux_t)
do concurrent (k=1:npm,j=1:nt,i=1:nblk)
flux_t(i,j,k) = 1.0
enddo
allocate (fn(nblk))
!$acc enter data create(fn)
do concurrent (i=1:nblk)
fn(i) = 0.0
enddo
!$acc parallel loop collapse(2) default(present) reduction(+:fn)
do k=2,npm-1
do i=1,nblk
enddo
enddo
!$acc exit data delete(flux_t,fn)
deallocate (flux_t)
deallocate (fn)
end program Example
Thanks Miko, I filed TPR #32397 and sent it to engineering for review.
My best guess is the array reduction is somehow corrupting the base copy of “fn” since the segv occurs when it’s accessed after the parallel loop. Also, if I don’t initialize “fn” in a compute region (or do conncurrent), then the program runs correct. Not sure this would be a viable work around for you:
% cat test.F90
program Example
use iso_fortran_env
implicit none
integer :: j,k,i
nblk = 1
nt = 513
npm = 1025
allocate (fn(nblk))
flux_t = 1.0
#if defined(CASE1)
!$acc kernels
fn = 0.0
!$acc end kernels
#else
! works
fn = 0.0
#endif
!acc parallel loop collapse(2) default(present) reduction(+:fn(:nblk))
!$acc parallel loop reduction(+:fn(1:nblk))
do k=2,npm-1
do i=1,nblk
enddo
enddo
print *, "HERE"
! segv here when fn is accessed
print *, fn(1)
deallocate (flux_t)
deallocate (fn)
end program Example
% nvfortran -acc=multicore test.F90 -g -DCASE1 ; a.out
HERE
Segmentation fault
% nvfortran -acc=multicore test.F90 -g ; a.out
HERE
1023.000000000000
-Mat
Hi Miko,
Sorry it took so long on this one, but engineering let me know that TPR #32397 was fixed in our 25.9 release.
-Mat
